mixing and matching speakers - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 05-28-2014, 04:14 AM - Thread Starter
Bretzy1990's Avatar
Got a pair of klipsch f-30 floor standers. Like them but would like to add to my system. Looking for some bookshelf speakers that I can add along with them. But my question is, if I get speakers that arnt klipsch, will they possibly not blend well. I know klipsch sorta have their own sound being horn loaded. I'm looking at the infinity p163 bookshelf. May end up using just as straight stereo with all 4 speakers and then sometimes use the bookshelves as surround speakers.
Bretzy1990 is offline
post #2 of 4 Old 05-28-2014, 09:01 AM
jaeelarr's Avatar
Quoted: 47 Post(s)
Liked: 43
Some people swear by timbre matching. I dont find it that serious. It really depends on what your ears hear.
I will say this though, matching a non-horn tweeter with the Klipsch might be more noticeable than not.
jaeelarr is offline
post #3 of 4 Old 05-28-2014, 09:20 AM
kamouflage's Avatar
Quoted: 145 Post(s)
Liked: 94
Good points and I agree with both of them. Although I haven't heard it myself I can't imagine horn/dome/ribbon tweeters being intermingled sounding too good across the front sound stage.
If you have some type of room correction on your receiver you should be ok if you're not really picky. I upgraded my Front Left/Right from B&W to Paradigm and still have my B&W center. After I ran Audyssey again on my receiver I can't tell that they're different brands of speakers when watching movies. For multi-channel music I can tell a slight difference with Audyssey and if it's Direct Mode Multi-Channel it sounds pretty bad.
PSN ID: javant86
Xbox Live: PikturePerfekt
kamouflage is offline
post #4 of 4 Old 05-28-2014, 09:28 AM
crazyrob425's Avatar
Quoted: 445 Post(s)
Liked: 338
Minimumly I suggest that people match their front 3 speakers. I have spent time with a system that has a missed match center and its obivious to me. The necessity of matching surrounds I have found to only be necessary when critically listening to multichannel music recording
crazyrob425 is offline
Reply Speakers
