3.0 Setup for Apartment - Ascend CMT-340 (L/R/C) or Chane Arx A3rx + A2rx? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 30 Old 03-21-2014, 01:46 PM - Thread Starter
Mysteriouskk's Avatar
Quoted: 28 Post(s)
I'm looking for something mainly for TV and movies and don't need a lot of bass. Which setup should I go with?
Mysteriouskk is offline
post #2 of 30 Old 03-21-2014, 08:23 PM
charmerci's Avatar
Quoted: 315 Post(s)
Liked: 201
Based on many people's opinions on these....either one.
Fairly similar quality - obviously, not sounding exactly the same. You chose.
charmerci is offline
post #3 of 30 Old 03-21-2014, 08:34 PM
charmerci's Avatar
Quoted: 315 Post(s)
Liked: 201
Plus - here's a list of the threads here (use the search function top right of page) if you want more details.
http://www.avsforum.com/newsearch/?search=arx+ascend&output=all&containingforum%5B0%5D=89&type=all&advanced=1
post #4 of 30 Old 03-21-2014, 09:29 PM
tommyncal's Avatar
This is exactly what I'm trying to decide. I've been trying to get some advice on how close the rear of the CMT-340 or A2rx speakers can be from the rear wall. I have a media console, where I want to place the speakers, with the front edge 20.5" from rear wall. That would put the rear of the 340's about 10" away. If that is not good, then I would probably go with the A3rx or stands for the 340's. Another question I had is the A3rx just a A2rx made into a tower?
tommyncal is offline
post #5 of 30 Old 03-21-2014, 10:25 PM
charmerci's Avatar
Quoted: 315 Post(s)
Liked: 201
A2rx made into a A3rx - yup, they use all the same drivers.
Whether 10" is far away enough would be for you to decide. It's a pretty good distance for a rear ported speaker. (I pull mine further out when I crank them up to reduce a bit of bass boominess. But most of the time, they're fine closer to the wall for me.) The A3rx comes with port plugs - but you have to ask them for them when you order.
post #6 of 30 Old 03-21-2014, 10:55 PM
tommyncal's Avatar
If I got the A3rx, being towers, I could have them 24" from the wall. But I think I'd like the bookshelf speakers sitting on the cabinet. But that seems to be frowned upon around here.
post #7 of 30 Old 03-21-2014, 11:03 PM
charmerci's Avatar
Quoted: 315 Post(s)
Liked: 201
On top of a cabinet or in the cubby hole of a cabinet. The second one isn't best for sound but it you pull it out an inch of the front, that should reduce the side reflections.
If you're looking for the best sound, the towers will be a better option.
post #8 of 30 Old 03-21-2014, 11:36 PM
tommyncal's Avatar
I have no cubby, just a straight solid wall. The cabinet is 8 feet long and the speakers would sit, 8 feet apart, in front of the TV by about 8" to 10", or more if I mount the TV on the wall. Also, not sure why the towers, in this case the A3rx's, would give better sound? Aren't they the same speaker as the A2rx, just on a permanent stand?
post #9 of 30 Old 03-22-2014, 08:26 AM
shadyJ's Avatar
Quoted: 1330 Post(s)
Liked: 1351
For a 3.0 system, this is a no-brainer, go for the Arx towers. They are full range speakers, the CMT-340s are not. They will sound a lot more authoritative.I would try to step up to the A5 towers too. If subs were involved, no doubt it would be a much more difficult decision.
shadyJ is offline
post #10 of 30 Old 03-22-2014, 09:32 AM
tommyncal's Avatar
In my case, not sure about the OP and don't want to hijack his thread, but I am planning on getting a sub down the road in about 9 months. Trying to understand this, why are the Arx A3rx towers full range speakers and the 340's not? It seems the A3rx are the same as the A2rx.
