Center used as mains? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 31 Old 03-16-2014, 07:39 AM - Thread Starter
Hockeypucks's Avatar
Quoted: 12 Post(s)
Liked: 49
Just wondering if a decent center channel could be used up front for all 3. I'm looking at the Focal 800v but placing all 3 vertically behind an AT screen.
Hockeypucks is offline
post #2 of 31 Old 03-16-2014, 07:42 AM
commsysman's Avatar
Quoted: 964 Post(s)
Liked: 521
You usually will get better sound quality and especially imaging from a pair of tower or bookshelf speakers.
Focal makes very good speakers, but I think that is a rather bad idea.
The 800v is not designed to be used vertically.
commsysman is offline
post #3 of 31 Old 03-16-2014, 08:00 AM - Thread Starter
Quoted: 12 Post(s)
Liked: 49
Yeah I looked at the speaker again and noticed the tweeter looks like it's designed for a horizontal setup. Ideally I would like 3 bookshelf speakers across the front but most are offered in pairs so that's why I thought of going with 3 centers. I haven't noticed anyone doing this so that must be for a reason smile.gif
post #4 of 31 Old 03-16-2014, 08:06 AM
commsysman's Avatar
Quoted: 964 Post(s)
Liked: 521
MUsic Direct has a great special on the 714V speakers.
A pair of those plus the cc700v would be a nice combination.
Or, if you don't want tower speakers, the 806V speakers.
If you are going to use stands, don't get flimsy wood stands; get the SANUS STEEL foundations stands or something equally strong and rigid for good coupling to the floor.
It also helps to put steel birdshot or sand in the vertical columns for more mass and damping.
Good stands make a HUGE difference in speaker performance; the difference between poor sound and excellent sound in many cases.
post #5 of 31 Old 03-16-2014, 08:44 AM - Thread Starter
Quoted: 12 Post(s)
Liked: 49
I will be building a false wall for my screen so I'll most likely frame in some custom stands for the speakers. I've been eyeing the deals at music direct, they look pretty good. These speakers are for a dedicated theater and I have 2 SVS PB-2000 subs for all my low end so that's why I don't mind going with decent bookshelf speakers. I am liking that center though I've never heard anything focal makes.
post #6 of 31 Old 03-16-2014, 09:46 AM
commsysman's Avatar
Quoted: 964 Post(s)
Liked: 521
Focal makes some really really good speakers; nice sound quality!
You might want to check out some of the past reviews on them at the Stereophile website, or look up some Focal speaker reviews onllne.
post #7 of 31 Old 03-16-2014, 09:53 AM
craig john's Avatar
Quoted: 513 Post(s)
Liked: 718
If you're building a false wall, use an acoustically transparent, (AT), screen and place the CC behind it. Then you don't need to use a "center" speaker; you can use a 3rd speaker identical to the L/R's. This will provide the best opportunity for a proper timbre-match across the front soundstage.
The woven AT screens have excellent acoustic transparency and don't require any EQ.
Agreed that Focal makes excellent speakers, especially their beryllium tweeters.
Craig
Lombardi said it:
Perfection is not attainable, but if we chase perfection we can catch excellence."
My System
craig john is offline
post #8 of 31 Old 03-16-2014, 09:57 AM - Thread Starter
Quoted: 12 Post(s)
Liked: 49
That's all I've been doing lately ha. Pretty sure I'm gonna go with them, just gotta figure out which line.
post #9 of 31 Old 03-16-2014, 10:00 AM - Thread Starter
Quoted: 12 Post(s)
Liked: 49
Craig
This is exactly what I'm doing but I can't seem to find 3 identical speakers that aren't towers. Or if I find towers I like they only come in pairs. I'd love to have all 3 up front be the same but it might not happen
post #10 of 31 Old 03-16-2014, 10:17 AM
cel4145's Avatar
Quoted: 2654 Post(s)
Liked: 2985
Look into the Ascend Acoustics CMT-340 SEs. They will sell you a third individually.
