SPL Meter, worth the purchase? - AVS Forum | Home Theater Discussions And Reviews
Old 03-26-2014, 08:03 AM - Thread Starter
Cinemafreak1's Avatar
Hello,
Just got a PB 2000 SVS sub and ran audyssey last night. And it chose aweful settings, had to switch speakers to small and move the crossover from 40 to 80. And the speaker and woofer levels are all over the place. Would it be worth getting a SPL Meter to confirm accuracy of audyssey?
MIchael
Cinemafreak1 is offline
Old 03-26-2014, 09:54 AM
jwtallguy's Avatar
Quoted: 111 Post(s)
Liked: 52
Originally Posted by Cinemafreak1 View Post
Hello,
MIchael
If you have a laptop I would recommend getting a mic instead but a spl meter is worth it just not as accurate as a calibrated microphone with room EQ wizard (REW ) for about the same price
jwtallguy is offline
Old 03-26-2014, 10:02 AM
jwtallguy's Avatar
Quoted: 111 Post(s)
Liked: 52
Btw audyssey sets nothing, its the avr that sets those crossovers based on a 75 db sweep tone( the testing chrips it does) and at 75 db your speakers play down that low, but as you increase the level they cant keep up so thats why you crossover at a higher point
Old 03-26-2014, 11:23 AM
Jack D Ripper's Avatar
Liked: 269
I personally would not bother with an SPL meter. I have one, and used to use it (before I had a receiver with an automatic setup; it was useful and good then). The things that automatic setups tend to get right are the things for which meters are needed, and the things the automatic setups tend to get wrong are the things that are easy to set without a meter. You can easily set the speakers to small and set the crossover point yourself based on the frequency response of the non-subwoofer speakers; no meter is necessary for that. Automatic setups typically get levels and delays (AKA distances) right, assuming one has set the microphone in accordance with the directions in the manual (and assuming you don't have extreme problems with incorrect speaker placement or acoustics). And if you set your microphone wrong, a manual setup with an SPL meter will be wrong, too. The microphone has to be in the right place, correctly oriented, for either automatic or manual setup, or the results will be off.
Now, if you want to get fancy with playing with the EQ of the system yourself, then a microphone and a laptop with the appropriate software would likely be what you would want. But we are not then talking about just an SPL meter.
God willing, we will prevail in peace and freedom from fear and in true health through the purity and essence of our natural fluids. God bless you all.
Jack D Ripper is offline
Old 03-26-2014, 12:26 PM
jwtallguy's Avatar
Quoted: 111 Post(s)
Liked: 52
I would still recommend a spl meter if its that or nothing, he has no sub eq with multi eq so just being able to manually flatten his response would be a big help
taboola here
