Do you adjust floorstanding speakers height? - AVS Forum | Home Theater Discussions And Reviews
Old 04-19-2014, 08:11 PM - Thread Starter
seiyafan's Avatar
Quoted: 28 Post(s)
Liked: 25
One of the rules for positioning speakers is to set tweeter at the ears level, that's easy to do for bookshelf speakers with adjustable stands, but what about floorstanding speakers? When I sit down my ears are about 47 inches off the floor, that's higher than most floorstanding speakers. Do you guys try to put something underneath, get a different chair or just don't bother? biggrin.gif
seiyafan is offline
Old 04-19-2014, 08:34 PM
East Glenn's Avatar
 I just put the speakers where I like. The speaker police have yet to give me summons.
East Glenn is offline
Old 04-19-2014, 11:43 PM
A9X-308's Avatar
Quoted: 1280 Post(s)
Liked: 951
I would contact the manufacturer and find out where the neutral axis of the speaker is and adjust the speaker or chair height to match if ear height was substantially different. I placed stands under my KEF 104/2s when I used them in my bedroom as the bed is quite high and the sound changed quite a bit as I moved up from tweeter height. I'll do the same with the new pair I'm building to replace the KEFs so that they can be used in a more conventional manner in another room later.
A9X-308 is offline
Old 04-19-2014, 11:46 PM
kiwi2's Avatar
Quoted: 35 Post(s)
Liked: 160
Yes if I need to.
Experiment by moving your head up and down at LP distance and see if the sound changes for better or worse.
kiwi2 is offline
Old 04-20-2014, 08:18 AM - Thread Starter
seiyafan's Avatar
Quoted: 28 Post(s)
Liked: 25
Good idea! Thanks!
seiyafan is offline
Old 04-20-2014, 01:34 PM
Bill Fitzmaurice's Avatar
Liked: 4628
What matters is having the tweeter axis on line with your head. If they're too low put something under the front edge of the speakers to tilt them back enough to accomplish that.
Bill Fitzmaurice is online now
