First Dedicated Theater... Klipsch or Definitive Speakers? - Page 2 - AVS Forum | Home Theater Discussions And Reviews
post #31 of 35 Old 04-13-2014, 11:16 PM
shadyJ's Avatar
Quoted: 1330 Post(s)
Liked: 1350
Originally Posted by cel4145 View Post
The front soundstage is most critical, and using three exact same speakers across the front is optimal, THE best solution.
It is definitely much less important for the rears and surrounds to be the same.
+1, you could fall back to something like RB-51s for surrounds and you probably wouldn't notice the difference. However, perfection would be RB-61s for surrounds.
The reason why a vertical center is better than the usual horizontal centers is because speakers perform better when the woofers are lined up vertically, not horizontally. If you want to get into technical reasons why a horizontal center faces more challenges to getting the sound right, here are a couple articles for you. The point is, if you can avoid it, you ought to do so. Most people can't due to the way their entertainment centers are designed, thus the reason for horizontal center speakers in the first place. Like I said before, their design is for the sake of convenience, not performance. That doesn't mean they are bad, just not ideal.
shadyJ is offline
post #32 of 35 Old 04-14-2014, 01:06 AM
Reference_head's Avatar
Quoted: 142 Post(s)
Liked: 730
Bookshelf are nice if that's what the room and budget will fit. I have rb61ii as back speakers and I have owned many reference line floor standers including rf82. The rf82 will give you a much better front stage than the rb61. Sub or no sub it's night and day. Even crossed over at 80hz the rf82 will give you a bigger more effortless sound. Still a lot of bass above 80hz and the rf82 will outperform the much smaller rb61. My advise is the rf62ii and rc62ii.
Klipsch Pro Cinema KPT-904 L/C/R, Pro Cinema KPT-1201-T2 for sides and Heresy II for backs.
SVS PB13-Ultra, PB12-Plus x2, and Velodyne SMS-1 Sub EQ
SC-55 elite and B&K 200.7 S2
JVC RS-45 Projector, and Seymour CS 125” 2.35 screen
Oppo BDP-103 9 ATS Acoustic panels
Reference_head is offline
post #33 of 35 Old 04-14-2014, 12:51 PM
Quoted: 142 Post(s)
Liked: 730
Think of it like this. If bookshelf really are just as good with a sub. They would be behind the screen at theaters. Size matters for more than just bass below 80hz.
post #34 of 35 Old 04-14-2014, 03:08 PM
losservatore's Avatar
Quoted: 2312 Post(s)
Liked: 2060
I like to use towers because they increase output, you get a more room filling ,many bookshelf speakers struggle and distort in medium to large rooms, I think it depends on how capable is.
Living Room :Oled 65" B6 / Marantz SR7010 / Xbox One S / PS4 Pro / HTPC / 2 PSA XS30 / Revel Performa3 F206 / Revel Performa3 C205 / Revel Surrounds / Sonos Connect / Roku 4 Ultra /Amazon Fire tv /
losservatore is offline
post #35 of 35 Old 05-12-2014, 10:29 AM
Yukichon's Avatar
Quoted: 145 Post(s)
Liked: 59
I would love to know what those chane theater 10 speakers sound like as they are on my short list
Yukichon is offline
Reply Speakers
