Need best CLEAR center channel speaker. Price Max: $200 :) - AVS Forum | Home Theater Discussions And Reviews
 2Likes
  • 1 Post By afrogt
  • 1 Post By FMW
post #1 of 21 Old 05-09-2014, 08:42 PM - Thread Starter
DEN7ER's Avatar
Hey guys can't stand my old sony center channel speaker... Hard to hear dialogue clearly sometimes. Really want great, crisp vocal clarity with overall smooth sound. High def audio system deserves better smile.gif
Need help, thanks!
DEN7ER is offline
post #2 of 21 Old 05-09-2014, 08:51 PM
BuddTX's Avatar
Quoted: 100 Post(s)
Liked: 74
Look at Pioneer Speakers designed by Andrew Jones
SP-C21 (1st Generation)
SP-C22 (2nd Generation)
I have not heard theC22, but the C21 is Awesome! However, check the dimensions before you buy. I have seen the C21 as low as 49.99.
http://www.pioneerelectronics.com/PUSA/Home/Speakers/Home+Theater+Speakers
Amazon, Fry's, Newegg have them on sale regularly.
BuddTX is offline
post #3 of 21 Old 05-09-2014, 09:11 PM
afrogt's Avatar
Quoted: 1053 Post(s)
Liked: 755
if you're gonna replace your center you need to get match front speakers too.
you want the front 3 speakers to be timbre matched.
darthray likes this.
Afro GT
afrogt is online now
post #4 of 21 Old 05-10-2014, 11:04 AM
sdg4vfx's Avatar
Quoted: 81 Post(s)
Liked: 140
+1 ^^^^
sdg4vfx is offline
post #5 of 21 Old 05-10-2014, 04:32 PM
jaeelarr's Avatar
Quoted: 46 Post(s)
Liked: 42
I understand the concept, but people make this a bigger deal than it is. If the OP wants a new center only, then there is nothing wrong with that.
jaeelarr is offline
post #6 of 21 Old 05-10-2014, 04:47 PM
zieglj01's Avatar
Quoted: 938 Post(s)
Liked: 846
I also agree - that you should timbre (voice tone) match the front 3 channels
Just $27 over budget, if you can swing it
Pioneer Center C22
http://www.amazon.com/Pioneer-SP-C22-Designed-Channel-Speaker/dp/B008NCD2EI/ref=sr_1_4?s=electronics&ie=UTF8&qid=1399761799&sr=1-4&keywords=pioneer+speakers
Pioneer BS22 speakers
http://www.amazon.com/Pioneer-SP-BS22-LR-Designed-Bookshelf-Loudspeakers/dp/B008NCD2LG/ref=sr_1_1?s=electronics&ie=UTF8&qid=1399761999&sr=1-1&keywords=pioneer+speakers+bs22
__________________________________________
Who AM I
Speakers > Snell K7, EOS 150SP
Receiver > Tascam PAR-200
zieglj01 is offline
post #7 of 21 Old 05-11-2014, 02:13 AM - Thread Starter
DEN7ER's Avatar
I'll check those pioneers out you guys mentioned, thanks!! I'm sure I'll replace the fronts eventually I just want clearer natural dialogue ASAP . Thanks fellas!
DEN7ER is offline
post #8 of 21 Old 05-11-2014, 08:00 AM
commsysman's Avatar
Quoted: 963 Post(s)
Liked: 521
You can get 2 pairs of the Dayton B652 speakers for only $80 from Parts Express, and use 3 of them.
Those are amazingly good speakers, for a ridiculously low price.
I had a set of Boston speakers with a Cambridge amplifier for my 60" Sony and CD player in my den, and replaced them with the Daytons.
It was a big improvement, despite the fact that the Boston speakers cost 3 times as much.
commsysman is online now
post #9 of 21 Old 05-11-2014, 08:11 AM
FMW
FMW's Avatar
Quoted: 1652 Post(s)
Liked: 1681
+1. In my experience most center speakers at the low and medium prices aren't well "timbre matched" anyway. The best timbre matching, aside from using 3 identical speaker systems is to leave the center channel speaker out of the system entirely as long as you can watch from directly in front of the TV..
blazar likes this.
