Need a set of surround speakers for a few hundred bucks. - AVS Forum | Home Theater Discussions And Reviews
post #1 of 36 Old 04-25-2014, 11:56 PM - Thread Starter
jlpowell84's Avatar
Quoted: 1613 Post(s)
Liked: 712
Hey all. I need to pick up a pair of surround speakers for a few hundred. I will upgrade at some point in the future but just need something that will do the job for now. I have JTR Triple 8 for LCR which are 98db sensitive and crossed over to a couple Seaton Submersives. I know very sensitive speakers. Let me know what you think a good match would be. Thanks.
I have been planning on the Volt 10 kit from the DIY sound group but thought I would ask for suggestions
http://www.diysoundgroup.com/coaxial-speaker-kits.html
Here are some others based on a few hundred.
http://www.avsforum.com/t/1513064/definitive-technology-studio-monitor-450-sm450-upgraded-internals
http://www.avsforum.com/t/1528801/definitive-technology-sr-8040bp-pair
http://www.avsforum.com/t/1506724/fs-mordaunt-short-mezzo-1-monitor-bookshelf-pair
http://www.avsforum.com/t/1529065/energy-veritas-5-2-center-and-5-1-bookshelf-speakers-high-gloss-rosewood
http://www.amazon.com/Klipsch-RB-51-II-Bookshelf-Speaker/dp/B0040LG96O/ref=pd_sim_sbs_e_3?ie=UTF8&refRID=1ZZPB6SB2VREKE3VRQG9
http://www.avsforum.com/t/1527691/ascend-hsu
http://www.avsforum.com/t/1527596/m-k-ss-550-gloss-black-pair
http://www.newegg.com/Product/Product.aspx?Item=N82E16882780029
http://www.avsforum.com/t/1524673/fs-nht-classic-two-300-for-pair
http://www.amazon.com/Fluance-ES1S-Fidelity-Surround-Bookshelf/dp/B006GDOJ70/ref=sr_1_37?s=electronics&ie=UTF8&qid=1398493962&sr=1-37&keywords=surround+speakers
jlpowell84 is offline
post #2 of 36 Old 04-26-2014, 02:11 AM
sandydankness's Avatar
Quoted: 105 Post(s)
Liked: 74
If you don't mind a little work the Volt's on paper look the best.  DIY is pretty much impossible to beat, and the higher sensitivity would probably be easier to meld into your mains.  I'm far from an expert, just my thoughts on the matter.
sandydankness is offline
post #3 of 36 Old 04-26-2014, 10:35 AM - Thread Starter
jlpowell84's Avatar
Liked: 712
post #4 of 36 Old 04-27-2014, 01:43 AM
jaeelarr's Avatar
Quoted: 46 Post(s)
Liked: 42
Why spend a few hundred if they are temporary? They are just surrounds....spend $50. They only handle ambient sounds for the most part anyways. No point in wasting good money.
jaeelarr is offline
post #5 of 36 Old 04-27-2014, 03:54 AM
blazar's Avatar
Quoted: 716 Post(s)
Liked: 526
"Only surrounds".... If you heard a home theater with a set of full range speakers, you wouldn't be saying this. Surrounds can make a HUGE difference in modern soundtracks... Whether you care to "waste" the money or not is a different issue.
Plenty of DIY, used, and refurbished options available for cheap.... No need to settle for crap.
darthray likes this.
Blazar!
blazar is offline
post #6 of 36 Old 04-27-2014, 08:21 AM
jaeelarr's Avatar
Quoted: 46 Post(s)
Liked: 42
Again, they are temporary....so why spend so much? That's the point.
And no where in my post did I say to buy crap. Cheap and crap are not synonymous.
jaeelarr is offline
post #7 of 36 Old 04-27-2014, 11:24 AM
blazar's Avatar
Quoted: 716 Post(s)
Liked: 526
Oh missed the "temporary" part
Blazar!
blazar is offline
post #8 of 36 Old 04-27-2014, 11:51 AM
sdg4vfx's Avatar
Quoted: 81 Post(s)
Liked: 140
The Cambridge Audio S30 could work. It's a full range speaker with a small-ish cabinet size and 90dB sensitivity.
On close out sale for $200 a pair at http://www.accessories4less.com/
sdg4vfx is offline
post #9 of 36 Old 04-27-2014, 12:09 PM - Thread Starter
jlpowell84's Avatar
Liked: 712
Several of the speakers I listed I wouldn't consider crap (I know you didn't say it). They could easily fill in until I can swing a set of say JTR single 8's ($900 each). I could then sell them for nearly what I bought them for. So not a waste of money. After selling after I have used whatever will be only a small fee to have them in my setup for some time. Like rent...So lets say I spent 300 on a pair of the used ones I listed. In a year I sell for 250. Or I buy the Volt kits which are certainly very capable speaker and I sell. You see what I am saying?
I am ordering the Volt kits with the slanted boxes...
post #10 of 36 Old 04-27-2014, 12:21 PM - Thread Starter
jlpowell84's Avatar
Liked: 712
On close out sale for $200 a pair at http://www.accessories4less.com/[/quote]
The whole reason I made this thread was to get ideas to avoid building the volts. I don't mind doing but my 4520 is coming thursday and I would 'prefer' to just plug in the surrounds and calibrate. These look like decent little speakers and I could always keep them for computer use...
post #11 of 36 Old 04-27-2014, 12:32 PM - Thread Starter
jlpowell84's Avatar
Liked: 712
post #12 of 36 Old 04-27-2014, 12:32 PM
zieglj01's Avatar
Quoted: 938 Post(s)
Liked: 846
Something like the Definitive Tech speakers or the likes of the
JBL Studio 210 speakers can work for you.
http://www.amazon.com/JBL-Studio-210-Surround-Loudspeaker/dp/B00GK22KYG
__________________________________________
Who AM I
Speakers > Snell K7, EOS 150SP
Receiver > Tascam PAR-200
zieglj01 is offline
post #13 of 36 Old 04-27-2014, 12:33 PM
sdg4vfx's Avatar
Quoted: 81 Post(s)
Liked: 140
... The whole reason I made this thread was to get ideas to avoid building the volts. I don't mind doing but my 4520 is coming thursday and I would 'prefer' to just plug in the surrounds and calibrate. These look like decent little speakers and I could always keep them for computer use...
