5.1 speaker purchase advice - AVS Forum | Home Theater Discussions And Reviews
post #1 of 31 Old 03-17-2014, 12:55 PM - Thread Starter
MikeRoz's Avatar
My current speakers include this Sony speaker pair as a floorstanding front pair, as well as the center and rear satellite speakers from a Klipsch 5.1 Ultra set for which the amp has long since died. My setup is in a room that's approximately 10ft by 10ft.
Can anyone recommend a good 5.1 set for me? Or would it be better to add a subwoofer to my setup and call it done? Something like this Klipsch set (RF-42 II) would probably be the extreme top end of my budget. Worth the upgrade?
My usage will be primarily television, with film, music, and maybe some gaming.
Thanks in advance for your help.
EDIT: Sorry! Link syntax fixed now.
MikeRoz is offline
post #2 of 31 Old 03-17-2014, 01:10 PM
crazyrob425's Avatar
Quoted: 443 Post(s)
Liked: 337
Budget?
Do you have any issues with your current setup?
What is the receiver that you are using currently?
crazyrob425 is offline
post #3 of 31 Old 03-17-2014, 04:05 PM - Thread Starter
MikeRoz's Avatar
Like I said, the very top end of my budget would probably be something around $1700, like the Klipsch set I linked. I'd rather it be less than that. It never seems like I can find anything between a $100 set that includes tiny satellites and a small sub, and something for $1700+ like those Klipsch speakers. I also don't know whether anything less expensive would even constitute an upgrade from what I have, hence I'm asking.
I don't have any issues with my current setup, aside from the fact that it's not currently installed - need longer speaker wire, need to run the wire somehow, and need to either mount the speakers or purchase stands. The satellites from the Promedia Ultra set are kind of old, and they've been knocked around in moves from my college days, but they still work and sound decent.
My current receiver is a Yamaha HTR-7065 - sorry, I meant to include that information.
MikeRoz is offline
post #4 of 31 Old 03-17-2014, 05:06 PM
cel4145's Avatar
Quoted: 2657 Post(s)
Liked: 2987
Yes. You can greatly improve over the Sonys.
In a 10 by 10, I'd say go for good bookshelves and trust a really good sub to handle the bass. smile.gif
Ascend Acoustic CBM-170 SE for front left/right, CMT 340 SE center, and either another pair of CBM-170 SE or the HTM 200 SE for the rear. Then get a good sub from SVS Sound, Power Sound Audio, HSU Research, Rythmik Audio, or Outlaw Audio. Those are Internet direct manufacturers that provide amazing price/performance values for subs.
Living room HT: Energy RC-50, Ascend Sierra Horizon w/RAAL, Ascend Sierra 1, PSB Imagine XA | PSA V1500 and CHT SS 18.1 | Denon X4200W | modified Dayton SA1000
Other rooms: CBM-170 SE | SVS SB-1000 | Audio-GD NFB-11 | Parasound Zamp | JBL LSR305
Headphone & Portable AKG K7XX | NAD HP50 | AKG K550 | Soundmagic E50 & E80 | DX50 | E12 | X1
cel4145 is offline
post #5 of 31 Old 03-17-2014, 05:33 PM
Quoted: 443 Post(s)
Liked: 337
x2
post #6 of 31 Old 03-17-2014, 06:21 PM
darkpoet25's Avatar
Liked: 40
A couple of other Ascend options would be, if the space provided of course would be three vertical 170's with a pair of 200's for surrounds and an SVS PB-1000. The other being a set of five 200's for the L/C/R and surrounds and a Rythmik LV-12R for the sub. Then there is HTD Level 2 and 3's.
Cliff
darkpoet25 is offline
post #7 of 31 Old 03-17-2014, 07:30 PM
zieglj01's Avatar
Quoted: 938 Post(s)
Liked: 846
The SVS PB-1000 will easily handle a 10 x 10 room.
__________________________________________
Who AM I
Speakers > Snell K7, EOS 150SP
Receiver > Tascam PAR-200
zieglj01 is online now
post #8 of 31 Old 04-08-2014, 08:14 PM - Thread Starter
MikeRoz's Avatar
Sorry for the long period of dormancy.
