Recommendation for surround speaker wire - AVS Forum | Home Theater Discussions And Reviews
Old 03-15-2014, 08:39 PM - Thread Starter
rsinclair's Avatar
Just bought our first home, so I'm looking at having to run longer speaker wire to the surrounds than I have in my previous apartment residences.
I'll also be running the wire under the house in the crawlspace, so I'll probably need some additional slack as well.
I'll be running the wire to two Snell LCR7 loudspeakers as surround channels, as well as to two Buttkicker LFE modules under the couch.
Looking for a recommendation for good speaker without breaking the bank. I don't think I need audiophile-grade stuff here, but I am willing to pay for quality that makes an actual difference.
In terms of the length, it's hard to say since we haven't even moved into the house yet and I've never run speaker wire under a house before. The physical distance from the speaker to the surround processor is only 10 feet or so in a straight line, but I've got to run the wire down the length of the speaker stands (~36"), then under the house, across the living room to the opposite wall, then up into some conduit, and finally down again into the alcove where my entertainment center is.
If I had to make a rough guess, I'd say each length would be about 30 feet or so, and I'd be running 4 wires (two to surrounds and two to the Buttkickers.)
Want to make sure the gauge is good enough so quality won't be an issue (I don't want to have to replace it for many years) and I'll be running it inside a wall so I want it to be up to code as well.
Not sure if I should be looking for a spool I can cut to my own lengths, or buying off-the-shelf predetermined lengths, but open to any suggestions. Would prefer to just run the same wire for both the surrounds and Buttkickers unless there's an amazing reason to use different wire types for them.
R
rsinclair is offline
Old 03-16-2014, 02:25 AM
jevans64's Avatar
Quoted: 187 Post(s)
Liked: 145
I use this speaker wire in any installs I perform...
12 ga. $ 0.75 by the foot... http://www.knukonceptz.com/productDetail.cfm?prodID=KL3-122
or
10 ga. $ 1.15 by the foot... http://www.knukonceptz.com/productDetail.cfm?prodID=KL3-102
You can save a little bit by ordering in 100 foot or 250 foot lengths. This cable is molded, not sheathed like eBay and MonoPrice cable, and is perfectly round. Great for applying TechFlex over when NOT running in-wall. It is a high strand count for more flexibility. Some of my installs involve exactly what you are doing -- running partially in attic or crawlspace. I run straight through the wall using blank wall plates and only TechFlex the wire coming out of the wall. It is a little harder to do but eliminates TWO wire breaks and potential for signal loss/failure not to mention the additional cost of jacked wall plates and additional termination hardware.
The ButtKickers might need something a little different depending on where the amp for those will be located. ButtKickers are 4 Ohm but the 12 gauge should still be fine as long as the run isn't more than 30 feet from amp to transducers. I actually decided to run high-quality RCA from the AVR's LFE output to the LFE input on a separate ButtKicker amp. My ButtKicker amp is real close to my seating, so I only needed 6 foot runs of speaker wire. I usually recommend 500 watts per kicker but that is if you want a lot of kick. I generally don't run mine more than 40% of max and that is with two kickers mounted to a three-seat couch with a BKA1000 amp.
Denon AVR X7200WA, Emotiva XPR-5, Emotiva XPA-7, Sony XBR 75" 850C, Oppo UDP-203, Roku Ultra.
DefTech BP7000SC (L/R), CLR3000 (C), SM55 (FH), UIW BPZ/A (SB), UIW 75 (TM).
JBL L7 (Sur), EoSone RSR 350 (RH).
PC 2.1 setup. Emotiva Stealth 6, SVS SB16-Ultra sub, Emotiva DC-1 DAC.
jevans64 is online now
Old 03-16-2014, 02:34 AM
mercury's Avatar
Liked: 101
Do yourself a favor and get any of these and call it a day-
http://www.monoprice.com/Search?keyword=IN+WALL+SPEAKER+WIRE
Mrkazador likes this.
Panasonic 65" plasma*
Denon 4520*
PSB T45* PSB B15* PSB C60*
Dual PSA XS30* Dual PSA XS15se*
Squeezbox*
Niles ZR-6 6 Source, 6 room Audio Reciever*
mercury is offline
Old 03-16-2014, 03:12 AM
Mrkazador's Avatar
Quoted: 252 Post(s)
Liked: 378
Yep. Plus, have a read at this
http://www.roger-russell.com/wire/wire.htm#wiretable
Mrkazador is offline
Old 03-16-2014, 07:21 AM
Bill Fitzmaurice's Avatar
Liked: 4631
Higher price does not equate to higher quality. Get the least expensive pure copper conductor wire of sufficient gauge. You can spend a thousand times more and it will sound the same. Use this to determine the required gauge:
http://www.bcae1.com/images/swfs/speakerwireselectorassistant.swf
Bill Fitzmaurice is offline
Old 03-16-2014, 08:18 AM
commsysman's Avatar
Quoted: 964 Post(s)
Liked: 521
Get the Monoprice CL2 #14 jacketed copper speaker cable for under-house runs.
Monoprice Part # 2820 (100 feet) or #2821 (250 feet).
It is about 30 cents per foot.
commsysman is offline
Old 03-16-2014, 08:38 AM
Quoted: 73 Post(s)
Liked: 112
Another vote for Monoprice.
rnatalli is offline
