Speaker size to match room volume - Page 2 - AVS Forum | Home Theater Discussions And Reviews
post #31 of 55 Old 04-19-2014, 07:27 AM
Berland's Avatar
Quoted: 45 Post(s)
Liked: 30
Originally Posted by EmulousTrigger View Post
I calibrate the sub using an SPL meter and the MCACC in the AVR. The room the sub is in now is smaller than the room it used to be in. I wonder if there's something wrong with the sub itself?
You are using the LFE input (Right-channel) only on the sub?
And very important; that you have set the LFE/Normal switch to LFE!
HT: CLASSE CA-5300 DELTA - BRYSTON 4B SST2 - Marantz AV8802A - B&W 803D2, 2*DB1, HTM2D2, 804D2, SCMS, Nautilus SCM1, 805D2, SA Talent - NORDOST Heimdall2/Frey2 - ISOTEK EVO3 Titan,Sigmas - Samsung UE78JS9505 - GIK ACOUSTICS - AUDYSSEY Pro Kit
HP: 2*MOON Neo 430HA D - Schiit Yggdrasil - 2*Audiobyte Hydra Z, Hydra ZPM - 2*iFi micro iUSB 3.0 - ISOTEK EVO3 Sigmas, Aquarius - NORDOST Heimdall 2 - AUDEZE LCD-4 rev2, LCD-3F, 2*LCD-XC - SHURE SE846
Berland is offline
post #32 of 55 Old 04-19-2014, 07:27 AM - Thread Starter
EmulousTrigger's Avatar
Originally Posted by Berland View Post
Could it be a difference in signal strengts from the LFE-output of the Pioneer SC67 is a lot lower then your previous AVR? There are no standards here - try pushing volume up on the sub itself.
Your sub should be more than enough to make the room shake... so that is not it.
I'm leaning toward an issue with the calibration in MCACC. Cancellation could be an issue too. I am going to try moving the sub, test that, then re-run the MCACC. Perhaps poor EQ settings could cause the bass issues.....
EmulousTrigger is offline
post #33 of 55 Old 04-19-2014, 07:32 AM
Secret Squirrel's Avatar
Quoted: 44 Post(s)
Liked: 39
Here's what to look for when calibrating the subwoofer. The subwoofer trim level should be as close to zero as possible in the AVR. Set the gain on the back of the sub to get between 75db-80db with the test tone. Don't try to fix this with EQ. I disagree with comment about the sub being able to pressurize that room . It's to small to be able to have a visceral impact.
Secret Squirrel is offline
post #34 of 55 Old 04-19-2014, 07:32 AM - Thread Starter
Using the right input, switch is at LFE, yes.
post #35 of 55 Old 04-19-2014, 07:35 AM - Thread Starter
Bi-amping the A9's isn't causing issues, is it?
post #36 of 55 Old 04-19-2014, 07:36 AM
Berland's Avatar
Quoted: 45 Post(s)
Liked: 30
Good, and if you get a lot of bass-peaks from the corner. The calibration could "fix" this by reducing the sub level by 10-15 dB. Also important as mentioned here to have the sub play around 80 dB before doing calibration (then the AVR should have sub-channel adjusted to 0 dB, calibrate this by using volume on the sub itself. A good indicator to see if it is too high or low is the see level of sub on AVR post calibration... if it is set -10 or +10; adjust volumne on sub accordingly.
Edit:
Also keep crossover to max (150 Hz adjustment on sub) and phase to 0 (switch on sub).
Edit2:
When all this is verified; try moving the sub between left or right front-speaker and center (facing main listening position)... Corner usually gives more bass, but could create massive peaks that effectively turns the sub "off" to adjust for this during calibration.
Berland is offline
post #37 of 55 Old 04-19-2014, 07:37 AM
Quoted: 44 Post(s)
Liked: 39
It's not causing the issue but bi amping your speakers like that is doing absolutely nothing.
post #38 of 55 Old 04-19-2014, 07:38 AM - Thread Starter
I don't understand how it was so effective in a really big room but so ineffective in a smaller room? It wasn't that bad with my old Denon either, it's been MIA ever since I installed the SC-67.
post #39 of 55 Old 04-19-2014, 07:40 AM - Thread Starter
Thank you! Darn good to know, I didn't hear a difference. Seemed like a waste of current to me!
post #40 of 55 Old 04-19-2014, 07:45 AM - Thread Starter
Edit:
Edit2:
Another interesting bit using MCACC....I had the trim on the sub set at 11:00, but MCACC always adjusted the sub level down to -8, but also set the sub distance to like 19 feet away all the time.....
