Surrounds too subtle? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 03-18-2014, 04:31 PM - Thread Starter
Tony Wilkins 99's Avatar
Quoted: 14 Post(s)
I know that surround sound for HT is not supposed to be too obvious but I'm afraid that our surrounds are just too subtle.  Right now we are running 5.1 driven off our Denon 5420CI.  The fronts and center are Kilpsch Reference bookshelf speakers about 10 years old (RSX4/RCX4 IIRC); the surrounds are Niles ICS 7 inch in ceilings (a choice driven by the open concept design of the space.)  There doesn't seem to be much surround at all as just about everything seems to be coming from the front soundstage (which sounds very good).
I'm concerned that the surrounds will suffer even more when my new speakers arrive - Philharmonic 3's for the front L/R and a Philharmonitor used as a center.
FWIW, the in-ceiling surrounds are about a foot behind and a foot to either side of the main listening position.  I'm not sure if this is 'curable' with adjusting the levels to the rears or if it's indicative of the surrounds being 'over-matched' (which will only get worse with he new speakers).
Tony Wilkins 99 is offline
post #2 of 7 Old 03-18-2014, 05:17 PM
Terry Newton's Avatar
An SPL meter might be helpful in your situation.I have a calibrated,MCACC, system but I also did an SPL calibration in another optional audio setting.I brought my surrounds up a little to where I like it.I find I use the calibrated setting more often but every once in a while I switch to my SPL setting.I am continually thinking my surrounds are to low,until I stand up.
Terry Newton is offline
post #3 of 7 Old 03-18-2014, 05:22 PM
Elihawk's Avatar
Quoted: 1019 Post(s)
Liked: 868
Not sure if that reciever has room correction software, but when I ran audiossey with my denon 1613, it really boosted my surround output.
Set up #1: EMP e5ti, e5Ci, and EMP e5Bi surrounds, Outlaw LFM1 Plus sub, EMP 10i10i sub
Set up #2: Def Tech SM450, CLR2002, SLS Qline surrounds and Klipsch 12wD sub
Set up #3: Philharmonics- BMR in a 2.0 system, music only
Elihawk is online now
post #4 of 7 Old 03-18-2014, 06:56 PM
zieglj01's Avatar
Quoted: 941 Post(s)
Liked: 846
Sometimes it depends on the source being played
Also, making sure the receiver is set to the proper surround format
Also the Klipsch is more sensitive, and will play louder with less watts
Check the volume level, and bring the surround level up higher, to match
the front level with test tones - even if you do it by ear to begin with.
__________________________________________
Who AM I
Speakers > Snell K7, EOS 150SP
Receiver > Tascam PAR-200
zieglj01 is online now
post #5 of 7 Old 03-18-2014, 07:30 PM - Thread Starter
Quoted: 14 Post(s)
Hadn't thought about the sensitivity so that makes sound.  The AVR is set correctly.  It does have AudessyXT32 but the cord wasn't long enough from where the AV closet is to where the main position is.  I'll check the volume level and see how that works out.
post #6 of 7 Old 03-19-2014, 11:23 AM
Jack D Ripper's Avatar
Liked: 272
I recommend you get an extension cord for your calibration microphone and use it.  It should be fairly cheap.
God willing, we will prevail in peace and freedom from fear and in true health through the purity and essence of our natural fluids. God bless you all.
Jack D Ripper is offline
post #7 of 7 Old 03-19-2014, 11:29 AM
PM-Performance's Avatar
Quoted: 246 Post(s)
Liked: 142
Deff play with the levels either with Audessey or by ear of SPL meter. You want to be immersed by the surrounds. Not the the point where they make no affect or overbearing.
Klipsch RF-82|RC-62|RS-52|RB-51, 2 Ultimax 18's in Marty Cabs Powered by Inuke 6000DSP|
Denon AVR-X4000|Oppo BDP-103|Epson 5020UB with Elite SableFrame 110"|
4 Aura Bass Shakers powered by Dayton PSA-250|4 Seatcraft 5131 seats
PM-Performance is offline
Reply Speakers