FMW is offline
post #10 of 21 Old 05-11-2014, 09:08 AM
zieglj01's Avatar
Quoted: 938 Post(s)
Liked: 846
Here is another option - Buy 2 pairs of the Teac, and use one as a center, and have
a spare speaker.
http://www.accessories4less.com/make-a-store/item/teaclsh265a/teac-ls-h265-2-way-5-1/4-in-reference-bookshelf-speakers-pair/1.html
A subjective review here.
http://www.cnet.com/news/teac-ls-h265-the-little-speaker-that-could/
Now if you are able to expand soon in the future - and you plan to timbre (voice tone)
match around the center speaker - then look at HTD Level Three
The center
http://www.htd.com/Products/level-three-speakers/Level-THREE-Center-Channel-Speaker
The bookshelf
http://www.htd.com/Products/level-three-speakers/Level-THREE-Bookshelf-Speakers
Also, Infinity P351 center
http://www.amazon.com/Infinity-Primus-PC351-Three-way-Center-Channel/dp/B0044D1788/ref=sr_1_4?ie=UTF8&qid=1399821936&sr=8-4&keywords=jbl+center+channels
http://www.crutchfield.com/S-ZZWVi47BVse/p_108PC351BK/Infinity-Primus-PC351.html
The bookshelf P163
http://www.amazon.com/Infinity-Primus-Two-way-Bookshelf-Satellite/dp/B0045NCB32/ref=sr_1_1?ie=UTF8&qid=1399821998&sr=8-1&keywords=infinity+p163
Who AM I
zieglj01 is offline
post #11 of 21 Old 05-11-2014, 09:40 PM - Thread Starter
DEN7ER's Avatar
Hmmmm interesting, thanks ZEIG.
So now I think I'm between the pioneer c22 or the Polk CS10. (?) was almost talked into the Difinitive Technology procenter 1000 for $200 but thought I'd research it some more... What do you guys think?
DEN7ER is offline
post #12 of 21 Old 05-11-2014, 09:45 PM
cel4145's Avatar
Quoted: 2653 Post(s)
Liked: 2984
Go with the one you'll be comfortable with buying the matching left and right later on. It will really will make your whole front soundstage sound better, and that leaves you the best future upgrade option.
Living room HT: Energy RC-50, Ascend Sierra Horizon w/RAAL, Ascend Sierra 1, PSB Imagine XA | PSA V1500 and CHT SS 18.1 | Denon X4200W | modified Dayton SA1000
Other rooms: CBM-170 SE | SVS SB-1000 | Audio-GD NFB-11 | Parasound Zamp | JBL LSR305
Headphone & Portable AKG K7XX | NAD HP50 | AKG K550 | Soundmagic E50 & E80 | DX50 | E12 | X1
cel4145 is offline
post #13 of 21 Old 05-12-2014, 01:33 PM
blazar's Avatar
Quoted: 716 Post(s)
Liked: 526
In cheap speakers, i would consider strongly a ribbon tweeter based speaker. Very clear "airy" highs.
Blazar!
blazar is offline
post #14 of 21 Old 05-12-2014, 04:54 PM
diceman1000's Avatar
Quoted: 29 Post(s)
Liked: 25
BIC DVCLR 62, absolutely great sounding center... it is HUGE though, 7+ H x 20+ L x 10+ D
Sent from my SCH-R760X using Tapatalk
diceman1000 is offline
post #15 of 21 Old 05-31-2014, 05:22 PM
NuSoardGraphite's Avatar
Quoted: 326 Post(s)
Liked: 298
I am also researching center speakers to possibly replace my less-than-adequate Sony center channel. I have the Sony SS-CN5000 center channel. I also have the Sony SS-B3000 "bookshelf" speakers as mains and the B1000 bookshelf speakers as surrounds. I am very happy with the performance (based on what I paid) of the mains and surrounds, but the center seems like it underperforms to me. I'm looking for something more robust.
Sony has released a new line of speakers, but I'm afraid to check out the new Sony speaker in case I get the same problems. I'm looking for something a bit more efficient (above 90db) and that can provide clear and audible dialogue with authority. It doesn't have to play super low...I would like to cross over at about 80-100hz. My mains can handle anything below that (and I will be getting a sub soon anyway) but yeah, very clear and precise mid-range is what I'm looking for.
Does anyone have an experience with Center speakers with multiple mid-woofers (more than two) such as the Cerwin Vega SL-45C ( http://www.amazon.com/Cerwin-Vega-SL45C-Quad-Speaker/dp/B00J8SN3D6/ref=sr_1_23?s=electronics&ie=UTF8&qid=1401576249&sr=1-23&keywords=Center+channel+speakers )
The Yamaha NS-310BL ( http://www.amazon.com/Yamaha-NS-C310BL-Bass-Reflex-Center-Speaker/dp/B001PZ674C/ref=sr_1_5?s=electronics&ie=UTF8&qid=1401576249&sr=1-5&keywords=Center+channel+speakers )
or the Infinity Primus PC351 ( http://www.amazon.com/Infinity-Primus-PC351-Three-way-Center-Channel/dp/B0044D1788/ref=sr_1_8?s=electronics&ie=UTF8&qid=1401576249&sr=1-8&keywords=Center+channel+speakers )
I'm wondering if the addition of more woofer cones enhances the mid-range in these centers compared to others with only 2 woofers.