Living room HT: Energy RC-50, Ascend Sierra Horizon w/RAAL, Ascend Sierra 1, PSB Imagine XA | PSA V1500 and CHT SS 18.1 | Denon X4200W | modified Dayton SA1000
Other rooms: CBM-170 SE | SVS SB-1000 | Audio-GD NFB-11 | Parasound Zamp | JBL LSR305
Headphone & Portable AKG K7XX | NAD HP50 | AKG K550 | Soundmagic E50 & E80 | DX50 | E12 | X1
cel4145 is offline
post #11 of 31 Old 03-16-2014, 11:16 AM - Thread Starter
Quoted: 12 Post(s)
Liked: 49
I've looked at those as well, for some reason they don't jump off the page for me. I think I'd be ok with a pretty good center that costs more than my cheap Polk cs10
post #12 of 31 Old 03-16-2014, 01:43 PM
cel4145's Avatar
Liked: 2985
Yeah, well, they are not being sold for aesthetics, which shouldn't matter if going behind a screen. Try reading this review: http://www.avsforum.com/t/1478626/ascend-acoustic-5-1-setup-review
And no. Most center would be a poor choice as they are designed for horizontal placement, not vertical. Bad choice just go with any of them, IMO, because the sound disbursement will be wrong. You could look for LCR speakers which are designed for vertical or center placement. Or find speakers that are sold as each.
cel4145 is offline
post #13 of 31 Old 03-16-2014, 03:08 PM - Thread Starter
Quoted: 12 Post(s)
Liked: 49
I didn't mean they weren't jumping off the page for me visually. Just more in general but I really haven't spent a lot of time researching them. I'm leaning towards Focal but I'm still keeping my options open.
post #14 of 31 Old 03-16-2014, 03:18 PM
rick240's Avatar
Quoted: 18 Post(s)
Liked: 52
Look into the Funk Audio 6.1, since Nathan custom builds these he would likely sell you 3.
Since you have an AT, 3 identical is definitely the way to go.
rick240 is offline
post #15 of 31 Old 03-16-2014, 03:23 PM - Thread Starter
Quoted: 12 Post(s)
Liked: 49
Thank you I'll check those out
post #16 of 31 Old 03-16-2014, 09:38 PM
sdg4vfx's Avatar
Quoted: 81 Post(s)
Liked: 140
...Ideally I would like 3 bookshelf speakers across the front but most are offered in pairs so that's why I thought of going with 3 centers. I haven't noticed anyone doing this so that must be for a reason smile.gif
... but I can't seem to find 3 identical speakers that aren't towers. ... I'd love to have all 3 up front be the same but it might not happen
If you call a dealer (or manufacturer) directly you can sometimes snag a single. I've done this successfully a few times.
+ 1 getting three identical speakers LCR across the front. Since it's often easier to buy 2 pair instead of 3 individual there are some options re the left-over 4th speaker - keep it as a backup, use it as a music monitor in another room, use it as a single "rear surround" speaker in a 6.1 setup (I did that for a while and it sounded great).
The Focal Chorus 800 series are very nice speakers, but if you're open to other speakers where getting a 3rd is easier ...
- +1 the Ascend CMT-340's mentioned earlier
- Ascend Sierra 1's (they currently have some B-stock to save $, the center is identical to the LR mains except for the rotated tweeter - just ask them to "un" rotate it back)
- Arx A1rx-c (will sell a single if you call, slightly less expensive but still good)
- Arx A2rx-c Center (same tweeter note as the Ascends, these speakers are designed to be used both vertically and horizontally)
- KEF Q200c or Q600c (a center that works both vertically and horizontally)
- JBL Studio 530 (JBL will sell singles if you call)
Sure there are others that just aren't coming to mind at the moment wink.gif
sdg4vfx is offline
post #17 of 31 Old 03-17-2014, 04:34 AM - Thread Starter
Quoted: 12 Post(s)
Liked: 49
I've looked at all of those except the KEF you mentioned.  I can get the JBL for $250 ea on Amazon but you say JBL will send me a single?  It was on my list to do today to e-mail them and ask if this were possible.  I've heard many good things about them but have never heard anything by JBL.  Thanks for the response, it's appreciated.
post #18 of 31 Old 03-17-2014, 06:14 AM
rick240's Avatar
Quoted: 18 Post(s)
Liked: 52
You could also do what I did...
