Best Speaker and subwoofer combination - advice please - AVS Forum | Home Theater Discussions And Reviews
post #1 of 30 Old 03-14-2014, 04:48 AM - Thread Starter
Bndck's Avatar
I am newbee. Recently i bought Denon DRA210 stereo amplifier (seperate system 50 WPC 8 Ohm 20Hz - 20kHz accoring to the manual). That has 8 terminal out for speakers. Impedence indicates A or B 6~10 Ohm and A+B 12~16 Ohm (this i cannot undestand at all). it has one pre out (i am assuming it's for subwoofer) L and R. what speaker configuration you suggest?. I had look 4 Ohm 80 Watts speaker pair and 8 Ohm 100 Watts speaker pair. both are Monitor Audio. both are sounding good in the studio. which one ideal for my configuration without any damage to either amp or speakers or what speaker configuration you would suggest? what subwoofer i should look for(Mono/Stereo)?.
Many thanks,,.
Ben
Bndck is offline
post #2 of 30 Old 03-14-2014, 05:40 AM
Transmaniacon's Avatar
Quoted: 1530 Post(s)
Liked: 1319
Do you need to drive both speaker sets? It should do fine driving one pair, you can hook up 4ohm speakers but you won't be able to drive them as well. Either speaker pair would work fine.
Is that a sub pre-out or just pre-outs for the main speakers? If there is no sub pre-out then you need to hook up a sub via speaker level inputs and outputs.
As for a sub recommendation, what is your room size, budget, and listening habits.
Samsung PN60F5300 | Denon AVR-1713 | EMP E55Ti | EMP E56Ci | EMP E5Bi | Outlaw Ultra-X12
Transmaniacon is offline
post #3 of 30 Old 03-14-2014, 06:07 AM - Thread Starter
Bndck's Avatar
Hello
Thanks Transmaniacon. I dont need to drive both speakers. this system is mainly for play Music/connect with i pod. I have seperate Home Theatre. my room area is about 150 suqare feets roughly. i add image here back of my amp. you can get clear idea. what subwoofer/speakers you suggest.
Bndck is offline
post #4 of 30 Old 03-14-2014, 06:17 AM
Liked: 1319
Your Monitor Audio speakers are still probably good, I would use one of those pairs for now. You don't have a sub pre-out on there, which means you need to find a sub woofer that has speaker level connections. What is your budget for a sub, and how big is your space?
post #5 of 30 Old 03-14-2014, 06:24 AM - Thread Starter
Bndck's Avatar
My budget is around 400$. i hook up this amp for my very old ADC SoundImage pair of speakers which were there gathering dust. (probbaly you have not heard about that). WOW. sound was incredible. but one tweeter is not not working..so i decided to go for Monitor Audio. suggest me nice Sub for this price tag.
thanks
Bndck is offline
post #6 of 30 Old 03-14-2014, 06:30 AM
Liked: 1319
Still need to tell me your room size and listening habits, is this for music or movies or both?
post #7 of 30 Old 03-14-2014, 06:36 AM - Thread Starter
Bndck's Avatar
this system only for Music cd/ipod . room size is about 150 square feets. many thanks
Bndck is offline
post #8 of 30 Old 03-14-2014, 06:55 AM
Liked: 1319
http://hsuresearch.com/products/stf-2.html
post #9 of 30 Old 03-14-2014, 07:55 AM
cel4145's Avatar
Quoted: 2652 Post(s)
Liked: 2984
Although the receiver does have left/right pre-outs on the back. I think a sub with left/right RCA inputs might be better.
This Reaction Audio BPS 212 subwoofer that is on closeout for $329 would work quite well.
Living room HT: Energy RC-50, Ascend Sierra Horizon w/RAAL, Ascend Sierra 1, PSB Imagine XA | PSA V1500 and CHT SS 18.1 | Denon X4200W | modified Dayton SA1000
Other rooms: CBM-170 SE | SVS SB-1000 | Audio-GD NFB-11 | Parasound Zamp | JBL LSR305
Headphone & Portable AKG K7XX | NAD HP50 | AKG K550 | Soundmagic E50 & E80 | DX50 | E12 | X1
cel4145 is offline
post #10 of 30 Old 03-14-2014, 08:38 AM
zieglj01's Avatar
Quoted: 938 Post(s)
Liked: 846
Are you from the USA?
__________________________________________
Who AM I
Speakers > Snell K7, EOS 150SP
Receiver > Tascam PAR-200
zieglj01 is offline
post #11 of 30 Old 03-14-2014, 08:40 AM
zieglj01's Avatar
Quoted: 938 Post(s)
Liked: 846
A new company - and they are having a close-out?
Who AM I
zieglj01 is offline
post #12 of 30 Old 03-14-2014, 08:55 AM
cel4145's Avatar
Liked: 2984
They decided to stick with the more expensive turbo model with the more powerful amp instead.
cel4145 is offline
post #13 of 30 Old 03-14-2014, 09:23 AM - Thread Starter
Bndck's Avatar
want to have a look on Reaction Audio sub. i'l update it
Bndck is offline
post #14 of 30 Old 03-14-2014, 10:23 AM
cel4145's Avatar
Liked: 2984
Here's the discussion thread for their subs, and the owner answers questions.
cel4145 is offline
post #15 of 30 Old 03-14-2014, 10:28 AM
crazyrob425's Avatar
Quoted: 443 Post(s)
Liked: 337
He can use the AMPs RCA L/R outputs to go to the subwoofer amp
x2
crazyrob425 is offline
post #16 of 30 Old 04-08-2014, 02:54 PM
diptiman's Avatar
Hi,
Can someone suggest me if I can use Klipsch and Polk combination in my Home Theater. I will provide what I have.