So, my main problem at this point is center satellite depth. My television is mounted over my fireplace. The mantle is only 8 inches deep. This means the old center from my ProMedia Ultras looks right at home at 4 3/4" deep, the CMT 340 SE and RC-42 II are way too big, and the C-20 narrowly fits.
I was tempted to give up and put off a speaker upgrade until a later year. My ProMedia center fits fine, so then I just need to buy speaker stands for the rear ProMedia satellites. Except the satellites have a mounting screw at the bottom rear for the little included 2" stands. All the stands I can find require either a center-bottom or rear mount. So I am back where I started.
I'm now considering, from the Klipsch Synergy line:
F-30s for FL FR
C-20 or C-10 for C
S-20 for SR SL
SW-110 for LFE
I did a search for the Synergy line here, and found they're not very well-regarded. Some suggested alternatives like the Pioneer SP-FS52-LR, but the matching Center satellite is about an inch too deep.
Any thoughts? I'm most constrained by center size here, unless I was to start mixing and matching product lines. I'm not sure if that's a good idea.
MikeRoz is offline
post #9 of 31 Old 04-08-2014, 08:43 PM
JustABrah's Avatar
Quoted: 99 Post(s)
Liked: 78
If I was you I'd buy the Sierra-1s LCR and a Rythmik LV12R that comes in at $1827 plus shipping, you can buy the HTM-200 for rears later and save extra with B stock, if that price is a bit much you can save by buying the Sierra-1s as B stick which should knock it down a little more. This gives you the option later to upgrade to the Sierra-2s when you got extra cash. If you buy the Rythmik sub from Ascend with your speakers you get a bit of a discount as well when you buy the LCR as a speaker package. IMHO this is by far the best option as having that option to upgrade to the Sierra-2s later, say a year or two makes this much better than anything you can buy in this price range or even much more than this price point.
Sierra-2 LCR
HTM-200 rears
Rythmik E15HP
Anthem MRX-300
Samsung 8550 UHD
-$8500ish : (
JustABrah is offline
post #10 of 31 Old 04-08-2014, 08:55 PM - Thread Starter
MikeRoz's Avatar
Sierra-1 is 10" deep - please read the post above yours.
MikeRoz is offline
post #11 of 31 Old 04-08-2014, 09:14 PM
smithhayward's Avatar
My Polk CSi3 center speaker is overall 9-1/4" deep, but the cabinet is exactly 8".  If you wire it such that the rear of the speaker is flush with the wall then the only overhang would be the speaker grille.  My two cents... (short of recommending a slim Bose center channel).
smithhayward is offline
post #12 of 31 Old 04-08-2014, 09:36 PM
JustABrah's Avatar
Quoted: 99 Post(s)
Liked: 78
I've tried the HTM-200 from ascend upfront and they did a solid job and they'd fit you could run with 5 of those and go with the LV12R sub or even move up to a F15 with the money you're saving... I use the HTM-200 as my rears and there a great speaker, I believed there compared to the Paradigm studio series for performance wise, although I've never ab the two speakers I've heard the Studios a lot and I would believe that their on the same playing field. Good luck, that's the only speaker I've heard that would fit for you.
MikeRoz likes this.
Sierra-2 LCR
HTM-200 rears
Rythmik E15HP
Anthem MRX-300
Samsung 8550 UHD
-$8500ish : (
post #13 of 31 Old 04-08-2014, 09:38 PM - Thread Starter
MikeRoz's Avatar
I just noticed that the HTM-200 is only about 6" deep. What if I went with:
Ascend HTM-200 SE center
Ascend CMT-340 SE mains
Klipsch SW-110 LFE
For the rear, I'm undecided whether I want something smaller like the Klipsch Synergy S-20 or a pair of HTM-200s. I don't really want gigantic rear satellites, especially if I have to mount them to the wall. Can anyone recommend stands or mounts that would be suitable for these speakers? If I go with stands, I'm hoping to tuck the bases of the stands underneath my couch.
EDIT: Just saw your reply, JustABrah. I'm hesitant to get a 300W sub - living in a condo, I will never, ever have the opportunity to really let that play at full blast without getting all the neighbors and the housing association mad at me. I'm not a 'bassophile' by any means.