post #11 of 30 Old 03-22-2014, 11:13 AM
shadyJ's Avatar
Liked: 1351
Nevermind what I said. Looking at them closer, it seems the CMT could actually be tuned lower than the Arx A3s. The Arx look to have a relatively high tuning point for tower speakers, in other words they don't look like they have as much bass as you would expect. I would have expected a speaker of that size to at least reach 40 Hz. I would skip them both and look for a tower speaker that has better bass extension. Klipsch speakers tend to have punchy bass and relatively deep tuning for towers. You might look at some RF-600s or RF-82s. Polk Rti A8s and A9s have pretty good bass for towers, and the prices can be talked down on those.
shadyJ is offline
post #12 of 30 Old 03-22-2014, 11:29 AM
shadyJ's Avatar
Liked: 1351
Bookshelf speakers like the CMT340s do not normally try for frequencies under 50 Hz, and most don't even go that low with authority. They are usually intended to be used with a subwoofer. Tower speakers normally try to dig lower, to nearly cover most of the bass spectrum, by using the larger size of their enclosure for a lower tuning point more. Looking at the +/- 3 dB and -6 dB point on the Arx A3s, they don't look like they have a whole lot of bass extension, in fact it is the same as the Arx A2 speakers, which is strange.
shadyJ is offline
post #13 of 30 Old 03-22-2014, 11:32 AM
zieglj01's Avatar
Quoted: 1425 Post(s)
Liked: 1263
For some info, and looks to be a nice option - check the MB Quart Alexxa towers on
close-out pricing, 370 each with shipping ($295 + $75), and they are front ported.
http://shop.mbquart.com/p/as-s1cpb-single?pp=24
If you prefer to buy from Amazon, they are $977.19 each.
http://www.amazon.com/Alexxa-Floorstanding-Speaker-Discontinued-Manufacturer/dp/B000R6YUJE/ref=sr_1_2?ie=UTF8&qid=1395513185&sr=8-2&keywords=mb+quart+alexxa
Alexxa bookshelf (front ported), is $470 pair with shipping ($395 + $75).
http://shop.mbquart.com/p/as-b1pb-pair?pp=24
Also, priced higher at Amazon.
__________________________________________
Who AM I
Speakers -- Snell K7 > Digital Phase AP-.5 > Harman Kardon Ten > Boston VS240 -- Receiver > Integra 50.2
zieglj01 is online now
post #14 of 30 Old 03-22-2014, 01:24 PM - Thread Starter
Quoted: 28 Post(s)
Are there reviews for the towers?
post #15 of 30 Old 03-22-2014, 02:35 PM
zieglj01's Avatar
Liked: 1263
No so-called USA pro reviews - however, people tend to place/rate them with the higher level
type sound signatures.
http://www.audioasylum.com/audio/speakers/messages/28/286262.html
This is a nice one on the Alexxa bookshelf speakers.
I own the higher-end MB Quart Vera VSO5B bookshelf speakers > and they are some serious
good sounding speakers - clean, refined and transparent, with real good detail, definition and
depth, for both music and home theater with good on-axis and off-axis response >> and they
are dynamic sounding.
Who AM I
post #16 of 30 Old 03-22-2014, 03:19 PM
tdogroeder's Avatar
Quoted: 45 Post(s)
Liked: 84
Based on that review makes me want to order them, I might just have to.
John 14:6 & John 3:16
Yamaha RXV765 & Emotiva LPA-1
Ascend Sierra-2s(LCR), RSS300, Polk R15, SVS PB12 plus
Panasonic S65, Sony S5100, PS4, PS3, XBOX 360
tdogroeder is online now
post #17 of 30 Old 03-22-2014, 03:27 PM
zieglj01's Avatar
Liked: 1263
You are starting to come around!
