Center channel placement...for those without AT screens lol! - AVS Forum | Home Theater Discussions And Reviews
post #1 of 11 Old 04-01-2014, 10:21 PM - Thread Starter
jlpowell84's Avatar
Quoted: 1614 Post(s)
Liked: 712
I just got my JTR Triple 8 LP (low profile) from MKtheater this week. I have been running 4 channel with a phantom center with my JTR Triple 8 HT's (difference is ported model). But my wife and I sit 9ft from the screen and about 12-18 inches to the left and right of center. It is now nice to have the sound coming from the center once again! The BD demo discs have gotten plenty of exercise as we have tested numerous scenes. I do notice the sound coming from below the screen although it is not bad. But I am a perfectionist and if making a stand and putting it above the tv will yield better results I will do it. Again I am not disappointed as it sits now and cosmetically and felling safer about it not up so high are two pluses. So I turn to you all for your advice and comments from your own experience. I know perfection would be an AT screen but it's just not a possibility currently.
Also currently the center sits on a surface even with the surface of the couch, maybe a touch higher once you sit and sink in. so it is only like 12 inches below dead center and matching the LR mains
jlpowell84 is offline
post #2 of 11 Old 04-02-2014, 10:13 AM
MKtheater's Avatar
Quoted: 1591 Post(s)
Liked: 1122
You can try lowering the mains so the sound is all coming from the same height. Angle the speaker to just above your ears as well and see if that helps.
Marantz 7702 Atmos
MKtheater is offline
post #3 of 11 Old 04-02-2014, 08:24 PM - Thread Starter
jlpowell84's Avatar
Liked: 712
it actually is firing about a ft over my head
post #4 of 11 Old 04-02-2014, 08:25 PM - Thread Starter
jlpowell84's Avatar
Liked: 712
post #5 of 11 Old 04-02-2014, 10:31 PM
GIEGAR's Avatar
Quoted: 706 Post(s)
Liked: 1220
Originally Posted by jlpowell84 View Post
Hi jlp
I reckon what will yield better results is if you pull the centre as far forward as possible on the entertainment unit - even to the extent that the speaker baffle is beyond the leading edge of the unit, if possible. Currently, you will be getting reflection and interference from the glass surface in front of the speaker. Because of the way midrange and bass frequencies propogate into the room (see below), it's these frequencies that will be interfered with. With the centre moved, you should notice things like improved clarity of voices/vocals and more coherent/fuller upper bass, giving you more feel or "punch". Many musical instruments have their fundamental frequencies spanning this upper bass/lower midrange. The centre content might actually "lock in" to the screen action better too. Of course, re-run Audyssey to optimise your results.
If the centre is firing a foot over your head, you perhaps don't need the wedges or that amount of uptilt. I think pulling the speaker all the way forward will achieve what you're trying to do with the wedges anyway.
BTW: If your bride is anything like mine, she may hate the look of the speaker pulled right forward ("It looks silly!")... some compomise may be required. I generally have mine back at a WAF distance for casual TV viewing etc, but pull them forward to "attack position" for serious listening or movie watching. Audyssey is based on the latter position. More often than not, I "forget" to push them back. biggrin.gif
[BTW #2: I love the look of JTR's LP versions... I think it's that the baffle is chock full of drivers!]
Bunga99 and jproy13 like this.
GIEGAR is offline
post #6 of 11 Old 04-03-2014, 12:02 AM - Thread Starter
jlpowell84's Avatar
Liked: 712
Thanks for the response! I will dissect this info and do further testing for sure! I guess if it sits physically farther forward than the LR mains that won't matter since it's all properly delayed in the distance settings! Sometime we need the obvious stated to us!
post #7 of 11 Old 04-03-2014, 08:23 PM - Thread Starter
jlpowell84's Avatar
Liked: 712
I will report back for sure! Do you mean toeing in the submersives as well? So that the LR mains would be square with the Submersives toed in together? So I have the evening alone to calibrate. So Even with pulling it forward I will need to prop it up at least a little or else it will fire into my waist area.
post #8 of 11 Old 04-03-2014, 10:51 PM - Thread Starter
jlpowell84's Avatar
Liked: 712
Ok here is a quick pic of the CC movement. I also pulled the Submersives out about 3.5 inches from the wall and slightly moved out the LR mains as far as they would go. Small portion of the back corner is hanging off the sub's. I would like that OCD look too but my room is so small! About to listen to movies after calibration here...
What do you think about a small little Roxul AFB pad for the CC to sit on? Not worth it at only 2 inch thick?
post #9 of 11 Old 04-03-2014, 10:52 PM - Thread Starter
jlpowell84's Avatar
Liked: 712
I would say the CC is now aimed directly at the chin area...
post #10 of 11 Old 04-03-2014, 11:22 PM - Thread Starter
jlpowell84's Avatar
Liked: 712
This weekend I am building my wall panels so I could easily construct a pad for it. Only 2 inches but it won't hurt and will technically raise it up a touch.
post #11 of 11 Old 04-07-2014, 07:26 AM
mumbleypeg's Avatar
Quoted: 26 Post(s)
Wow! That's a lot of speaker for a small screen! When I got my first surround setup I was still using a computer monitor to watch movies. Soon after I bought a barco crt on ebay and built a screen. Now I have a 5' x 10' screen and the sound coming from the bottom of the screen issue was awful. After trying top vs bottom, I found that top+ bottom was much better. The angle of each is pretty important. moving forward and backward in the room you will notice a change in the perceived location of the sound. If you have multiple rows of seating this may not be ideal. For many years this was an adequate solution, Now I have two height speakers that are simply outputting the center channel information. I do not have Dolby plIIz or DTS neo:x so they are not true height channels. I find this works very well and does a better job throughout the room. If you have a 9 or 11 channel avr the height channels do have a dialog height setting that sends a percentage of the center channel to them. Raising your screen and center channel might help as well. I will be interested to hear what you will do. Have fun!
mumbleypeg is offline
Reply Speakers
