Will Klipsch HT system overwhelm room? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 03-15-2014, 03:34 PM - Thread Starter
notmybutt's Avatar
Hi all,
I have a 18 x 12 x 9 foot room for my HT system, with the following parts:
  • two Klipsch RF-82 for the tower speakers
  • one Klipsch rc-52 for the center speaker
  • two Klipsch RS-42 for the surround speakers
  • one Klipsch downfiring 12 inch subwoofer (sub-12)
  • yamaha rx-v575 7.1 for receiver
Should I have a bought a smaller system instead?  Just worried it's to much for the room.  Welcome all feedback.
notmybutt is offline
post #2 of 5 Old 03-15-2014, 04:17 PM
crazyrob425's Avatar
Quoted: 443 Post(s)
Liked: 337
I would look at smaller towers from the front left and right or a larger center. The RF-62's are plenty.
BTWs you can always turn the speakers down but you can only turn them up so much.
If you are paying $400 for the Sub-12 their are better things out there for your budget
crazyrob425 is offline
post #3 of 5 Old 03-15-2014, 05:46 PM
Kini62's Avatar
Quoted: 1421 Post(s)
Liked: 1307
Yep. Save a few dollars and get the 62s and put the savings toward a "real" sub.
Def Tech SC8000
Harman Kardon AVR 1600
PS3, Apple TV, Sharp 70" Qattron
Kini62 is offline
post #4 of 5 Old 03-15-2014, 06:34 PM - Thread Starter
notmybutt's Avatar
The thing is I've already purchased the rf-82.  It was on a great sale and it was just a little more expensive than the rf-62.   I couldn't resist at the time.  Now I'm just wondering if I've made a bad decision.
What should I expect if I stick with the RF-82's?  Will there be to much bass, treble?  Or is it just going to very difficult to calibrate with the Yamaha's YPAO calibration?
post #5 of 5 Old 03-15-2014, 06:47 PM
Secret Squirrel's Avatar
Quoted: 44 Post(s)
Liked: 39
I personally think you're better off with the larger RF-82 towers. Your room is on the large side. I think the RF-82 will be more capable for your room size then the RF-62. The price difference isn't that much between these speakers. I would of also chose the larger speakers just for the small increase in the price. You won't have a problem with these speakers overpowering the room or having to much bass. That's what the calibration process is for. If you like to listen loud the larger speakers will also be a benefit. The larger drivers won't have to work as hard as the smaller drivers in the RF-62 at loud volumes.
Secret Squirrel is offline
Reply Speakers
