Dipole / Bipole speakers for my speaker orientation? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 10 Old 04-17-2014, 04:36 PM - Thread Starter
andrx471's Avatar
Hi all. I am moving to a new apartment in about a month. My bedroom is about 13' by 13'. I would like to setup surround in that room, but with it being kind of small, I'm wondering if dipole or bipole speakers for surrounds would be the way to go? I will be using Energy CB-20 speakers for my fronts and the Energy CC-10 for my mid. I picture myself watching movies sitting in my bed, with my bed pushed up against the opposite wall from my front speakers. This means my rears will have to be more to the side of me than actually behind me. My budget would be around $300 for a pair of speakers. What do you all think? Thanks!
andrx471 is offline
post #2 of 10 Old 04-17-2014, 08:07 PM - Thread Starter
andrx471's Avatar
Bump
andrx471 is offline
post #3 of 10 Old 04-18-2014, 06:38 AM - Thread Starter
andrx471's Avatar
Bump
andrx471 is offline
post #4 of 10 Old 04-18-2014, 06:58 AM
almadacr's Avatar
A Level TWO Surround Speakers from HTD would fit your needs .
HTD
almadacr is offline
post #5 of 10 Old 04-18-2014, 08:15 AM - Thread Starter
andrx471's Avatar
I have never heard of HTD. Are their speakers a good bang for my buck? Also, do you know how well they would match with my Energy speakers? Thanks for your input!
andrx471 is offline
post #6 of 10 Old 04-18-2014, 08:19 AM
almadacr's Avatar
You can check with HTD owners , there's a tread dedicated to HTD speakers , i didn't heard bad things about it .wink.gif
HTD Tread
almadacr is offline
post #7 of 10 Old 04-18-2014, 08:34 AM - Thread Starter
andrx471's Avatar
Great! Thank you! Would these be positioned in the upper corners of my room, 90 degrees from my sitting position, or how should these be set up?
andrx471 is offline
post #8 of 10 Old 04-18-2014, 09:31 PM
LowTech1's Avatar
Quoted: 1149 Post(s)
Liked: 272
LowTech1 is offline
post #9 of 10 Old 04-19-2014, 12:40 AM
fatbottom's Avatar
Quoted: 1420 Post(s)
Liked: 520
I use dipole for the sides, and bipole for the rears. These speakers are best when you're close to the side/surrounds, otherwise with monopoles they're too distracting.
Bipoles can work on the rear and sides, but dipoles should be used on the side only.
fatbottom is offline
post #10 of 10 Old 04-20-2014, 05:28 PM - Thread Starter
andrx471's Avatar
Great! Thank you all for your help!
andrx471 is offline
Reply Speakers