Stand tall and shake the heavens...
NuSoardGraphite is offline
post #16 of 21 Old 05-31-2014, 06:44 PM
blazar's Avatar
Quoted: 716 Post(s)
Liked: 526
A horn loaded center channel or in general horn loaded cinema speakers are a great choice in general for high efficiency applications at a good price point.
There is a reason why almost all commercial theaters go with horn loaded systems...
Blazar!
blazar is offline
post #17 of 21 Old 06-02-2014, 12:47 PM
Quoted: 326 Post(s)
Liked: 298
I was afraid of this.
I'm not ready to upgrade my entire package yet. The other speakers in my system are dome tweeters, so my center will have to be a dome tweeter as well. I understand that having mix-matched brands can create a slight difference in the tonal characteristics of the speakers. Completely changing the type of tweeter is likely to have a much bigger impact in that area.
However when I am ready to upgrade all of my speakers, I am seriously considering going to horn tweeters for this reason (efficiency)
post #18 of 21 Old 12-23-2014, 09:53 PM
IceCold81's Avatar
Just posted a thread today myself.... I'm looking at upgrading across my entire front side for speakers L/R/C
Looking at a $1000 budget, considering the Cerwin Vegas XLS-12 L/R and either the SL-45C or the XLS-6C for the center.... Still can't come to terms on it... But I think I'm going to pull the trigger on something one way or another tonight or tomorrow.
ID:	438322   Click image for larger version
ID:	438330   Click image for larger version
IceCold81 is offline
post #19 of 21 Old 12-24-2014, 10:43 PM
blazar's Avatar
Quoted: 716 Post(s)
Liked: 526
That looks like a very reasonable configuration for the price. At least partially horn loaded designs will give you the dynamic range you want while EQ such as Audyssey's EQ curve should take care of any harshness in the overall response.
I'm not sure about the overall benefits and quality of cerwin vega over any other brands in that range.
Blazar!
blazar is offline
post #20 of 21 Old 12-24-2014, 10:45 PM
blazar's Avatar
Quoted: 716 Post(s)
Liked: 526
Actually the midrange and low bass regions really can benefit from good horn loaded design as well. I am obviously a lover of this sound since I own some of the "highest end" horn speakers on the market. So my opinion on this will be very much biased. If you heard my final setup, you would be biased too
Blazar!
blazar is offline
post #21 of 21 Old 12-25-2014, 04:45 AM
bluewizard's Avatar
Quoted: 1637 Post(s)
Liked: 963
If you want speakers that can really cut through the clutter and have a strong presence in the voice/mid+high range, the horn loaded Center and Front are worth considering.
But, they are not exactly giving these away -
Klipsch Reference 52 II ($296/each) -
http://www.crutchfield.com/p_714RC52...-RC-52-II.html
Klipsch Reference 62 II ($399/each) -
http://www.crutchfield.com/p_714RC62...II-Cherry.html
Here, if you scroll down, you can see the entire Klipsch Reference II series line up -
http://www.klipsch.com/reference-ii-...heater-systems
The Infinity Primus PC351 is a good center in its price range but it is BIG. Make sure you can handle the size.
Infinity Primus PC351 ($199/each) -
http://www.crutchfield.com/p_108PC35...mus-PC351.html
I think we need to know specifically what Sony Center you have now, and we need to know the rest of your system. That will lend perspective to our recommendations.
In the short term, there is nothing wrong with a mismatch between the Front and Center. But in the longer run, you are going to want them Tonally matched. So, whatever decision you make now on the Center, somewhat dictates that that is the direction you go in the future. For example, if you buy the Klipsch Reference Center, that implies when you buy new front, they will also be Klipsch Reference speakers.
Unless you want to consider this new Center speaker a throw-away. Use for now, and ditch it later when you replace the Front Three (left/center/right). Though best to make a decision now that directs your choice in the future, so you aren't wasting money.
So, as well as the equipment you are using now, we need some sense of where it is you intend to go in the future. The nature of the system for the future and how it will be used. Some of the suggested speakers are very big. That would be fine in a larger home cinema room, but a bit overwhelming in the average living room, especially if you are married.
So, we need to understand both short term and long term goals including your budget.
Keeping in mind, the choice you make now, somewhat dictates the choice you will have to make later.
Steve/bluewizard
bluewizard is online now
Reply Speakers
