Paring speakers to a Russound MCA-C6 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 1 Old 03-26-2014, 01:25 PM - Thread Starter
utek's Avatar
Hi there,
Been lurking on these forums for years for answers, and decided that there wasn't a particular old post that can answer my current question, so here goes:
I'm planning on installing a russound mca-c6 distributed audio system (http://www.russound.com/product_detail.php?i=3171), and I am looking at pairing some speaker to it. The purpose of the speakers is background music (and the speakers are distributed to reflect that), 4 zones (2x6.5 inch speakers in each) initially that will be expanded to 6 in the future, and currently I am not planning any additional amps for power.
I am open to ideas, such as adding amps if necessary. My budget is limited to about $100/speaker (I could go slightly higher). Size of speaker would be 6.5 ideally, and I am definitely wanting low profile grills.
My concern is wattage pairing, I am worried that the speakers I choose could end up being rated for a higher minimum wattage than the russound system can deliver. Quality is another concern, I know I don't need top notch quality for background music but I am still hoping to get something of good quality. I have been looking at the russound RSF-62, but am unsure of the quality.
Any advice or suggestions regarding speaker choice?
Thanks in advance!
utek is offline
Reply Speakers
