3.1 Setup for ~$1000 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 50 Old 03-30-2014, 06:37 PM - Thread Starter
Jer446's Avatar
Hello,
I think I decided a 3.1 setup is the best for my needs. I just moved into a new apartment - the main room is about 14x20 but with main listening area is 14x12. I have carpeted floors, and it would be difficult to run the rears, so I don't plan to have rears (for now). I can do towers in the front, if they are relatively small and nice looking.
What does everyone recommend for the best home theater setup around $1000? 99% tv and movies. I like punchy and vibrant sound, so I think I prefer pioneer/onkyo receiver over a Denon. I will be buying a 60" LED along with this, so I can either buy the system online, or package it with a TV to negotiate at a big box.
I listened to the Klipsch RF-42's today and thought they sounded pretty good. What do you think of them, and what sub/receiver should I pair it with?
Any other suggestions? In the past, I LOVE Definitive towers, but I don't think I can get a setup in my price range. 2.0 Towers and upgrade later? Would that be better than the Klipsch 3.1 towers?
Thanks for the advice!
Jer446 is offline
post #2 of 50 Old 03-30-2014, 07:15 PM
macddmac's Avatar
Quoted: 16 Post(s)
A 3.1 system including the receiver for $1000 is a tall order.
That said, I would go with the Pioneer vsx- 822 receiver228.00, pioneer FS – 52 speakers180..00 and SP-C-22 center 80.00and an SVS PB 1000 subwoofer-500.00 .. Yes it's worth it. Under a grand and done.
Is it a great system?? For your budget it's phenomenal!
Cheers, Mac
macddmac is offline
post #3 of 50 Old 03-30-2014, 08:04 PM - Thread Starter
Jer446's Avatar
How come you think I should spend so much on a sub? I was thinking more on the speakers and about 200 on a sub.
Jer446 is offline
post #4 of 50 Old 03-30-2014, 08:12 PM
macddmac's Avatar
Quoted: 16 Post(s)
The SVS PB-1000 will is likely the best sub on the market for the money and will make your 1000.00
99%tv/ movie system sound like you payed far more than you did.
Suit yourself and get a one note boomy 200.00 pos sub if you like.
Edit: sorry if that came off harsh- every room needs a focal point to make it memorable, regardless of what you spent to put it together.
Same thing with home theater systems. A quality subwoofer,or front speakers, in a (tight) budget home theater system can provide the wow factor to an otherwise unremarkable setup.
Your $$, your choice
Cheers, Mac
macddmac is offline
post #5 of 50 Old 03-30-2014, 08:46 PM
zieglj01's Avatar
Quoted: 1708 Post(s)
Liked: 1623
zieglj01 is offline
post #6 of 50 Old 03-30-2014, 08:51 PM - Thread Starter
Jer446's Avatar
Now I've confused muself.. The girlfriend really doesn't want towers. If I were to go with the definitive pro monitors (1000?) or maybe the myths line, mounted them on the wall and got a decent sub, how would those compare to the klipsch RS-42s? Out of the pro monitors and myths line, which package should I go with.
Jer446 is offline
post #7 of 50 Old 03-30-2014, 09:02 PM
ambesolman's Avatar
Quoted: 1100 Post(s)
Liked: 921
I'd been running a budget 5.1 sat/sub combo til about five yrs ago. I wanted to start upgrading and decided the sub was the first of many steps. Did my research (no pun intended I swear) and settled on the Hsu Research vtf3mk3. It was TRANSFORMATIVE. I'd been missing out on a LOT in movies. Everything just feels bigger, more intense and powerful.
My father has the hybrid 3 5.1 in a giant room and it does a fantastic job. I liked the HB-1s so much I bought a pair in rosenut, they're nice.
http://www.hsuresearch.com/products/hybrid2pkg.html
ambesolman is offline
post #8 of 50 Old 03-30-2014, 09:08 PM
RayGuy's Avatar
Quoted: 992 Post(s)
Liked: 868
Klipsch would be a bad choice to pair with an Onkyo or Pio receiver. Too much treble emphasis.
RayGuy is online now
post #9 of 50 Old 03-30-2014, 09:17 PM
lovinthehd's Avatar
Quoted: 4588 Post(s)
Liked: 4783
So you're saying neither the whole lineup of Onkyo or Pioneer receivers plays flat as has been measured many times? That they are "boosted" in the treble end of the spectrum? Can you please provide any evidence of this (I have one of each btw).
Or is it that the Klipsch speakers know when they're connected to these brands and sound even more harsh than usual?
ps OP--one way to think about lesser speakers with a better sub is that the sub will help the speakers out more than a lesser sub will help out better speakers...
As to a particular recommendation I liked the suggestions so far but can't think of a better one at your budget....and those Pioneers come in bookshelf models, too. Pinpoint AM40 wall mounts can be nice.
lovinthehd is offline
post #10 of 50 Old 03-31-2014, 04:44 AM
FMW
FMW's Avatar
Quoted: 1653 Post(s)
Liked: 1687
What? How would it be different "pairing" them with a different brand? Since Klipsh is one of the most popular brands on the planet, one would assume that your opinion of them isn't universal.