1.) Receiver - Pioneer 5.1 VSX 522K(Not planning to upgrade right at this moment)
2.) Front Speakers - Klipsch Icon KB15
3.) Center - Klipsch Icon KC25
I was planning to buy the following...
Sub-woofer - Can I use a Polk?
Surround Speakers - Can I use the Bookshelf Polk Audio - 5-1/4" 2-Way Bookshelf Speakers (Pair) - Black Ash Vinyl?
Suggestions required - Can I combine Polk and Klipsch like the way I am thinking?
DB
diptiman is offline
post #17 of 30 Old 04-08-2014, 02:57 PM
Liked: 1319
Originally Posted by diptiman View Post
Hi,
DB
Your surround speakers do not need to match, the Polks should work fine. The same goes for a sub, but Polk subs are not very good. What is your budget for a sub? We can recommend something better.
post #18 of 30 Old 04-08-2014, 06:01 PM
diptiman's Avatar
Thanks for the reply. For subwoofer I have a budget of $150. Will I get a good subwoofer in this price? What are the suggestions from your end?
DB
diptiman is offline
post #19 of 30 Old 04-08-2014, 06:01 PM
diptiman's Avatar
diptiman is offline
post #20 of 30 Old 04-09-2014, 05:38 AM
Liked: 1319
DB
http://www.amazon.com/JBL-ES150PBK-300-Watt-Powered-Subwoofer/dp/B00166VDLC/ref=sr_1_20?ie=UTF8&qid=1397043497&sr=8-20&keywords=subwoofer
post #21 of 30 Old 04-09-2014, 05:42 AM
arnyk's Avatar
Quoted: 851 Post(s)
Liked: 1238
Marginal depending on your expectations.
Acoustech PL200
or
BIC F12
arnyk is offline
post #22 of 30 Old 04-09-2014, 10:12 AM
diptiman's Avatar
So can I think that Polk bookshelf can work as surrounds? Which are the good satellite speakers?
I am getting i steal price $99 for Polk
http://www.amazon.com/Polk-Audio-Bookshelf-Speakers-Black/dp/B002RJLHB8/ref=sr_1_1?ie=UTF8&qid=1397059681&sr=8-1&keywords=polk+T15
OR
http://www.amazon.com/Polk-Audio-Two-Way-Bookshelf-Loudspeakers/dp/B000MGNDHE/ref=sr_1_2?ie=UTF8&qid=1397059681&sr=8-2&keywords=polk+T15
I can go for a bit higher budget for surrounds. Suggestions always welcome.
DB
diptiman is offline
post #23 of 30 Old 04-09-2014, 10:41 AM
Liked: 1319
http://www.amazon.com/Polk-Audio-On-Wall-Speaker-Black/dp/B0018QNYVM/ref=sr_1_1?ie=UTF8&qid=1397061563&sr=8-1&keywords=owm3
I would use these for surrounds. They are more shallow and come with a variety of wall mounting options. You also won't run into port issues when you put a bookshelf against a wall (the ones you linked are rear-ported).
post #24 of 30 Old 04-09-2014, 11:33 AM
zieglj01's Avatar
Quoted: 938 Post(s)
Liked: 846
Focal Sib - the shelf stand can also be used for wall mounting
http://www.accessories4less.com/make-a-store/item/focalsibprwht/focal-sib-5-2-way-satellite-loudspeakers-pair-white/1.html
Who AM I
zieglj01 is offline
post #25 of 30 Old 04-09-2014, 10:15 PM
diptiman's Avatar
I am actually looking for a subwoofer with 220-240V inlet. Can anyone suggest anything? The ones suggested are 110V inlet.
Thanks in advance
DB
diptiman is offline
post #26 of 30 Old 04-10-2014, 06:52 AM
Bill Fitzmaurice's Avatar
Liked: 4628
That indicates you're not in North America. You need to put your location on your profile so that you won't be advised to get gear that's not available to or useable by you.
Bill Fitzmaurice is offline
post #27 of 30 Old 04-10-2014, 08:24 AM
diptiman's Avatar
I am in North America.
I need to buy 2 of them. 1 with 110V and other with 220-240V inlet.
Is there anything which supports 110V to 240V?
One of them I need to send to India as gift.
DB
diptiman is offline
post #28 of 30 Old 04-10-2014, 08:34 AM
cel4145's Avatar
Liked: 2984
SVS Sound sells subwoofer internationally, so I would imagine that they can do one with 220-240V.
cel4145 is offline
post #29 of 30 Old 04-11-2014, 04:06 PM
diptiman's Avatar
SVS looks like very expensive!
DB
diptiman is offline
post #30 of 30 Old 04-11-2014, 04:16 PM
Jahjd2000's Avatar
Quoted: 48 Post(s)
Liked: 79
Rythmik also sells subs with a 240V option.
Dolby Atmos 5.1.4
Denon x6200
Ascend Acoustics Towers and Horizon Center (NrT)
RSL 34CE in-ceilings (4)
Rythmik E15HP
Jahjd2000 is offline
Reply Speakers
