New Home Theater Set-up - AVS Forum | Home Theater Discussions And Reviews
post #1 of 17 Old 04-04-2014, 11:07 AM - Thread Starter
jcarp11's Avatar
I am in the process of putting in a new home theater in my basement with a 110" projector screen. The room will be used primarily for movies and TV/sports, but some music as well. I think I am settled on the video side, but am feeling a little overwhelmed by the choices for audio.
The room is a rectangle with ~1,600 cubic feet. In order to maximize screen size, there is little-to-no space to the sides of the screen for floorstanding speakers. Therefore, I think I need something that can be mounted. The seating will be along the back wall of the room.
My maximum budget is $3,000 for a 5.1 set-up, including the receiver, although I am always open to a better value. Generally speaking, we are not true audiophiles but would like a relatively impressive system to match the 110" video.
Any help or suggestions would be greatly appreciated. Thanks.
jcarp11 is offline
post #2 of 17 Old 04-04-2014, 11:19 AM
Transmaniacon's Avatar
Quoted: 1530 Post(s)
Liked: 1319
I would take a look at HSU, the Hybrid 3 5.1 system would be a great option, and I would add an additional VTF-3 MK4 to improve bass response.
I would add to that a Denon AVR-X2000, which comes with Audyssey MultEQ XT, and 7.1 for future expansion.
This system will give you great dynamics and clear sound for movies, and the dual subs will really enhance your movie experience. You should be looking at an acoustically transparent screen, so you can put the speakers behind it and utilize three identical speakers (most ideal). I would also strongly consider getting an acoustic panel package, this will make a huge difference in sound quality, and is a requirement in a dedicated space.
Samsung PN60F5300 | Denon AVR-1713 | EMP E55Ti | EMP E56Ci | EMP E5Bi | Outlaw Ultra-X12
Transmaniacon is offline
post #3 of 17 Old 04-04-2014, 11:26 AM
zieglj01's Avatar
Quoted: 938 Post(s)
Liked: 846
More often than not - it seems that people are choosing video as a priority, over audio quality.
How much width space do you really have to the side of the screen?
__________________________________________
Who AM I
Speakers > Snell K7, EOS 150SP
Receiver > Tascam PAR-200
zieglj01 is offline
post #4 of 17 Old 04-04-2014, 12:18 PM - Thread Starter
jcarp11's Avatar
Only a few inches to either side. My problem is that the wall that will have the screen also has a closet door, so that limits my width.
jcarp11 is offline
post #5 of 17 Old 04-04-2014, 12:33 PM - Thread Starter
jcarp11's Avatar
Thanks. I will take a look. My one concern with the X2000 is the lack of wifi. I think I'd probably prefer to have it built-in, but this is definitely a good option otherwise.
jcarp11 is offline
post #6 of 17 Old 04-04-2014, 12:49 PM
zieglj01's Avatar
Quoted: 938 Post(s)
Liked: 846
Then look at the EMP speakers
http://emptek.com/ew35.php
Who AM I
zieglj01 is offline
post #7 of 17 Old 04-04-2014, 12:49 PM
Liked: 1319
The X2000 has networking... I don't know of many receivers that have wifi built in, I would rather run Ethernet.
post #8 of 17 Old 04-04-2014, 02:54 PM - Thread Starter
jcarp11's Avatar
Wouldn't I need a receiver with 2 pre-outs for the dual subwoofers?
jcarp11 is offline
post #9 of 17 Old 04-04-2014, 03:39 PM
darthray's Avatar
Quoted: 939 Post(s)
Liked: 895
Not realy.
You can use a Y splitter (1 male to 2 female).
I ran my set-up for years before getting an andio/video processor with dual output.
Ray
darthray is offline
post #10 of 17 Old 04-04-2014, 09:23 PM
dinzitari's Avatar
I just bought a Klipsch set-up from crutch field for 1,245$. Bought a Yamaha  rx575 on Amazon fro 299$. Speakers are  pair of rb600's, rc500, rs400's and a rw12 sub.
Receiver is 7.2 with dual zone
dinzitari is offline
post #11 of 17 Old 04-04-2014, 09:26 PM
cel4145's Avatar
Quoted: 2658 Post(s)
Liked: 2990
So why not get a 100" screen so you'll have more room for speakers? You realize that you can have sound that can equal or exceed the movie theater, but not if you don't have room for speakers. LOL
Living room HT: Energy RC-50, Ascend Sierra Horizon w/RAAL, Ascend Sierra 1, PSB Imagine XA | PSA V1500 and CHT SS 18.1 | Denon X4200W | modified Dayton SA1000
Other rooms: CBM-170 SE | SVS SB-1000 | Audio-GD NFB-11 | Parasound Zamp | JBL LSR305
Headphone & Portable AKG K7XX | NAD HP50 | AKG K550 | Soundmagic E50 & E80 | DX50 | E12 | X1
cel4145 is offline
post #12 of 17 Old 04-06-2014, 06:12 AM - Thread Starter
jcarp11's Avatar
@cel4145I think I will be happier with the 110" screen given my viewing distance. As I consider everyone's suggestions and look again at the space, I think I probably need to go with an in wall installation behind an AT screen. I am thinking the Elite AccousticPro 1080P2. My only other option is probably to do all three front speakers either above or below the screen.
What do you guys think about in wall options and this screen?
jcarp11 is offline
post #13 of 17 Old 04-06-2014, 09:43 AM
zieglj01's Avatar
Quoted: 938 Post(s)
Liked: 846
Go AT screen, with the speakers behind the screen
crazyrob425 likes this.
Who AM I
zieglj01 is offline
post #14 of 17 Old 04-06-2014, 09:59 AM
cel4145's Avatar
Liked: 2990
Agreed.
cel4145 is offline
post #15 of 17 Old 04-06-2014, 04:44 PM
sdg4vfx's Avatar
Quoted: 81 Post(s)
Liked: 140
+2
sdg4vfx is offline
post #16 of 17 Old 04-07-2014, 04:18 AM
smasher50's Avatar
Quoted: 355 Post(s)
Liked: 15681
fwiw, just a suggestion . after reading your post I would try to keep your seating away from back wall also, for better overall sound experience
i'm so laid back,i'm laid out
smasher50 is offline
post #17 of 17 Old 04-07-2014, 05:15 AM
Liked: 1319
+3
Reply Speakers