They are just that, "decent little speakers". I used them as surrounds for several months and they worked very well (I eventually upgraded my surrounds for 5 identical speakers all around). I now use the S30's as bedroom speakers - they dig surprisingly low for speakers their size and sound good on their own.
sdg4vfx is offline
post #14 of 36 Old 04-27-2014, 12:34 PM
zieglj01's Avatar
Quoted: 938 Post(s)
Liked: 846
Actually I need to raise them up and was going to use a couple stands so I could just get these instead!
http://www.accessories4less.com/make-a-store/item/cambs70oak/cambridge-audio-s70-5-3-way-floorstanding-speakers-each-dark-oak/1.html#!specifications
Not a bad option
Who AM I
zieglj01 is offline
post #15 of 36 Old 04-27-2014, 12:37 PM
sdg4vfx's Avatar
Quoted: 81 Post(s)
Liked: 140
+1
sdg4vfx is offline
post #16 of 36 Old 04-27-2014, 12:42 PM - Thread Starter
jlpowell84's Avatar
Liked: 712
For 60 bucks more I would just do the tower option since I need to raise them up anyway...I may do this...
post #17 of 36 Old 04-27-2014, 12:44 PM - Thread Starter
jlpowell84's Avatar
Liked: 712
post #18 of 36 Old 04-27-2014, 12:45 PM
zieglj01's Avatar
Quoted: 938 Post(s)
Liked: 846
Bingo!
Who AM I
zieglj01 is offline
post #19 of 36 Old 04-27-2014, 12:46 PM - Thread Starter
jlpowell84's Avatar
Liked: 712
the jbls would have better power handling as I will be running off of the Denon 4520...
post #20 of 36 Old 04-27-2014, 12:51 PM
zieglj01's Avatar
Quoted: 938 Post(s)
Liked: 846
Go for it
Who AM I
zieglj01 is offline
post #21 of 36 Old 04-27-2014, 01:11 PM - Thread Starter
jlpowell84's Avatar
Liked: 712
Or like you said these look like the same thing but just low profile
http://www.amazon.com/JBL-Performance-Wall-Mountable-Bookshelf-Loudspeaker/dp/B000FK5Y74/ref=pd_sim_e_10?ie=UTF8&refRID=1K17BPZ1EC8WX2FTSV6Y
I know have some old JBL towers on surround (going bad) and they are 87db sensitive I think. Audyssey just sets my mains at like -8db and the surrounds at like 0db so lower sensitivity isn't all that bad
post #22 of 36 Old 04-27-2014, 03:05 PM
zieglj01's Avatar
Quoted: 938 Post(s)
Liked: 846
They can work out fine for you
Who AM I
zieglj01 is offline
post #23 of 36 Old 04-27-2014, 03:06 PM
raynist's Avatar
Quoted: 1257 Post(s)
Liked: 1196
I have the ported volt 8's and they keep up with my JTR 228's with no problem. They blend perfectly even at reference. I would build these and there would probably be no need to upgrade in the future.
Mine are in the ported .67 cu/ft box they sell.
Will get 2 more to complete a 7 speaker system. May build 5 additional for another system in my living room.
Before I got my 228's, I used these for mains and they were the best sounding speaker I had owned.
JTR (3 215 RT, 5 212HTR, 2 Growlers, 4 S2's)
PSA (4 Triax's, 3 210T's)
Behringer (4 B1200 Midbass Modules)
raynist is online now
post #24 of 36 Old 04-27-2014, 04:18 PM
Archaea's Avatar
Quoted: 2841 Post(s)
Liked: 2421
Archaea is online now
post #25 of 36 Old 04-27-2014, 08:27 PM - Thread Starter
jlpowell84's Avatar
Liked: 712
Thanks J!
I also found these. I think I might prefer direct radiating surrounds. Seems like a decent option a little better than a set of 200 JBL home line bookshelves? I can't say for sure, prob the same. But 95 db sensitive...
http://www.crutchfield.com/p_714RB600B/Klipsch-Reference-RB-600.html?tp=186
post #26 of 36 Old 04-27-2014, 08:39 PM
Quoted: 105 Post(s)
Liked: 74
Those look like a steal at 350
post #27 of 36 Old 04-27-2014, 09:03 PM
blazar's Avatar
Quoted: 716 Post(s)
Liked: 526
The behringer 15" or 12" are super cheap too and likely put out a lot more sound with great efficiency
Blazar!
blazar is offline
post #28 of 36 Old 04-27-2014, 09:28 PM
zieglj01's Avatar
Quoted: 938 Post(s)
Liked: 846
Klipsch tends to inflate their sensitivity specs - the sensitivity will average around 91db
Are you still riding on a merry-go-round?
Who AM I
zieglj01 is offline
post #29 of 36 Old 04-27-2014, 09:40 PM - Thread Starter
jlpowell84's Avatar
Liked: 712
post #30 of 36 Old 04-27-2014, 09:41 PM - Thread Starter
jlpowell84's Avatar
Liked: 712
A real LOL! Yes I want the volts but after my latest massive time spent with constructing treatments I have zero motivation for assembly! Even though it would be fairly easy and a couple hours
Reply Speakers
