Planning to buy Polk RTiA1; question about compatibility - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 05-09-2014, 07:22 PM - Thread Starter
imeem's Avatar
I notice that the back of the RtiA1 has 2 pairs of inputs, meant for bi-wiring. Do I have to do this? If not, does it matter which input I use?
My amp is a Technics su-z550 and the watts per channel is 70 (8 ohm). Is it decent enough to power the speakers which recommends 20-120 watts?
link to my amp's specs: http://www.manualscenter.com/manuals/technics/suz550-service-manual.html . Scroll down to last picture.
imeem is offline
post #2 of 8 Old 05-10-2014, 07:55 PM
XStanleyX's Avatar
Liked: 1270
Forget the bi-wiring and just use either the top or bottom posts with the metal bridges in place. Should be enough wattage unless you like it super duper loud.
imeem likes this.
XStanleyX is offline
post #3 of 8 Old 05-11-2014, 06:41 AM
commsysman's Avatar
Quoted: 1080 Post(s)
Liked: 569
BI-wiring is not needed until you get into very large speakers that draw a lot more power than you will need.
Putting 2 sets of terminals on there is silly, if you ask me.
Your amplifier spec sheet actually says 50 watts per channel at 8 ohms, if you look at the DIN spec sheet.
It will drive those speakers, but it will be marginal in terms of distortion/ sound quality.
The distortion specs given are with a load resistor connected, which is a joke.
Actual distortion, with a real speaker connected, will be 10 to 100 times higher; a speaker is a much more difficult load for the amplifier than a resistor.
Something like the Music Hall 15.3 or NAD C326BEE will sound much better much IMO.
commsysman is offline
post #4 of 8 Old 05-11-2014, 07:19 AM
FMW
FMW's Avatar
Quoted: 1653 Post(s)
Liked: 1687
Some confusion here. Bi-wiring has nothing to do with power. It is the practice of sending two wires from the same amplifier terminal to two separate terminals on the speaker. In effect it just combines the two sides of the crossover at the amplifier terminal rather than at the speaker terminal. It accomplishes nothing.
Passive biamplification, on the other hand, adds another amplifier to the mix and connects each side of the crossover network to separate amplifiers. Since this sends full power to both sides of the crossover network it accomplishes almost nothing compared to bi-wiring which accomplishes absolutely nothing.
Speaker manufacturers have done a disservice to beginner audio enthusiasts by including the bi-wire terminals. OP. Ignore anything that says bi-wrie or bi-amplfy. These activiies won't produce anything meaningful for you.
imeem likes this.
FMW is offline
post #5 of 8 Old 05-12-2014, 04:26 AM - Thread Starter
imeem's Avatar
the first page isn't exactly my amplifier. you have to scroll down to the last picture. I have no idea why different regions have different models. But regardless, i may buy a new amplifier in the future tho, but not at the same time as the speakers
imeem is offline
post #6 of 8 Old 05-12-2014, 11:55 AM
riley08's Avatar
Quoted: 12 Post(s)
i have the RTIA1's as my fronts and they are superb! i am using the denon 1513 75W/channel and it sounds incredible:)
i have it connected to the bottom terminals and it sounds good!
mains-POLK RTI6
center-POLK CSI3
surround-POLK RC65 INWALL
sub-DAYTON 1200
receiver-YAMAHA RX-V475
riley08 is offline
post #7 of 8 Old 05-12-2014, 06:37 PM - Thread Starter
imeem's Avatar
when you are close to them, how badly do they hiss? I'm planning to use them in a near-fielded scenario (computer speakers.). I somewhat learned to live with the hissing, but it's nice when they don't.
imeem is offline
post #8 of 8 Old 05-13-2014, 12:00 PM - Thread Starter
imeem's Avatar
Good news, I was going to the store to check then out and found out that they were on sale for $229. I had the store help me order a pair that wasn't used. In that mean time, i can check online for some speaker wires.
imeem is offline
Reply Speakers
