Bowers and Wilkins New 600 Series Thread - Page 5 - AVS | Home Theater Discussions And Reviews
post #121 of 141 Old 01-23-2015, 09:13 AM
Liked: 0
Need some advice even after reading all 100+ posts. I have narrowed it down to a few options as these are in my price range and can use some advice for which step to take when trying to build a better 5.1 system in the future. Right now the price range is around $1000 (can go a little over if needed) for the speakers. I recently got a Denon X2100 for Christmas and will be using that. Here are the options I came up with and any advice would be greatly appreciated.
1. 2 B&W either 686 S2 or 685 S2 plus HTM62
2. 686 or 685 plus sub
3. 2 B&W 684
Eventually it'll be built out to a complete 5.1 but for now just need something for movies/sports.
iamvietness is offline
post #122 of 141 Old 01-23-2015, 03:35 PM
Chise's Avatar
Quoted: 191 Post(s)
Liked: 100
3. 2 B&W 684
Welcome to AVS start with 685S2's with HTM62S2 then get two M-1's later and sub.
Chise is offline
post #123 of 141 Old 01-23-2015, 04:25 PM
Quoted: 77 Post(s)
Message me i might be able to set u up with a pair of 683s2 for a great desl
JimSatala77 is offline
post #124 of 141 Old 01-24-2015, 09:22 PM
Liked: 0
i wish i saw this earlier. just picked up a pair of 684's and an HTM62
post #125 of 141 Old 02-01-2015, 07:59 AM
jav1's Avatar
685 s2 - Poor Bass
Hi Folks,
Posted this on the B&W thread, then saw this thread dedicated to the new 600 series. Hope someone can help-out. Have about 15 hours on a pair of 685 S2 being driven by a Marantz nr1403 50watt receiver. I realize the Marantz may be a bit underpowered and I am planning on upgrading. But I primarily listen at low to moderate levels and only 2.1 so I feel I should get pretty good performance. The speakers are 10 inches from the wall and so far the bass is anemic. I've been setting the cross-over to the sub at 80 or 100 to get decent bass. Decided to run Audyssey, ran it 3 times and it choose to crossover at 120/150/120. When I auditioned them in-store compared to Martin Logan Motion 15 without sub, they definitely did not go as deep as the Motions but I don't recall them being this thin. Anyone have any thoughts on why I'm nowhere near how low they are rated for? Will another 85 hours of break-in really make that much of a difference? Any 685 S2 owners care to comment on your bass performance and amp/receiver you are using.
Many Thanks
jav1 is offline
post #126 of 141 Old 02-01-2015, 08:53 AM
kamouflage's Avatar
Quoted: 66 Post(s)
Liked: 59
Originally Posted by jav1 View Post
Hi Folks,
Many Thanks
Did you make sure the port plugs are removed?
PSN ID: javant86
kamouflage is online now
post #127 of 141 Old 02-01-2015, 09:38 AM
jav1's Avatar
Yes, no port plugs.
jav1 is offline
post #128 of 141 Old 02-06-2015, 07:22 AM
Quoted: 37 Post(s)
Liked: 2
Hi Folks,
Many Thanks
My experience with Audyssey in Marantz 7009 is that is subdues the Bass quite a bit. That's why I use Pure direct for Stereo music. I use audessey specifally to control the bass out put so as to not shake up the house. Try switching out Audessey and see if makes a difference. Not to say Audessey is not great but I don;t know how to configure it to let the Bass role.
Smoothmhz is offline
post #129 of 141 Old 02-19-2015, 11:51 AM
Liked: 0
B&W 600 series S2 speakers
Hi,
I need some suggestion as well on the set up which I have purchased recently , I am a newbie to the Home theater world and went to the Best Buy store and demoed some of the Bowers and Wilkins speakers and bought them home the below set up, This is my first time purchase in the hi fi system.
1)Two Floor Standers 683 S2
2) Center HTM 61 S2
3) pair of 685 S2
4) pair of 686 S2
5) SVS-PB-2000 subwoofer
My Set up is 7.1 and was thinking if the CM Series center which is CM Center 2 S2 would be more performance improvement compared to HTM61 S2, But when I check the technical specifications in the B&W Website I see the sepcs are almost same just the CM Center is better built,
Also one other issue is the Best Buy also demoed the Pioneer Andrew jones Atmos speakers and they said that it is the future proof.
