Please advise! Boston A250/A225/A25 or Pioneer SP-PK52FS/C22/BS22 or Infinity Primus P163/P251/P153 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 25 Old 05-01-2014, 04:29 PM - Thread Starter
Yanec's Avatar
Quoted: 12 Post(s)
Hello,
Please advise, I am looking for a new speaker setup.
- The room size is about 500 square feet also I won't be able to use room treatment.
- What I do care about is the sound quality of music, movies are not so important to me, but I do need 5.1 as this is the only setup in the house. I listen to various types of music ranging from Jazz and Classics to Hip-Hop and Hardcore.
- I prefer the sound to be as close as possible (in this price range) to the unaltered sound aimed by the performer and the recording engineers.
- I am considering all options - new, refurbished or used gear.
- I live in a country where I do not have the chance to listen to any gear before buying. I have to order everything over the internet and get friends living in the UK or US ship it to me. I know about the warranty.
So far, I am looking at 3 possible setups in my price range:
1. Boston A225 center + Boston A250 mains pair + Boston A25 surround pair+ a sub matching the timber of these
2. Pioneer SP-PK52FS 5.0 + a sub matching the timber of these
3. Infinity Primus P163/P251/P153 + a sub matching the timber of these
I need advice on the sub-woofer too - which sub to get for music and to match the timber of the choice you advise?
Just from what I have read so far, I am leaning towards AJ's PK52FS, but which sub to get for them I lack the experience and the info to choose the correct match myself!
In addition, is there any setup that is more expensive (but not too much) worthy the additional price? Advice on all other options and generally any advice is very welcome.
Thanks in advance!
Y.K.
Yanec is offline
post #2 of 25 Old 05-02-2014, 03:53 AM - Thread Starter
Yanec's Avatar
Quoted: 12 Post(s)
Thanks for all the answers bellow to everybody!
Yanec is offline
post #3 of 25 Old 05-02-2014, 07:30 AM
zieglj01's Avatar
Quoted: 938 Post(s)
Liked: 846
Originally Posted by Yanec View Post
Any help, anybody?
None of them are bad - However, I would prefer the Boston set
Your call
Yanec likes this.
__________________________________________
Who AM I
Speakers > Snell K7, EOS 150SP
Receiver > Tascam PAR-200
zieglj01 is offline
post #4 of 25 Old 05-02-2014, 07:55 AM - Thread Starter
Yanec's Avatar
Quoted: 12 Post(s)
Ziglj01, Thanks for your answer! Any particular reasons why you would prefer the Boston over the Pioneer? Which "musical" sub would match the Bostons well?
Yanec is offline
post #5 of 25 Old 05-02-2014, 08:30 AM
crazyrob425's Avatar
Quoted: 443 Post(s)
Liked: 337
Subwoofers do not timber match the speakers.
What is your budget for a subwoofer? The options vary depending on how much you can spend.
Yanec likes this.
crazyrob425 is offline
post #6 of 25 Old 05-02-2014, 08:51 AM
zieglj01's Avatar
Quoted: 938 Post(s)
Liked: 846
Pioneer is good and better than some - however, there is only so much
that the driver/speakers can give
No bad choices on your list.
If you have the budget - then look at the SVS SB-1000 sub (sealed)
http://www.svsound.com/subwoofers/sealed-box/SB-1000#.U2OxAPldUxo
Or, Reaction Audio BPS-212 subwoofer
http://reaction-audio.myshopify.com/products/bps-212-turbo-powered-subwoofer
Yanec likes this.
Who AM I
zieglj01 is offline
post #7 of 25 Old 05-02-2014, 09:00 AM - Thread Starter
Yanec's Avatar
Quoted: 12 Post(s)
crazyrob425 Thanks for the clarification! I am just trying to get everything right. My budget for the sub is $400, absolute maximum $500.
Yanec is offline
post #8 of 25 Old 05-02-2014, 09:07 AM - Thread Starter
Yanec's Avatar
Quoted: 12 Post(s)
Thanks again zieglj01!
I will check these subs out! One more question - what are the differences in overall sound signature between the Pioneer and the Boston set? The reason I liked the Pioneers is online reviews saying how neutral they are is the Boston also neutral just better in terms of the drives used? I am double checking as I will not have the chance to listen before I buy and it is not cheap to ship and return such a package.
Any other suggested options around this price?
Thanks for all your help!
Yanec is offline
post #9 of 25 Old 05-02-2014, 09:46 AM
zieglj01's Avatar
Quoted: 938 Post(s)
Liked: 846
I have owned the Pioneer speakers and some Infinity Primus speakers.
I have owned several Boston speakers, however not the current A ones.