FMW is offline
post #11 of 50 Old 03-31-2014, 04:49 AM
Transmaniacon's Avatar
Quoted: 1586 Post(s)
Liked: 1394
That is a characteristic of the speaker, not the amplifier.
tdogroeder likes this.
Samsung PN60F5300 | Denon AVR-1713 | EMP E55Ti | EMP E56Ci | EMP E5Bi | Outlaw Ultra-X12
Transmaniacon is offline
post #12 of 50 Old 03-31-2014, 07:31 AM
zieglj01's Avatar
Liked: 1623
Look at the Boston P442 L/C/R speakers, on closeout pricing. They can
be mounted vertical for L/R and horizontal for the center.
They come with both black and silver grills packed inside for color option.
I do prefer the Boston sonic signature, over Definitive and Klipsch
http://www.accessories4less.com/make-a-store/item/bosp442ba/boston-acoustics-p442-lcr-left-right-center-speaker-black-each-new/1.html
http://a248.e.akamai.net/pix.crutchfield.com/ImageHandler/fixedscale/900/900/products/2011/7/065/x065P442-o_grilleon.jpeg
http://a248.e.akamai.net/pix.crutchfield.com/ImageHandler/fixedscale/400/300/products/2005/065/x065P442-o-1.jpeg
Still look at the Reaction Audio subwoofer. I think that no grill comes with the
Reaction Audio sub - however, double check with them.
Also, look at the HSU STF-2 subwoofer
http://www.hsuresearch.com/products/stf-2.html
__________________________________________
Who AM I
Speakers -- Canton GLS 2 > Boston VS240
Receiver -- Integra 50.2
zieglj01 is offline
post #13 of 50 Old 03-31-2014, 08:39 AM - Thread Starter
Jer446's Avatar
Thanks! I'll check these out. Do you know anywhere that sells them locally so I can give them a listen? That is the problem with a lot of these speakers.. I don't have a place to listen to them to compare, just have to go off of reviews. Since I've heard definitive many times, I know what those sound like.
Jer446 is offline
post #14 of 50 Old 03-31-2014, 08:54 AM
zieglj01's Avatar
Liked: 1623
Not at this time, since the speakers are on close-out pricing. With my experience with Boston
speakers - they make all around good stuff, and it is hard for them to make a bad speaker.
I have owned a few of their speakers.
Some insight about their P series - a review of the P400 soundbar
http://hometheaterreview.com/boston-acoustics-p400-three-channel-soundbar-speaker-reviewed/
Enjoy the adventure
Who AM I
zieglj01 is offline
post #15 of 50 Old 03-31-2014, 11:56 AM
AllenA07's Avatar
Quoted: 701 Post(s)
Liked: 572
If you're going to be using it primarily for movies I would do some serious spending on the sub. While there are some decent options around $200, the product you're getting for $500 is going to be night and day. The return on that additional $300 at that price point really is staggering. Honestly as others have said, you've got a tough task trying to go to 3.1 with a AVR for under $1000, however here are my picks:
Speakers: Pioneer Andrew Jones collection. Fronts and center should run you right around $300.
AVR: Pioneer VSX-822 which should be right around $250.
That leaves you with $450, I would spring for the SVS PB-1000.
That would give you a pretty decent 3.1 system for $1050.
My Theater: The Ugly Theater
AllenA07 is offline
post #16 of 50 Old 03-31-2014, 02:53 PM
afrogt's Avatar
Quoted: 1432 Post(s)
Liked: 982
afrogt is offline
post #17 of 50 Old 03-31-2014, 04:25 PM - Thread Starter
Jer446's Avatar
If I spent the extra money on Definitive Pro Cinema's, would that be worth the money?
Jer446 is offline
post #18 of 50 Old 03-31-2014, 04:29 PM
zieglj01's Avatar
Liked: 1623
I would go with the SM45 for the front 3 channels
http://www.crutchfield.com/S-nEsiTdTQ910/p_735SM45/Definitive-Technology-StudioMonitor-45.html
Who AM I
zieglj01 is offline
post #19 of 50 Old 03-31-2014, 05:03 PM
afrogt's Avatar
Liked: 982
The SM45's are $199 each. How is he going to get 3 of those, SVS PB1000 and a AV receiver for $1000?
Might want to look at 3 Infinity P163's across the front while they're on sale.
http://www.amazon.com/Infinity-Primus-Two-way-Bookshelf-Satellite/dp/B0045NCB32
Or a PC251 as a center if you want a horizontal speaker.
http://www.amazon.com/Infinity-Primus-PC251-Two-way-Center-Channel/dp/B0046A8R5A/ref=pd_sim_e_3?ie=UTF8&refRID=1P62H73RKCXK8EY688RW
Afro GT
afrogt is offline
post #20 of 50 Old 03-31-2014, 05:19 PM
zieglj01's Avatar
Liked: 1623
His statement and question in post #17 was, what if I spent extra mony (on the ProCinema)?
So, the response was to that > it seems that the budget may not be written in stone.