post #41 of 55 Old 04-19-2014, 07:45 AM
Quoted: 44 Post(s)
Liked: 39
This is probably due to a difference in the calibration that you're using between the two different AVR's and the different rooms. The smaller room should have more bass impact using the same subwoofer as long as you have the sub trim settings right and the sub placed properly. It's also possible that you have a phase issue between your mains and the subwoofer. You may need to manipulate the subwoofer distance settings to manipulate the time alignment between those speakers. The settings to get the time alignment right at the main listing position is not always the actual distance.
post #42 of 55 Old 04-19-2014, 07:48 AM - Thread Starter
The MCACC should be doing this for me, no?
post #43 of 55 Old 04-19-2014, 07:49 AM
Berland's Avatar
Quoted: 45 Post(s)
Liked: 30
Distance to sub is often set larger than it in reality is, reason for this is processing time inside the sub (the calibration measures time for signal from it is sent out from AVR to it is received in the microphone). But 19 feet seem kind of brutal, could this be due to corner reflection tricking the calibration system. Again, try moving it between center and one of the two front speakers to see if this got effect. -8 indicates that the volume of sub is to high before calibration; turn it down to 09:30 :)
Berland is offline
post #44 of 55 Old 04-19-2014, 07:49 AM
Quoted: 44 Post(s)
Liked: 39
That means that you have the gain on the subwoofer to high. You need to turn it down until you get a reading close to zero on the subwoofer AVR trim. You can test the 19ft measurement by setting it closer and further away and see if the bass comes together. Play a song that you know very well and move the distance setting around and see if that improves the sound.
post #45 of 55 Old 04-19-2014, 07:53 AM - Thread Starter
Gentlemen, can't thank you enough, solid advice. Will try all that as soon as I can. When I redo my calibration, should I leave the crossover at 80 and set the A9's to Large or Small?
post #46 of 55 Old 04-19-2014, 08:07 AM
Bill Fitzmaurice's Avatar
Liked: 4900
Set to small you have those huge speakers that are capable of delivering lots of output down to 25Hz or so doing nothing below 80Hz. That's the epitome of illogical. If you're going to use a sub at all it should be in conjunction with the mains, placed where it will smooth out the response null that you have at the LP, which means probably at the rear of the room.
Bill Fitzmaurice is online now
post #47 of 55 Old 04-19-2014, 08:12 AM - Thread Starter
I've actually tried the back of the room, and I think it's a black hole back there. No real audible difference between the sub being on or off when it's placed at the back of the room. Looks like it's sub crawl time again!
post #48 of 55 Old 04-19-2014, 08:21 AM - Thread Starter
And is the SC-67 enough to do those speakers justice? Should I be looking at external amplification?
post #49 of 55 Old 04-19-2014, 08:23 AM
Berland's Avatar
Quoted: 45 Post(s)
Liked: 30
Set to SMALL, everyone creating the calibration systems recommend this. You can set the crossover for the fronts down later; do it in incremental steps and listen until you are happy.
Berland is offline
post #50 of 55 Old 04-19-2014, 08:24 AM
Berland's Avatar
Quoted: 45 Post(s)
Liked: 30
If you set crossover to 80Hz, the SC-67 will not be an issue. You need double power to drive them down to 40Hz compared to 80Hz :)
Berland is offline
post #51 of 55 Old 04-20-2014, 01:17 PM - Thread Starter
Okay, sub was moved to about 3 feet from the side wall, still up against the front wall though, not enough floor space to put the sub 2 feet from the front wall. RTi's installed near the corners of the room, again, due to space constraints and maximize separation. Did a complete MCACC calibration, will update with results. Crossover is set to 80 and the mains are set to large.
post #52 of 55 Old 04-20-2014, 02:01 PM
Quoted: 44 Post(s)
Liked: 39
Good luck. Let us know the results.
post #53 of 55 Old 04-20-2014, 06:32 PM - Thread Starter
My MCACC calibration has turned all the levels down below 0. Am I compromising the calibration by upping all the levels by the same amount? Output is pretty quiet as a result.
post #54 of 55 Old 05-06-2014, 05:42 PM - Thread Starter
Okay, recalibrated MCACC, moved speakers around, moved the sub and it's much improved. However one weird thing is happening.....I was watching Star Wars and my wife upstairs was complaining that the bass was too high, but in the room it felt like there was none and it didn't sound that loud. Normally when there is a lot of bass you can tell by hearing it that people in the house are going to hear and feel it. Not so much the case with me now. Thoughts?
post #55 of 55 Old 05-06-2014, 07:12 PM
Liked: 4900
Cancellation, which is the product of the distances between the sub and you, the sub and room boundaries, and you and the room boundaries. You have major cancellation nulls at your LP. Since she's in a different room she's not in the cancellation zone. It's difficult, if not impossible, not to have major cancellation nulls at the LP with only one sub.
Reply Speakers