Based on the former CR and CS Boston speakers, I prefer them over
the Pioneer and Infinity Primus series. The Boston A series is a re-work
of their budget entry lines - and their reviews have been good - they are
more positive over the CS and CR series.
Boston's sound signature, tends to be robust and vivid, with-out being
forward, sharp or aggressive in nature - and they are not laid back.
Do not base your choice/decision on me, or anyone else - we can not
guarantee you, how a speaker will sound to your ears. Also, you tend to
have a bigger than average room - and you stated that there will be no
room treatments.
The Boston A250 will be able to take some power, and they are built
good for the price.
Depending on your max budget for 5.1 - I may have more recommendations.
Yanec likes this.
Who AM I
zieglj01 is offline
post #10 of 25 Old 05-02-2014, 09:56 AM - Thread Starter
Yanec's Avatar
Quoted: 12 Post(s)
room treatments.
good for the price.
You are really helpful - this really adds value to my future choice given the situation that I can't check these out initially!!
My budget is about $1500 for the 5.0 plus the sub, without the shipping and customs. If there are any really good sets up to 2k I might find some additional budget as I buy speakers once in 10 years so I want to get the maximum bang for the buck.
One thing I really dream of hearing in closer to natural sound is piano - it sounds so flat and artificial with cheap ht systems
Yanec is offline
post #11 of 25 Old 05-02-2014, 10:05 AM
Elihawk's Avatar
Quoted: 1015 Post(s)
Liked: 860
A ported sub will give you more Umph, and maybe hit lower (so better for HT in a big room)...sealed subs typically don't get quite as loud and won't hit quite as low, but maybe have better accuracy/fidelity. For music mostly, I think a sealed sub is the way to go. The SVS SB1000 might be a great start...499.00 shipped from SVS!
Yanec likes this.
Set up #1: EMP e5ti, e5Ci, and EMP e5Bi surrounds, Outlaw LFM1 Plus sub, EMP 10i10i sub
Set up #2: Def Tech SM450, CLR2002, SLS Qline surrounds and Klipsch 12wD sub
Set up #3: Philharmonics- BMR in a 2.0 system, music only
Elihawk is online now
post #12 of 25 Old 05-02-2014, 10:12 AM
zieglj01's Avatar
Quoted: 938 Post(s)
Liked: 846
If you have room to do a vertical bookshelf center - then I would look at
Monitor Audio Silver RX-1 speakers >>> they will have good detail and
definition, and do a real good job for music - and can handle HT
2 pair will be $1000 - use 1 each as a center channel and keep a spare,
it would be worth it. 3 pair is $1500
Black is sold out - still have Rosenut and Walnut
http://www.saturdayaudio.com/picturepages/monitor_special.htm
You can always buy some budget surrounds - and do music in 2.1
or 3.1 mode
http://www.accessories4less.com/make-a-store/item/focalsibprblk/focal-sib-5-2-way-satellite-loudspeakers-pair-gloss-black/1.html
Who AM I
zieglj01 is offline
post #13 of 25 Old 05-02-2014, 10:19 AM - Thread Starter
Yanec's Avatar
Quoted: 12 Post(s)
I have been looking at several subs suggested here and from online reviews:
SVS SB100
Dayton Audio 1200
Acoustech PL200
BIC F12
HSU - if I find a model fitting my budget and needs
Any suggestions on these - which should I skip, which should I consider further?
Yanec is offline
post #14 of 25 Old 05-02-2014, 10:22 AM
zieglj01's Avatar
Quoted: 938 Post(s)
Liked: 846
I would aim for the $500 line of subwoofers
Also, if you like that Piano - and if you can handle the looks >
The JBL Studio 530, is one of the best musical speakers that
I have owned for the price
http://www.amazon.com/JBL-Studio-530-Bookshelf-Loudspeakers/dp/B00622STI0/ref=sr_1_1?ie=UTF8&qid=1399047576&sr=8-1&keywords=jbl+studio+530
http://www.amazon.com/JBL-Studio-520CBK-Channel-Speaker/dp/B00622SUHK/ref=sr_1_1?ie=UTF8&qid=1399047813&sr=8-1&keywords=jbl+studio+520
Yanec likes this.
Who AM I
zieglj01 is offline
post #15 of 25 Old 05-02-2014, 11:06 AM - Thread Starter
Yanec's Avatar
Quoted: 12 Post(s)
So this gives me the following options so far, totaling a budget a bit over $1500:
For the 5.0
2. JBL Studio 530 x 4 + JBL center 520
3. Monitor Audio RX1 x 4 + some center - which should I go for?
For the LFE:
1. HSU VTF-1 MK2
2. Reaction Audio BPS 212 Turbo
3. SVS SB 1000
Any combinations you would prefer out of these options?
Thank you so much once again!!!
