Add two patio speakers to one amplifier. - AVS Forum | Home Theater Discussions And Reviews
Old 03-18-2014, 12:32 PM - Thread Starter
rcalzadilla's Avatar
I need t install two pation speakers at 4ohms and two living room speakers at 8ohms .
Will be using the amplifier's two speaker "Stereo" outputs and switch between A/B speaker pairs. Would also like to power A+B speakers at the same time.
Amplifier rated for 8ohms 100W + 100W.
I think I'm facing the following options:
ONE- Buy a speaker selector switch with Inpendance protection, which are kind of expensive.
Or
TWO- Buy two 8ohms patio speakers and use a basic, unprotected selector switch.
Which is the correct option?
My Amplifier:
Sony Multi channel AV Receiver Model STR-DH800
rcalzadilla is offline
Old 03-18-2014, 01:41 PM
crazyrob425's Avatar
Quoted: 443 Post(s)
Liked: 337
Why you looking at 4 ohm out door speaker? They sell plenty of 8ohm outdoor speakers. Get a pair of those for outside and use 8 ohm speakers inside
You will be able to run a pair outside and inside to play the same music by selecting SP A+B pg33 of manual (https://docs.sony.com/release/STRDH800_US.pdf)
crazyrob425 is offline
