Used Klipsch Synergy 5.1 thoughts? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 05-28-2014, 06:24 AM - Thread Starter
magicc8ball's Avatar
I just joined this site and love it so far, so much information it is easy to get overwhelmed.
My question is I have an opportunity to purchase a used Synergy 5.1 system for 350 and wanted to get some opinions on it.
What is in the system is:
4-S-20
1 C-20
1 KW-100
Currently all I have is a pair Polk Audio R50 attached to a Yamaha Aventage 720. I have never had a true 5.1 system in my life so this would be a big change. I am just not sure if the money is worth it and if I would miss my R50's.
I would love to hear you all share your thoughts.
magicc8ball is offline
post #2 of 7 Old 05-28-2014, 06:57 AM
FMW
FMW's Avatar
Quoted: 1653 Post(s)
Liked: 1687
Your best bet is to listen to it and then you can decide for yourself.
FMW is offline
post #3 of 7 Old 05-28-2014, 08:11 AM
tezster's Avatar
Quoted: 517 Post(s)
Liked: 401
Are those model #'s correct? Aren't the S-20's surround speakers? It would be quite strange to have 4 of them in a 5.1 setup.
magicc8ball likes this.
tezster is offline
post #4 of 7 Old 05-28-2014, 08:51 AM - Thread Starter
Yes those are the right part number and yes they are the surround speakers.
post #5 of 7 Old 05-28-2014, 09:37 AM
crazyrob425's Avatar
Quoted: 445 Post(s)
Liked: 339
Its probably going to sound weird with your Polk R50's towers and a C-20 Center channel.
"Surround" speakers aren't ment to be the front speakers in any set-up
crazyrob425 is offline
post #6 of 7 Old 05-28-2014, 09:59 AM
tezster's Avatar
Quoted: 517 Post(s)
Liked: 401
You could use the 4xS-20's as surround and rear speakers in a 7.1 setup, but not as the main L/R. And the center wouldn't be timber-matched with your current mains, most likely. FYI the S-20's have woofers angled in opposite 45 degree angles, and is designed to have the sound bounce off walls. I will admit that the price is pretty good, but you can't use that system as-is as a replacement for your existing speakers. If he's willing to part the set, grab a pair of S-20's and maybe the subwoofer if the price is good, then purchase a matching Polk center for your R50's separately.
tezster is offline
post #7 of 7 Old 05-28-2014, 11:43 AM - Thread Starter
Awesome thanks everyone you all confirmed what I was curious and nervous about. Ill see if he will part it out and if not then o well was not meant to be.
Reply Speakers