Yanec is offline
post #16 of 25 Old 05-02-2014, 11:08 AM - Thread Starter
Yanec's Avatar
Quoted: 12 Post(s)
Elihawk Would the HSU VTF-1 MK2 be a good choice too or the SVS is preferable? Thanks!
Yanec is offline
post #17 of 25 Old 05-02-2014, 11:13 AM
zieglj01's Avatar
Quoted: 938 Post(s)
Liked: 846
My preference is >
(1) the JBL
(2) the Monitor Audio
No, hands-down winner between the 2
Subwoofer on sale till May 8th >
Outlaw Audio LFM-1 Plus
http://www.outlawaudio.com/products/lfm1plus.html
If you do not buy Outlaw - then I lean towards >
Reaction Audio, or SVS
Yanec likes this.
Who AM I
zieglj01 is offline
post #18 of 25 Old 05-02-2014, 11:27 AM
Quoted: 443 Post(s)
Liked: 337
An amazing deal right now for the next week is the Outlaw LFM-1 Plus. It normally sells for $600 plus shipping, but they are selling it this week for $500 shipped.
If I had $500 to spend on a subwoofer that is what I would go with. Its an great deal at its price point right now
The Outlaw LFM-1 Plus is similar to the HSU VTF-2 (just a different port location)
Yanec likes this.
post #19 of 25 Old 05-02-2014, 12:26 PM - Thread Starter
Yanec's Avatar
Quoted: 12 Post(s)
Thanks! The Outlaw is a bit oversize next to my "Provence" style white furniture and I will be buying in 30 days, so I will miss the promotion. But it really seems to have great reviews and to be a practical solution in terms of placement options in an unevenly furnished room as mine.
I will take your advise on the JBLs since you owned the Pioneers and other speakers noted here and find these more musical. I would guess they do not have problems with the mids as you said they do justice to the piano. I will do some more reading and "comparing" on the Reaction Audio 212 Turbo and the SVS SB100 so I can choose one of these that matches jazz and classics better.
You made my day thanks!
Y.K.
Yanec is offline
post #20 of 25 Old 05-02-2014, 12:31 PM
zieglj01's Avatar
Quoted: 938 Post(s)
Liked: 846
I like the Piano, Violin, Guitar, Saxophone, and Trumpet - and the JBL
does a good job with these and voices - plus the JBL has good bass.
Enjoy the Adventure.
Yanec likes this.
Who AM I
zieglj01 is offline
post #21 of 25 Old 05-02-2014, 01:19 PM - Thread Starter
Yanec's Avatar
Quoted: 12 Post(s)
Thank you! The adventure actually just begins and I believe it will be full of learning but even more of audio pleasure. Any advice on the available Mordaunt, they seem to have excellent prices, or should I stop wondering and stick with the Studio 530? : http://www.ebay.com/sch/i.html?_trksid=p2050601.m570.l1313.TR0.TRC0.H0.Xmordaunt&_nkw=mordaunt&_sacat=0&_from=R40
Yanec is offline
post #22 of 25 Old 05-02-2014, 01:55 PM
zieglj01's Avatar
Quoted: 938 Post(s)
Liked: 846
I can not speak for the Mordaunt Short Mezzo - however, the word
is good on them. I would not go lower than their Mezzo line.
As far as wondering around - that is up to you.
Yanec likes this.
Who AM I
zieglj01 is offline
post #23 of 25 Old 05-02-2014, 05:13 PM - Thread Starter
Yanec's Avatar
Quoted: 12 Post(s)
Now I have read thru all available reviews and I am definitely going for a pair of these! I am really grateful that you suggested these.Now there is one problem - I just checked can't physically fit a rear pair of these in my room, what speakers can match in timber the Studio 530 for 5.1 DSD / SACD music and for movies?  Will the JBL Studio 130 be a match? Also will it be OK to fit the Studio 520 above the 50" TV - there is no way to get it under it or in front of it given my furniture.
Yanec is offline
post #24 of 25 Old 05-02-2014, 07:00 PM
zieglj01's Avatar
Quoted: 938 Post(s)
Liked: 846
Only the Studio 5 series will timbre match with each other - however, the Studio 130
or Studio 220 for surrounds will be close..
You can put the Studio 520 center above the TV, if you can angle it down towards
your head
Yanec likes this.
Who AM I
zieglj01 is offline
post #25 of 25 Old 05-02-2014, 07:19 PM - Thread Starter
Yanec's Avatar
Quoted: 12 Post(s)
your head
I hope good room correction software ( I am also buying an AVR - can use recommendation) will help get the 130 closer to the 520 as it is the only surround speaker that will fit my room and I hope 5.1 music will not suffer...many hopes smile.gif
Thanks for all your help and have a great day/evening!
Y.K.
Yanec is offline
Reply Speakers
