Front speaker upgrade help - AVS Forum | Home Theater Discussions And Reviews
Old 04-02-2014, 08:40 PM - Thread Starter
Hound888's Avatar
Quoted: 66 Post(s)
Hi All,
I'm currently looking to upgrade my front l/c/r channel Monoprice 8" in wall speakers for something much better. The Monoprice have served me well especially given their very affordable price but its time for an upgrade.
I do have their 6.5" surrounds which I'm keeping to go along with my much beloved SVS NSD-PB12 sub. My issue is that I only have about 5" in depth so looking for compact. I guess I can always leave it exposed on the backside since its in my storage room so no one would really see.
I've looked at the SVS ultra bookshelf which is 10" deep and also the NHT absolute wall bookshelf's which are 5".
Just wondering if there are any other options out there. My budget is about $1000 for the 3 speakers.
These are the Monoprice 8" I'm using now for the front 3 speakers.
http://www.monoprice.com/mobile/Product/Details/6816?mainCategoryId=108&categoryId=10837&subCategoryId=1083703
Oh, forgot to mention my screen is the Elunevision Reference auduoweave 115" and receiver is the Denon 2312CI.
Any input would be greatly appreciated!
Hound888 is offline
Old 04-02-2014, 09:49 PM
cel4145's Avatar
Quoted: 2660 Post(s)
Liked: 2991
Definitive Technology has their Mythos line of speakers which are thin for wall mounting.
Living room HT: Energy RC-50, Ascend Sierra Horizon w/RAAL, Ascend Sierra 1, PSB Imagine XA | PSA V1500 and CHT SS 18.1 | Denon X4200W | modified Dayton SA1000
Other rooms: CBM-170 SE | SVS SB-1000 | Audio-GD NFB-11 | Parasound Zamp | JBL LSR305
Headphone & Portable AKG K7XX | NAD HP50 | AKG K550 | Soundmagic E50 & E80 | DX50 | E12 | X1
cel4145 is offline
Old 04-02-2014, 10:16 PM
Eyleron's Avatar
Quoted: 252 Post(s)
Liked: 142
In-wall speakers are best with a backer box.
You don't say why you're upgrading. Do the Monoprice sound harsh at all volumes? At high volumes? How high do you play (dB down from reference level)? How high do you want to play?
Is the room treated acoustically?
SEOS Fusion 10 Max, 88 Special, Volt 10 LX, SVS PB10 and DIY SI18 subs, Denon X4000, JVC RS400 & 2.35:1 AT Screen
Eyleron is offline
Old 04-03-2014, 11:20 AM - Thread Starter
Hound888's Avatar
Quoted: 66 Post(s)
I'm thinking of upgrading because the Monoprice starts to sound harsh when playing at near reference levels. Also, they do sound a bit tinny so I'm looking for a fuller sound.
Sorry but I'm not an audiophile by any means, just looking to get my setup sounding better.
Hound888 is offline
Old 04-03-2014, 11:22 AM - Thread Starter
Hound888's Avatar
Quoted: 66 Post(s)
Thanks I've looked at those.
I'm now leaning towards the NHT Classic 3 or SVS Ultra Bookshelf. Any input on the differences between the two?
Can I use these for my front L/R and C channels?
Hound888 is offline
Old 04-03-2014, 11:28 AM
zieglj01's Avatar
Quoted: 943 Post(s)
Liked: 846
I would look at the MB Quart Alexxa - buy 2 pair, use one each as a center and keep one as a spare.
http://shop.mbquart.com/p/as-b1pb-pair?pp=24
__________________________________________
Who AM I
Speakers > Snell K7, EOS 150SP
Receiver > Tascam PAR-200
zieglj01 is offline
Old 04-03-2014, 01:11 PM
Eyleron's Avatar
Quoted: 252 Post(s)
Liked: 142
I appreciate that you're not an audiophile, although just that you're willing to upgrade speakers and that you don't want "tinny" and want "fuller" sound makes you an "audiophile" compared to most of the public.
I didn't mean to suggest that you need to wax poetic like some silly magazine review, or spout all this audio techno stuff.
It's about what your goals are for how the speakers are used.
If I say "I need a new car," you don't know if I'm trying to fit in a larger family, haul construction supplies, navigate rocky snowy terrain, haul a boat, look more styling driving down Hollywood Boulevard, beat people in street racing, want to save my marriage by having separate environmental controls for the passengers, etc. You don't have to be a Car&Driver editor to think about your needs.
Most speakers sound harsh when playing at near reference levels. You need speakers that can handle more power or are more sensitive.
How about this Klipsch THX In-wall: http://www.klipsch.com/kl-7800-thx-in-wall-speaker
Or this Triad In-wall: http://www.triadspeakers.com/products/iwg6lcr.html
Or Triad on-wall: http://www.triadspeakers.com/products/owblcr.html
Eyleron is offline
Old 04-18-2014, 11:39 AM - Thread Starter
Hound888's Avatar
Quoted: 66 Post(s)
I ended up purchasing three Jamo D500LCR due to their size and liked how they sounded when I auditioned them at a local A/V store.
Thanks for all the input!
Hound888 is offline
Old 04-18-2014, 02:33 PM
Eyleron's Avatar
Quoted: 252 Post(s)
Liked: 142
Great! Make sure your receiver supports 4 ohm speakers.
Eyleron is offline
Old 04-18-2014, 02:38 PM - Thread Starter
Hound888's Avatar
Quoted: 66 Post(s)
I didn't even think about this! My Demon 2312CI only supports 6 and 8 ohms. Does that mean it won't work?
I still have time to cancel my order as it hasn't shipped yet.
Hound888 is offline
Old 04-18-2014, 03:36 PM
Eyleron's Avatar
Quoted: 252 Post(s)
Liked: 142
Maybe your receiver does okay with 4ohm but not officially.
Maybe the speakers' impedance isn't too tough a load. You could read about each.
But other than that you should get diff speakers or diff receiver.
Eyleron is offline
Old 04-18-2014, 08:41 PM - Thread Starter
Hound888's Avatar
Quoted: 66 Post(s)
Thanks for the info. I think I'm going to try it out with my receiver first but thinking maybe adding a 3 channel external amp might be the way to go.
I've read a couple D500 owners using receivers not supporting 4ohms and seems to be working for them but I'd rather be safe than sorry. I'm pretty set on the D500's and don't really want to replace my Demon since its less than a year old.
Any suggestions on a 3 channel amp capable of doing 4 ohms at under $500?
Hound888 is offline
Old 04-23-2014, 01:48 PM - Thread Starter
Hound888's Avatar
Quoted: 66 Post(s)
After thinking about it some more, I cancelled my Jamo D500 order since it's rated for 4ohms and I don't want to take a chance blowing things up. Also, my receiver doesn't have pre-outs so I can't even add an amp, just too much work and unknowns.
Now I'm looking at the Chane Arx A2rx-c for my fronts. It will work as mains as well as a center and all the reviews seem to be good.
Only issue is that its sold out now and won't be available for another 90 days.
Hound888 is offline
