Small wall/ceiling mounted speakers to replace Polk Monitor 50s? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 9 Old 03-26-2014, 10:26 AM - Thread Starter
BL44's Avatar
Hello!
I'm hoping someone may have a suggestion for me. I've been happily using a pair of Polk Monitor 50s as my front left and right in a 7.1 setup. I've got a Polk CS2 center channel and four Mirage Nanosats as my rear four channels. The sub is a Polk PSW12. Anyway, some remodeling + the addition of two toddlers to the family since I got the towers means they have to go, at least temporarily, and be replaced with something I can mount very close to the ceiling (can't stick down more than about 8-10") or on the wall close to the ceiling. A doorway means I can't mount a typical bookshelf speaker unless I turn it sideways (in other words, there's only about 8" of wall there, like over a typical door).
I always really liked the decent mid-bass I got from the Monitor 50s running them "full", but I realize I'm probably going to have to run something crossed over with the sub the way the nanosats are. I would like, however, to try to get my front and left channel a bit larger than a typical satellite because I usually like a slightly larger driver there for music.
Finally, to add to the difficulty level - my wife would prefer something white if possible.
Some options I'm considering:
Bose 161s - I know, I know, but the wife likes them and auditioning them, I don't think they'd be any worse than most of the small "satellite" options and would essentially be used that way. Mentioned here because if turned sideways they'd be just about a perfect fit for the spots I have to mount them.
Polk OWM5s - Likewise, they just happen to "fit"
Energy Take I/O 5's - These are indoor/outdoor speakers. I'm having a hard time finding a place to audition them in any sort of "indoor" setup because they're primary sold for outdoor use - but the size, shape, and bracket would make them very easy to mount and they're white. I also figure these speakers appear to be designed to be mounted sideways, so there's less potential for weird effects from the tweeters and mid-range drivers being pointed oddly, etc, when turned.
Polk Atrium 5's - Same as above, essentially.
Two more Mirage Nanosats or Omnisats - I can't find these in white, but at least they would match the rears. Not sure they'll be a satisfying replacement for the monitor 50s though, and then the center might need changing.
Other options, opinions? Budget is 150-300 for the pair. I'm not married to Polk- I tend to like Klipsch and Energy.
BL44 is offline
post #2 of 9 Old 03-26-2014, 11:02 AM
Jack D Ripper's Avatar
Liked: 272
Nothing can be ideal with your requirements, but I think sideways bookshelf speakers might be the way to go:
http://www.ebay.com/itm/RTi4-CHERRY-Bookshelf-Speakers-Polk-Audio-NEW-PAIR-/360804038210?pt=Speakers_Subwoofers&hash=item540198b642
BL44 likes this.
God willing, we will prevail in peace and freedom from fear and in true health through the purity and essence of our natural fluids. God bless you all.
Jack D Ripper is offline
post #3 of 9 Old 03-26-2014, 11:26 AM
Transmaniacon's Avatar
Quoted: 1586 Post(s)
Liked: 1394
I would take a look at the Wavecrest HLV-1, they are a compact, front ported speaker that can also be oriented horizontally and are 7" wide. You can get 2 for $230 or 3 for $335, and the designer is affiliated with Ascend, a very well liked speaker manufacturer.
http://www.wavecrestaudio.com/products/hvl-1-two-way-loudspeaker-pair
BL44 likes this.
Samsung PN60F5300 | Denon AVR-1713 | EMP E55Ti | EMP E56Ci | EMP E5Bi | Outlaw Ultra-X12
Transmaniacon is offline
post #4 of 9 Old 03-26-2014, 11:36 AM
zieglj01's Avatar
Quoted: 1709 Post(s)
Liked: 1625
Look at the Focal Sib > the stand also doubles as a mount
http://www.accessories4less.com/make-a-store/item/focalsibprwht/focal-sib-5-2-way-satellite-loudspeakers-pair-white/1.html
BL44 likes this.
__________________________________________
Who AM I
Speakers -- Canton GLS 2 > Boston VS240
Receiver -- Integra 50.2
zieglj01 is online now
post #5 of 9 Old 03-26-2014, 01:06 PM - Thread Starter
BL44's Avatar
Interesting! I had shied away from a real "bookshelf" because I'm not sure how to mount them, but these might tempt me to get creative. My primary concern is that I think I'd have to put screws into the cabinets to mount these horizontally above the door, which seems like sacrilege apart from probably having an effect on the sound..
..but that would be light-years better than putting up those 161s.
BL44 is offline
post #6 of 9 Old 03-26-2014, 02:04 PM
Liked: 272
The Polks to which I provided a link are also mountable. The "power port" on the back gives one extra options. Having said that, since I have not heard these other speakers, I cannot say how they compare.
BL44 likes this.
post #7 of 9 Old 03-26-2014, 02:18 PM
Liked: 1394
No need for screws, you can use these: http://www.standsandmounts.com/sanusspeakerwallmountsforlargerbookshelfspeakersblackwms-2.aspx
Lay the speaker on it's side, and then clamp it in place. It supports 15 pound speakers, the HLV-1 is 12 pounds, and extends up to 11", the HLV-1 is 9.5" deep.
An alternative is the NHT Super Zero. It is small enough to be placed vertically in that space and has a keyhole on the back for easy mounting. http://www.nhthifi.com/Bookshelf-speaker-SuperZero-2-1?sc=12&category=3772
BL44 likes this.
post #8 of 9 Old 04-11-2014, 12:46 PM - Thread Starter
BL44's Avatar
So I've done a ton of reading and tried some things since I first posted this. Now that I know better, dear god, what was I thinking!?
Anyway, being an engineer by trade (though not an audio engineer by any means) I've been digging into everything I can get my hands on and doing physical space measurements and paper simulations and.. gah, it's just getting to the point that I need to stop thinking about it and get something up so I can start listening to it :)
Here's what I've determined- I can't fit 12" vertically or people will bump their head on them. I tried this by putting up some 12" speakers and trying to live with them there.. and I kept hitting my head on them. Bummer :/ Also, in another thread, I discovered I really like horn tweeters.
So I'm down to:
Klipsch RB-41s
HSU HB-1's mounted sideways, tweeter in, with the tweeter turned 90 degrees.
I can't decide if it makes sense to accept the off-axis lobing I'd get with the HB-1's turned sideways in exchange for the greater frequency response of the larger mid-range driver. Since these are the front channel speakers, does time alignment trump frequency response?
Thoughts?
(BTW, thanks to all of you who have responded in this thread and in others. I've been entertained for weeks. :) )
BL44 is offline
post #9 of 9 Old 04-11-2014, 01:28 PM
Liked: 1394
Why not just go with the HSU HC-1 instead? It is designed to be oriented horizontally, and will still work well as L and R. And having three matching front speakers is the most ideal setup. Arnyk on this forum uses three Infinity PC351 mounted up on a soffit and has had good results.
Reply Speakers