What receiver and sub he buys is up to him.
Who AM I
zieglj01 is offline
post #21 of 50 Old 03-31-2014, 07:36 PM
Elihawk's Avatar
Quoted: 1339 Post(s)
Liked: 1169
On a 1000 dollars budget, well, no way I would spend 50% on a sub! 200 for a budget AVR, 2-300 for a sub and that would leave 4-500 for a front stage
Set up #1: EMP e5Ti, e5Ci, and EMP e5Bi surrounds, Outlaw LFM1 Plus sub, SVS NSD SB12 sub, Marantz Slimeline 1504 AV receiver
Set up #2: Def Tech SM450, CLR2002, SLS Qline surrounds and EMPtek10i10i sub, Denon 1910 AV receiver
Set up #3: Philharmonics- BMR in a 2.0 system, music only, Yamaha RXV-363 AV receiver
Elihawk is offline
post #22 of 50 Old 03-31-2014, 09:15 PM
cel4145's Avatar
Quoted: 2668 Post(s)
Liked: 3002
I agree. $500 out of a $1000 budget is a lot to spend on a sub.
Living room HT: Energy RC-50, Ascend Sierra Horizon w/RAAL, Ascend Sierra 1, PSB Imagine XA | PSA V1500 and CHT SS 18.1 | Denon X4200W | modified Dayton SA1000
Other rooms: CBM-170 SE | SVS SB-1000 | Audio-GD NFB-11 | Parasound Zamp | JBL LSR305
Headphone & Portable AKG K7XX | HE-400i | NAD HP50 | Sony MDR-1A | Soundmagic E50 & E80 | X5ii | DX50 | E12
cel4145 is offline
post #23 of 50 Old 03-31-2014, 09:27 PM - Thread Starter
Jer446's Avatar
I like the idea of the bookshelves- what stands would I buy for them? Also, could I go with one of their center channels, so I can put it right under the tv? I don't think the big bookshelf will look good as a center.
Jer446 is offline
post #24 of 50 Old 03-31-2014, 10:16 PM
zieglj01's Avatar
Liked: 1623
Something like the Sanus 28 or 30 inch speaker stands can work
http://www.standsandmounts.com/sanuseurofoundations28inchspeakerstandsblackef28b.aspx
http://www.standsandmounts.com/sanusnaturalfoundations30inchspeakerstandsnf30b.aspx
The SM45 will make a good center and will sound better, for a good balance and dimensional sound.
If you can not do a vertical center, then a regular center can work - however, it will cost more.
The CS-8040HD is the center channel.
Who AM I
zieglj01 is offline
post #25 of 50 Old 04-01-2014, 07:51 AM
tdogroeder's Avatar
Quoted: 45 Post(s)
Liked: 84
You could make your own stands for $50-$60, just follow instructions at this link > http://forum.blu-ray.com/showthread.php?t=47536
I'm in the process of making my own with different different dimensions.
John 14:6 & John 3:16
Yamaha RXV765 & Emotiva LPA-1
Ascend Sierra-2s(LCR), RSS300, Polk R15, SVS PB12 plus
Panasonic S65, Sony S5100, PS4, PS3, XBOX 360
tdogroeder is offline
post #26 of 50 Old 04-07-2014, 05:15 PM - Thread Starter
Jer446's Avatar
I think I decided to go with the Definitive 8020 towers, with the pro cinema 1000 center. No sub for now (the towers have active subs).
What does everyone think of this decision? I've always been in love with these speakers.
What is a decent receiver in the ~300 range would I go with?
Jer446 is offline
post #27 of 50 Old 04-07-2014, 05:33 PM
Kini62's Avatar
Quoted: 1740 Post(s)
Liked: 1554
I'm sure it will sound nice. The pro cinema 1000 is not the matching center, buy maybe it's close enough you wan't notice it. It might be a little small too. If going with that series the 2000 would be a better choice.
Are you getting all 3 for $1k? If so that's a decent deal.
IMO you'd still be better off with a pair of the pro monitor 1000s or SM45s and a separate sub. The 8020s will be OK to around 35-40hz. Even a $300 or less sub will get you down to the mid 20hz range and have more output as well.
A pair of Dayton 12 or a single or pair of the 15s would be a much better option than the 8020s.
Def Tech SC8000
Harman Kardon AVR 1600
PS3, Apple TV, Sharp 70" Qattron
Kini62 is offline
post #28 of 50 Old 04-08-2014, 04:38 AM
Liked: 1394
Check out www.accessories4less.com, I would recommend the AVR-X1000 for 5.1, or E400 if you 7.1.
post #29 of 50 Old 04-08-2014, 04:50 AM
bladerunner6's Avatar
Quoted: 22 Post(s)
Liked: 59
I would go for a matching front three.
bladerunner6 is offline
post #30 of 50 Old 04-08-2014, 05:55 AM
98Harley's Avatar
Just wondering Transmaniacon and others, if I went with the X1000 from accessories4less which speakers would be a good match from their site as well, if putting together a package from same place, with similar parameters as original poster, maybe going a little over on budget even.
98Harley is offline
Reply Speakers
