ORB Speakers buying VERY SOON, Need Sub Woofer Advice Please!!!! - Page 4 - AVS Forum | Home Theater Discussions And Reviews
post #91 of 93 Old 04-09-2014, 04:52 AM
Bond 007's Avatar
Quoted: 2370 Post(s)
Liked: 1906
Get the 8040 center. Make sure to pull it all the way forward on the mantle and prop up the back of it so that it points directly at the listening position.
Licence to Kill
Bond 007 is online now
post #92 of 93 Old 04-09-2014, 09:10 AM
crazyrob425's Avatar
Quoted: 443 Post(s)
Liked: 337
Originally Posted by redcoupebandit View Post
I WOULD Love it if someone suggested my Center Channel from the 3 choices I listed above please. If I get the smaller one for $349, it fits EASILY under the TV. the other ones will hang abount 1 inch off the front, but will still have 95% of the speaker supported by the Mantle, so I am not sure how BAD Going with one of the "Big Daddy" Center Channel choices would look????
Definitive Technology CS-8040HD
If you can fit it!
crazyrob425 is offline
post #93 of 93 Old 04-09-2014, 09:17 AM
zieglj01's Avatar
Quoted: 938 Post(s)
Liked: 846
100% skipping the ORBs!!! .
The Definitive Technology Speakers look NICE,
Definitive is a good call - and the new SM series are really nice - the 8040HD is the preferred center.
You will get better sound, if it does sit 1 inch forward of the mantle
__________________________________________
Who AM I
Speakers > Snell K7, EOS 150SP
Receiver > Tascam PAR-200
zieglj01 is offline
Reply Speakers
