Need best bookshelves I can find for $400 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 15 Old 05-10-2014, 02:12 PM - Thread Starter
Potential456's Avatar
I'm looking for a set of 2 bookshelf speakers under $400 to replace my current 5.0 setup. I'm moving to a smaller place and would like to have a higher quality stereo setup, especially given I don't notice the surround much as it is.
I would like to be able to grow these 2 into a larger set, eventually. Would prefer a large soundstage and "lively" sound. Not looking for towers or bars. Can be used or new. Would be a bonus if the speakers looked good.
Usage: 70% Movies/TV, 15% Gaming, 15% Music
Room: ~ 15' x 15' , speakers can be away from wall
Receiver: Marantz SR5007
Subwoofer: Rhythmik LV12R
Current Speakers: Dayton Audio HTS-1200B (http://www.amazon.com/Dayton-Audio-HTS-1200B-Theater-Speaker/dp/B000I7U1OU)
Options I've considered:
Aperion Intimus 5B
Ascend Acoustics CBM-170 SE
Ascend Acoustics HTM-200 SE
Bowers and Wilkins 685 v1
Chane Arx A1rx-c (once they're back in stock)
Hsu Research HB-2 MK2 Horn
Paradigm Atom Monitor Series 7
Open to other suggestions, thanks!
Potential456 is offline
post #2 of 15 Old 05-10-2014, 02:52 PM
afrogt is offline
post #3 of 15 Old 05-10-2014, 05:22 PM - Thread Starter
Hmm, out of those the KEF looks the most intriguing... how does it compare to the other ones I've listed?
post #4 of 15 Old 05-10-2014, 07:43 PM
JimWilson's Avatar
Quoted: 1501 Post(s)
Liked: 1991
Aperion Intimus 5B
If by "lively" you mean something with strong high frequencies the Arx and HSU should probably move toward the top of your list. I've heard the Arx and they do present a lot of detail in the upper range. Virtually anything with a horn tweeter (HSU) will have a lot of presence as well.
If you take yourself too seriously, expect me to do the exact opposite
JimWilson is offline
post #5 of 15 Old 05-11-2014, 12:04 AM
ambesolman's Avatar
Quoted: 1096 Post(s)
Liked: 919
+1 for hsu. Really like mine in the rosenut finish
ambesolman is online now
post #6 of 15 Old 05-11-2014, 01:53 AM
shadyJ's Avatar
Quoted: 1330 Post(s)
Liked: 1351
The Hsu speaker is good, but the treble is not voiced hot. Not all horn systems sound like Klipsch. If you want a lively and crisp top end, I would be looking at Klipsch Reference RB-51s.
shadyJ is offline
post #7 of 15 Old 05-11-2014, 06:29 AM
commsysman's Avatar
Quoted: 1080 Post(s)
Liked: 567
I suggest the Focal 705V speakers, which are only $350 per pair from Music Direct.
The Wharfedale Diamond 10.1 and 10.2 are also very good (and look very nice).
The Cambridge SX-50 are also good, and only $250/pair.
commsysman is offline
post #8 of 15 Old 05-11-2014, 11:48 AM
Quoted: 75 Post(s)
Liked: 112
I personally like Monitor Audio and there are some good deals on the silver line out there. Another brand for you to add to the list is Axiom.
rnatalli is offline
post #9 of 15 Old 05-11-2014, 12:44 PM
zieglj01's Avatar
Quoted: 1555 Post(s)
Liked: 1402
I for sure, would look at the Snell K5 speakers - you can move them to surrounds later
or, even sell them. - Snell for sure, made some good stuff.
http://www.ebay.com/itm/SNELL-TYPE-K-5-SPEAKERS-/121337310807?pt=Speakers_Subwoofers&hash=item1c40446e57
__________________________________________
Who AM I
Speakers -- Snell K7 > Q Acoustics 3020 > Boston VS240
Receiver -- Integra 50.2
zieglj01 is online now
post #10 of 15 Old 05-11-2014, 03:14 PM
beaveav's Avatar
Quoted: 525 Post(s)
Liked: 669
Many good suggestions so far.
I would suggest you also consider something a little different: In that price range, look around for used speakers in really good shape. If you're patient, lucky, and/or persistent, you'll be able to find a pair of MSRP $800 or so speakers for $400, give or take. Look on eBay, Craigslist, USAudioMart, Audiogon, etc. It opens your possibilities up to even nicer speakers, like the NHT Classic Three, Ascend Sierra 1, etc., both of which can sometimes be found used in the $400 range.
Also, consider PSB B5 or B6. Both are over your price range but can be found gently used for quite a bit under $400.
Semi-retired Technology Insider.
Insist on Quality Posting.
beaveav is offline
post #11 of 15 Old 05-11-2014, 04:17 PM
afrogt's Avatar
Quoted: 1363 Post(s)
Liked: 946
you can get PSB B5 under $400 and B6 not too much over $400 from Saturdayaudio.com
beaveav likes this.
Afro GT
afrogt is offline
post #12 of 15 Old 05-11-2014, 04:23 PM
beaveav's Avatar
Quoted: 525 Post(s)
Liked: 669
Good find, afrogt. At those prices they're definitely worth considering if the OP wants new speakers.
Also, I saw a used pair of the B5's on Audiogon for $270.
beaveav is offline
post #13 of 15 Old 05-11-2014, 06:56 PM
Codeman0535's Avatar
Polk RTiA3's
Codeman0535 is offline
post #14 of 15 Old 05-11-2014, 08:47 PM
cel4145's Avatar
Quoted: 2662 Post(s)
Liked: 3001
Living room HT: Energy RC-50, Ascend Sierra Horizon w/RAAL, Ascend Sierra 1, PSB Imagine XA | PSA V1500 and CHT SS 18.1 | Denon X4200W | modified Dayton SA1000
Other rooms: CBM-170 SE | SVS SB-1000 | Audio-GD NFB-11 | Parasound Zamp | JBL LSR305
Headphone & Portable AKG K7XX | NAD HP50 | AKG K550 | Soundmagic E50 & E80 | DX50 | E12 | X1
cel4145 is offline
post #15 of 15 Old 05-11-2014, 09:44 PM
losservatore's Avatar
Quoted: 2618 Post(s)
Liked: 2401
1+ for the KEF Q100
losservatore is offline
Reply Speakers
