Looking for Center Channel 6'' or less in height - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 03-07-2014, 06:30 AM - Thread Starter
sumik's Avatar
Hello, I'm looking for Center channel that would be 6'' high or less for home theater, mostly for movies.
It needs to be in a line with some bookshelves as I will need LCR setup.
Budget for 3 speakers is $1500, cannot listen to speakers locally as there's no shops around me.
sumik is offline
post #2 of 5 Old 03-07-2014, 08:30 AM
crazyrob425's Avatar
Quoted: 443 Post(s)
Liked: 337
What is the size of your listening/viewing room?
crazyrob425 is offline
post #3 of 5 Old 03-07-2014, 10:43 AM - Thread Starter
sumik's Avatar
Room is 25 long by 12 wide. TV stand right in middle dividing room into two. From couch to tv is 12ft and then another 12 ft behind tv of open space where dining table stands.
I also have outlaw lmf1 plus sub for the setup.
sumik is offline
post #4 of 5 Old 03-10-2014, 11:30 AM
Quoted: 443 Post(s)
Liked: 337
A center channel that is only 6" tall at max will end up being a very small center in a large room.
While you have an appropriate subwoofer the size you set for your other speakers really limits you choices.
This flat panel speaker might work for you
http://www.htd.com/Products/flat-panel-speakers/flat-panel-speaker
post #5 of 5 Old 03-10-2014, 12:24 PM
callas01's Avatar
Quoted: 829 Post(s)
Liked: 463
dynaudio dm series dm center and dm2/6 would be about $1500 and meet your requirements. Dialog will be clear and intelligible and it'll have decent punch for its size.
I think you could buy from dedicated audio.com
Dynaudio Focus 260s, Focus 210C, DM 2/6, Hsu VTF3 MK5 HP, Oppo BDP-103, NaimUniti 2, Naim Stageline N, Pro-ject 2xperience Classic, Marantz SR7007, 60" 4K Samsung LED LCD
callas01 is offline
Reply Speakers