MikeRoz is offline
post #14 of 31 Old 04-08-2014, 09:42 PM
JustABrah's Avatar
Quoted: 99 Post(s)
Liked: 78
I would go with a better sub, go with SVS, HSU or Rythmik for your sub you'll be getting a MUCH better sub, if you end up with the Ascends you'd get a discount on the Rythmik sub if you buy it from them and you get another discount with speaker packages.
Sierra-2 LCR
HTM-200 rears
Rythmik E15HP
Anthem MRX-300
Samsung 8550 UHD
-$8500ish : (
post #15 of 31 Old 04-08-2014, 09:45 PM - Thread Starter
MikeRoz's Avatar
I'm concerned that Ascend's cheapest model might be too much sub for my condo. Don't want the neighbors/housing association coming after me.
MikeRoz is offline
post #16 of 31 Old 04-08-2014, 10:02 PM
cel4145's Avatar
Liked: 2987
I have the CBM-170 SEs. The Ascends are nice speakers for the money. If your room is small and you aren't planning on driving it really loud, you could go with the CBM-170s for front left/right.
You can always turn the sub down. For the money, check out the SVS SB-1000. It's a compact 12" sealed sub. Probably won't have any more output than the Klipsch (if that much), but definitely will sound better. And it's not going to fill a big room with bass.
MikeRoz likes this.
cel4145 is offline
post #17 of 31 Old 04-08-2014, 10:08 PM - Thread Starter
MikeRoz's Avatar
They certainly get excellent reviews, but I'm a bit put off of doing that because they're smaller than the SS-B3000 pair I currently use. Saving nearly $300 would certainly be nice though.
What stands would you recommend for the front CBS-170 pair and the rear HTM-200 pair?
EDIT: And thanks for the advice on the SB-1000, I may end up getting that. Klipsch can't seem to get any love in this thread :p
MikeRoz is offline
post #18 of 31 Old 04-08-2014, 11:12 PM
JustABrah's Avatar
Quoted: 99 Post(s)
Liked: 78
Go for the Rythmik F12 then, you'll get extra savings with Ascend when buying Rythmik sub from them with your speakers and they'll help you with setup or any problems and since it's their speakers and sub they would know best. I have the PB-1000 and its a solid sub for the money but it lacks the bass that hits you in the chest or going lower then 20Hz, since your looking for a good movie system you really should get a great sub as its a very important part of a good HT system, I'd go for the F15 or the LV12R and you'll have head room which is always a good thing to keep the sub playing its best, the SB-1000 won't be a good sub for movies, for music sure but it'll lack the output for a great movie performance.
If you run 5 HTM-200 you can wall mount them and clear the floor space.
Sierra-2 LCR
HTM-200 rears
Rythmik E15HP
Anthem MRX-300
Samsung 8550 UHD
-$8500ish : (
post #19 of 31 Old 04-08-2014, 11:24 PM
JustABrah's Avatar
Quoted: 99 Post(s)
Liked: 78
Also, if you go with the HTM-200 since their smaller speakers, which you need to fit, you'll need a sub to play cleanly and good up to 100Hz, so a very good sub is going to be important for you, honestly I'd go with a sub like the F15 or better as a sub is going to be very important and since it'll be taking over all the bass below 100Hz, which will include male voices, like Banes.
Sierra-2 LCR
HTM-200 rears
Rythmik E15HP
Anthem MRX-300
Samsung 8550 UHD
-$8500ish : (
post #20 of 31 Old 04-08-2014, 11:42 PM - Thread Starter
MikeRoz's Avatar
The product page for the HTM-200 says the frequency response is linear all the way down to 70 Hz. Both the SB-1000 and the LV12R are linear to well over 100 Hz. I would imagine that a HTM-200 system would be fine with either an SB-1000 or an LV12R, and either would certainly be a massive improvement over my current 5.0 system.
I'm not sure I'll have room on the wall to mount the speakers on either side of my new TV. I estimate I'll have about 9" on either side, and the -200 is 6.5" wide. Don't want to make the wall look too crowded.