...convince a friend to do the same thing and split a pair to each get a centre (in our case it was KEF iQ3).
rick240 is offline
post #19 of 31 Old 03-17-2014, 06:44 AM - Thread Starter
Quoted: 12 Post(s)
Liked: 49
That's a good idea but I don't have anyone who'd want to do that. You in need of another iQ3? smile.gif
post #20 of 31 Old 03-17-2014, 06:59 AM
rick240's Avatar
Quoted: 18 Post(s)
Liked: 52
You could always buy 3 pairs of something, have the ultimate matching 5.0 and a spare in case something blows down the road...
rick240 is offline
post #21 of 31 Old 03-17-2014, 07:09 AM
cel4145's Avatar
Liked: 2985
Another to add to that list. The Definitive Technology Studio Monitor series are also sold as each.
cel4145 is offline
post #22 of 31 Old 03-17-2014, 07:23 AM
arnyk's Avatar
Quoted: 851 Post(s)
Liked: 1238
I have done exactly what the thread title suggests with what I find to be excellent results, but I wouldn't do what you seem to be thinking of doing.
As a rule speakers are designed to have a preferred orientation and it is the rare speaker that works well in more than one orientation. Most of those have carefully controlled directivity and incorporate waveguides (horns).
This is I believe, a picture of the speaker that you propose to use in the wrong orientation:
This is what it would look like were it designed to be used vertically:
Or
The technical issues are covered by these aritcles:
http://www.audioholics.com/loudspeaker-design/vertical-vs-horizontal-speaker-designs
http://www.audioholics.com/loudspeaker-design/center-channel-designs
Rather than rewrite the Torah, I recommend reading them. Amy questions - put them into this thread and I will try to monitor it.
The speakers I used this way were Infinity PC351s but I used them oriented horizontally.
arnyk is offline
post #23 of 31 Old 03-17-2014, 07:34 AM - Thread Starter
Quoted: 12 Post(s)
Liked: 49
I missed these in my research, thanks for the suggestion.
post #24 of 31 Old 03-17-2014, 07:40 AM - Thread Starter
Quoted: 12 Post(s)
Liked: 49
Or
Good information, thanks. I am not considering doing this and never truly felt it would be better than 3 "main" speakers but was curious if anyone has done it and wanted to get a take on it all. Would 3 JBL studio 530 monitors fill a 2500 cu ft room nicely? Can't seem to find anything negative about these speakers.
post #25 of 31 Old 03-17-2014, 07:45 AM
arnyk's Avatar
Quoted: 851 Post(s)
Liked: 1238
Or
Good information, thanks. I am not considering doing this and never truly felt it would be better than 3 "main" speakers but was curious if anyone has done it and wanted to get a take on it all. Would 3 JBL studio monitors fill a 2500 cu ft room nicely? Can't seem to find anything negative about these speakers.
I believe that Primus 363s are preferable even though they are probably made in the same factories and may even include some of the same drivers. I'd definitely use 2 Primus P363s and a PC 351 in a room that size with a good subwoofer.
arnyk is offline
post #26 of 31 Old 03-17-2014, 08:27 AM - Thread Starter
Quoted: 12 Post(s)
Liked: 49
I already have 2 SVS PB-2000 subs with a potential third so I know the low end is covered. Guess I'll just have to listen to speakers but ugh auditioning many different ones is a pain. Wish this was as easy as picking my subs ha
post #27 of 31 Old 03-17-2014, 08:43 AM
cel4145's Avatar
Liked: 2985
I think the Ascends, Focals, Def Techs, and Kefs would all be a significant upgrade over your Polk CS10 (are your mains Polk Monitors?). I would imagine that you would probably be safe with buying without trying smile.gif
cel4145 is offline
post #28 of 31 Old 03-17-2014, 09:03 AM - Thread Starter
Quoted: 12 Post(s)
Liked: 49
Ha yes I believe you're right. I sold my polks but they were monitor 75 towers. Just way too cheap for the rest of my equipment and I want to try a different sound.
post #29 of 31 Old 03-17-2014, 10:38 AM - Thread Starter
Quoted: 12 Post(s)
Liked: 49
So I'm sick of looking at countless speakers without listening to anything. I've narrowed it down to the Ascend CMTs or Chane A2rx. They are pretty close in price and quality so it'll come down to which one has the better sound to my ears.
post #30 of 31 Old 03-17-2014, 02:22 PM
charmerci's Avatar
Quoted: 310 Post(s)
Liked: 195
There's a guy selling 3 of them for $600 + shipping here.
http://www.audiocircle.com/index.php?topic=123993.0
However, you can't send a PM on the AC site until you have 2 posts and the first one takes many hours to be posted until they can monitor the post.
charmerci is offline
Reply Speakers