Please let me know your suggestions..
I currently also have Yamaha HTR 7065 receiver which is 2 year old, Do you guys think I need to upgrade something like Marantz SR 7009 , Since the best buy guy was marketing and convincing me that Marantz are the best match for the B&W's,
All your inputs are really valuable, and it helps me make better judgement , Depending on the suggestions i might return and purchase the speakers which best suits for 70% movies and 30% music.
vaar is offline
post #130 of 141 Old 02-19-2015, 01:08 PM
Chise's Avatar
Quoted: 191 Post(s)
Liked: 100
Originally Posted by vaar View Post
Hi,
2) Center HTM 61 S2
3) pair of 685 S2
4) pair of 686 S2
Welcome to AVS sound like you know what you want, Marantz 7009 is great match with those speakers and how big is your HT room.
Chise is offline
post #131 of 141 Old 02-19-2015, 01:20 PM
Liked: 0
Thanks for the reply Chise,
The HT is set up in my living room with 35x15x9 this includes kitchen, since this is a living room it is connected to other rooms like dining, study etc...
vaar is offline
post #132 of 141 Old 02-19-2015, 01:43 PM
Chise's Avatar
Quoted: 191 Post(s)
Liked: 100
That's big room.
Chise is offline
post #133 of 141 Old 02-19-2015, 03:04 PM
Liked: 0
it is...
vaar is offline
post #134 of 141 Old 02-20-2015, 08:24 PM
postrokfan's Avatar
Quoted: 165 Post(s)
Liked: 704
Hi,
2) Center HTM 61 S2
3) pair of 685 S2
4) pair of 686 S2
Great setup. To answer your question, yes the CMC S2 is a better center but it would make sense to stick with what you have. With that huge space I would add another subwoofer or two.
postrokfan is online now
post #135 of 141 Old 02-22-2015, 03:53 AM
John1788's Avatar
How do you find 684? Do you have sub?
What amp do you have?
John1788 is offline
post #136 of 141 Old 02-23-2015, 09:06 AM
Liked: 0
Thank you postrokfan, I guess I will stick with what I have right now... Thanks again for suggesting..As you said I might add another subwoofer down the lane...
vaar is offline
post #137 of 141 Old 02-23-2015, 08:02 PM
postrokfan's Avatar
Quoted: 165 Post(s)
Liked: 704
No problem. Sounds like a good plan.
post #138 of 141 Old Today, 07:27 PM
rbf1138's Avatar
Quoted: 21 Post(s)
Has anyone heard the JBL Studio 530s? I just got them and they are pretty great but I have this itch to maybe try the B&W 685 S2...Any idea if one would totally outdo the other?
rbf1138 is online now
post #139 of 141 Unread Today, 09:01 PM
postrokfan's Avatar
Quoted: 165 Post(s)
Liked: 704
The 530s are fantastic speakers and very neutral/accurate. If you're really that curious I would suggest auditioning the 685s. In any case, you just purchased the 530s so why not live with them for a little while?
post #140 of 141 Unread Today, 09:04 PM
rbf1138's Avatar
Quoted: 21 Post(s)
Fair point The reason I'd want to try the 685s sooner than later is that I'd want to be able to exchange the 530s I got at Best Buy within the return period for the 685s, which they sell.
At this point I just want to get rid of that "what if" feeling. I sense that at this price point the 530s are going to be as good and likely similar enough to the 685s to not make it worth swapping but I can't help but wonder lol.
post #141 of 141 Unread Today, 09:10 PM
postrokfan's Avatar
Quoted: 165 Post(s)
Liked: 704
If you're wondering "what if" they're better the answer is no. They're just different. The B&Ws are a bit warmer and therefore less neutral. Some listeners like that (FWIW, I do as I have owned several different models of B&W speakers). Ultimately, the decision is up to you and what you prefer.
Reply Speakers