Who AM I
post #18 of 30 Old 03-22-2014, 04:26 PM
tommyncal's Avatar
Why doesn't the Alexxa line have a center channel? What would you use for a center?
post #19 of 30 Old 03-22-2014, 05:10 PM
tdogroeder's Avatar
Quoted: 45 Post(s)
Liked: 84
I got to audition MA Silver S 2's & Paradigm Studio 20's today and I prefered the MA's much more as they were more pleasant to my ears. I think they were more accurate, paradigms were brighter and more expensive and not worth the price difference imo.
post #20 of 30 Old 03-22-2014, 05:12 PM
tdogroeder's Avatar
Quoted: 45 Post(s)
Liked: 84
They use to they must have sold out of them, it's called the Alexxa C-One
http://www.manualslib.com/manual/293127/Mb-Quart-Alexxa-C-One.html
post #21 of 30 Old 03-22-2014, 05:17 PM
zieglj01's Avatar
Liked: 1263
The Alexxa is on close-out, the line has been discontinued.
Another pair of the Alexxa bookshelf, is cheaper than a horizontal center.
If one has room for vertical placement, then that is the way to go - and
you would have an extra speaker, as a back-up (a good deal).
Who AM I
post #22 of 30 Old 03-22-2014, 05:20 PM
zieglj01's Avatar
Liked: 1263
The Monitor Audio Silver line is nice.
Who AM I
post #23 of 30 Old 03-22-2014, 05:23 PM
tdogroeder's Avatar
Quoted: 45 Post(s)
Liked: 84
They were the new Silver Series, and yes they were nice.
I'm sure you favor your Vera's over the MA Silvers, but do you think the Alexxa's would be better than them to?
post #24 of 30 Old 03-22-2014, 05:31 PM
zieglj01's Avatar
Liked: 1263
The Vera for sure, is my preference.
I would not be surprised if the Alexxa was a little better than the Silver 2 - only one way for you to find out.
Who AM I
post #25 of 30 Old 03-22-2014, 05:34 PM
tdogroeder's Avatar
Quoted: 45 Post(s)
Liked: 84
The Vera for sure, is my preference. Not surprised at that.
I would hope they would be a lot better that is why I have not pulled the trigger on them, and still toss back and forth with going with the Sierra 2's.
post #26 of 30 Old 03-22-2014, 05:44 PM
zieglj01's Avatar
Liked: 1263
The Sierra 2 looks to be a real nice speaker.
For one on a tight budget, the Alexxa looks to be a solid deal. Based on my experience
with the Vera - the Alexxa looks to be solid for a mid-level series >> that use to list for
$1000/1100 a pair, around 2007.
Who AM I
post #27 of 30 Old 03-22-2014, 05:56 PM
tdogroeder's Avatar
Quoted: 45 Post(s)
Liked: 84
They actually have them listed at the former price of $1299, but do they perform in that price range among others in the $1200-$1300 range?
Do the Vera's perform as good as other speakers in their former list price of $3600?
post #28 of 30 Old 03-22-2014, 06:42 PM
zieglj01's Avatar
Liked: 1263
Maxxsonics is a little too optimistic, with their former lists prices.
The Vera VS05B was $2,500 (pair), when they first came out - and they for sure, sound like
real high-end speakers - plus other comments have backed that up. >> For those who were
sleeping when the Vera close-out specials came out, they lost out on a gem.
The Alexxa looks like it would be strong, and hold up with the $900 to 1200 list priced speakers
of today. For someone on a tight budget, they should be on their short list. If one would prefer
another set of speakers in the future, then you can move the Alexxa to surrounds.
Who AM I
post #29 of 30 Old 03-22-2014, 06:48 PM
tdogroeder's Avatar
Quoted: 45 Post(s)
Liked: 84
For those who were sleeping when the Vera close-out specials came out, they lost out on a gem.
I wished I would have purchased them when I had the opportunity, I have waiters regret!
post #30 of 30 Old 03-22-2014, 07:43 PM
charmerci's Avatar
Quoted: 315 Post(s)
Liked: 201
After zeiglj got 'em and raved about them, you had less than a day and a half to decide on $500+ pr. of speakers. They sold out fast.
tdogroeder likes this.
Reply Speakers