MikeRoz is offline
post #21 of 31 Old 04-08-2014, 11:42 PM
cel4145's Avatar
Liked: 2987
I don't know what stands to get, but the CBM-170 SEs are better speakers than the Sonys in terms of sound quality. The SB-1000 (or different sub) will make up for the slightly lower output (if any) that the Sonys have.
The other reason I suggested them is that for the difference in price, you could get a pair of HTM-200s for surrounds. I think Ascend might give you a price break if you buy five speakers.
However, I do agree that the LV12R is a better sub for movies than the SB-1000. How big is the room this setup will go in? And does the room have a connecting wall with another condo?
cel4145 is offline
post #22 of 31 Old 04-08-2014, 11:46 PM - Thread Starter
MikeRoz's Avatar
Yes, I do have a connecting wall, but it is the opposite wall from where the sub will be. The wall near the sub joins to another room in my unit.
Room is about 10' by 10', but it's not walled in on all sides. Keep going south and you'll be in my kitchen, go further and you'll be in my dining room, no walls or doors in between.
I am leaning toward the HTM-200s for surrounds as they currently seem the better deal, and I'm sure the setup will benefit from the uniformity if the rest of the system is all Ascend.
MikeRoz is offline
post #23 of 31 Old 04-08-2014, 11:56 PM
JustABrah's Avatar
Quoted: 99 Post(s)
Liked: 78
ARC set my HTM-200 at 100Hz and my Sierra-2s to 60Hz, and it does a great job at knowing where to set the crossover. I personally for a HT system would go with a better sub than the SB-1000 but that's up to you to decide, with a 100Hz your asking a lot of performance from the sub and will make it an important piece for your setup.
Sierra-2 LCR
HTM-200 rears
Rythmik E15HP
Anthem MRX-300
Samsung 8550 UHD
-$8500ish : (
post #24 of 31 Old 04-09-2014, 12:40 AM
cel4145's Avatar
Liked: 2987
The bass will go through the opposite wall no problem if you have it turned up loud enough.
The SB-1000 may not be enough sub for that space. However, SVS has a 45 day in home demo, free shipping both ways. So you could try it. If you feel you need more sub, return it for the PB-1000. Or get the LV12R from Rythmik.
cel4145 is offline
post #25 of 31 Old 04-09-2014, 01:01 AM
JustABrah's Avatar
Quoted: 99 Post(s)
Liked: 78
Also to the op you know you could place a center speaker above your TV pointing down towards the seating area, if that works better with giving you more depth? Like this
Sierra-2 LCR
HTM-200 rears
Rythmik E15HP
Anthem MRX-300
Samsung 8550 UHD
-$8500ish : (
post #26 of 31 Old 04-09-2014, 01:17 AM - Thread Starter
MikeRoz's Avatar
TV is mounted above a fireplace - mounting it above the TV would practically be ceiling-mounting it. Plus there's currently an air vent there - working on that though.
MikeRoz is offline
post #27 of 31 Old 04-09-2014, 01:10 PM - Thread Starter
MikeRoz's Avatar
I think I may go the all-HTM-200 route and do what this guy did to mount his speakers. Anyone anticipate any issues if I mount them upside-down?
MikeRoz is offline
post #28 of 31 Old 04-09-2014, 01:33 PM
JustABrah's Avatar
Quoted: 99 Post(s)
Liked: 78
That's how I have mine mounted and no issues at all, works great.
Sierra-2 LCR
HTM-200 rears
Rythmik E15HP
Anthem MRX-300
Samsung 8550 UHD
-$8500ish : (
post #29 of 31 Old 04-09-2014, 01:38 PM
Quoted: 443 Post(s)
Liked: 337
Klipsch SW-110 LFE
Not a bad set-up EXCEPT for the subwoofer.
Klipsch isn't know for their subwoofers. I strongly suggest you get a subwoofer from an internet direct company like SVS Sound, Rythmik, HSU, or Outlaw Audio. You will be getting a better subwoofer for you money.
post #30 of 31 Old 04-09-2014, 01:45 PM - Thread Starter
MikeRoz's Avatar
I've been brought around to that opinion. Looking at either a SB-1000 or an LV12R now. And HTM-200s all around L/R/C/SR/SL.
MikeRoz is offline
Reply Speakers
