Speaker search via cabinet size / dimensions? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 30 Old 06-08-2014, 08:20 PM - Thread Starter
TonyB1966's Avatar
Quoted: 187 Post(s)
Liked: 25
Our new home has a place for the mains, like an enclosure of sorts, but they are a tad small for our current front speakers. I can remove the feet, and they'd fit, but since I've had these since I was in the dorms 20+ years ago, it really is time to refresh these....
Is there a good website to help one shopping for speakers based upon dimension constraints or criteria?
Height, I can do about 28 1/2" max, and width, about 26". Depth should not be a problem...
Thanks much.
TonyB1966 is offline
post #2 of 30 Old 06-08-2014, 09:12 PM
afrogt's Avatar
Quoted: 721 Post(s)
Liked: 599
You can look at categories such as towers, bookshelf speakers, satellites, etc. from sites like Best Buy, Amazon.
You're not going to find a tower speaker 28" tall though because the tweeter would be below ear level when seated.
You should look at bookshelf speakers and possibly a speaker stand.
Afro GT
afrogt is offline
post #3 of 30 Old 06-08-2014, 09:27 PM - Thread Starter
TonyB1966's Avatar
Quoted: 187 Post(s)
Liked: 25
Thanks afrogt. That's what I've been doing...
Floor speakers have much smaller footprints these days (and taller), which I can see as being desirable, for a few reasons.
I see Cerwin Vega! and BIC speakers in the "traditional" shape (wider) that I'm seeking, but they seem to be 33" at the shortest. So, as you said, maybe a bookshelf speaker serving in this capacity should be considered. Can you think of any good candidates? Thanks again for making the time to help...
post #4 of 30 Old 06-08-2014, 09:40 PM
afrogt's Avatar
Quoted: 721 Post(s)
Liked: 599
you need to go to your local audio stores and listen to as many speakers as you can. Speaker preference is totally subjective. What you like I may not like and vice versa.
And you also need to provide a budget which you haven't done. People can't give you recommendations if they have no idea how much you're willing to spend.
Afro GT
afrogt is offline
post #5 of 30 Old 06-08-2014, 09:46 PM - Thread Starter
TonyB1966's Avatar
Quoted: 187 Post(s)
Liked: 25
Clearly understood on that front. Having not seen any that would "fit" the space there were no contenders to go listen to...
Bookshelf speakers serving as the main front left and right is a whole new search, which I'm just starting. Budget, about 500-700 dollars, for the pair...
post #6 of 30 Old 06-09-2014, 02:49 AM
zieglj01's Avatar
Quoted: 925 Post(s)
Liked: 836
Look at the Focal 806V
http://www.musicdirect.com/p-139677-focal-chorus-806v-bookshelf-speakers-pr.aspx
Ascend CMT-340
http://www.ascendacoustics.com/pages/products/speakers/cmt340m/cmt340m.html
TonyB1966 likes this.
__________________________________________
Who AM I
Speakers > MB Quart VS05, Boston VS260, Snell K7, EOS 150SP
Subwoofer > Mordaunt Short Aviano 7
Receiver > Tascam PAR-200, Pioneer VSX-30
zieglj01 is offline
post #7 of 30 Old 06-09-2014, 04:19 AM
Transmaniacon's Avatar
Quoted: 1478 Post(s)
Liked: 1271
+1 on the Ascend, an MTM speaker design would be a good option for a front speaker. But just make sure you keep them at the front edge of the cutout so you that you have adequate space for the rear port.
Samsung PN60F5300 | Denon AVR-1713 | EMP E55Ti | EMP E56Ci | EMP E5Bi | Outlaw Ultra-X12
Transmaniacon is offline
post #8 of 30 Old 06-09-2014, 08:16 AM - Thread Starter
TonyB1966's Avatar
Quoted: 187 Post(s)
Liked: 25
Just woke-up to these most recent two posts - thank you. It seems those Ascend CMT-340 are quite nice (been reading-up the past few minutes). Also, it looks like they are classified as "mini tower" speakers? If I would have known such existed, I would have been searching on such... The height seems to be about 20", so these would even fill that opening better than a bookshelf, so from an aesthetic point, nice too... And in the price range. Not sure I'll have any local to me to listen to though. Still hunting... I really appreciate the input guys!
Transmaniacon, pardon my ignorance, but what is meant by "just make sure you keep them at the front edge of the cutout so you that you have adequate space for the rear port."? I think I know what you are getting at... simply having them sufficiently forward to allow space for the wired connections. The depth of the opening is a tad over 21", so I'm guessing that would be fine. Also, since the ports look to be angled upwards, that would help in tight spaces...
From the bookshelf search last night, the Sony SS-B3000 was up pretty high on the list and our local, and quite large for a bookshelf, also about 20". Now that I'm aware of mini towers, another search...
The Ascend CMT-340 really has my interest though.
post #9 of 30 Old 06-09-2014, 08:22 AM
Liked: 1271
Ported speakers need space near the port in order to function properly. With a rear ported speaker, you want at least 6" of clearance, and in sounds like in your case there shouldn't be an issue.
Stay away from those Sony speakers, they not good and the Ascends are far and away better. They also have a 30 day risk free trial so you can give them a shot and if you don't like them, mail them back.
post #10 of 30 Old 06-09-2014, 08:29 AM
zieglj01's Avatar
Quoted: 925 Post(s)
Liked: 836
Stay away from the cheapy Sony SS-B3000 speakers
The new Sony Core speakers are the ones to look at - they are nice and do sound good
http://www.bestbuy.com/site/sony-core-series-5-3-way-bookshelf-speakers-pair/5721014.p?id=1219148662428&skuId=5721014&st=categoryid$abcat0205001&cp=1&lp=9
The Ascend 340 and Focal 806V are still good options
Who AM I
zieglj01 is offline
post #11 of 30 Old 06-09-2014, 08:48 AM - Thread Starter
TonyB1966's Avatar
Quoted: 187 Post(s)
Liked: 25
Alrighty. The other bookshelf speaker very high on the list was the Andrew Jones-inspired Pioneers...
I was unable to find much on "mini towers", making these CMT-340 SE's rather unique in size, so it seems...
So, these are only sold direct from Ascend Acoustics? No problem of course. An old Denon 3801 would be driving these (a 7.1 in total). It still manages to serve our purposes well...
post #12 of 30 Old 06-09-2014, 09:10 AM
zieglj01's Avatar
Quoted: 925 Post(s)
Liked: 836
With your budget, I would go higher than Pioneer
Ascend has a 30 day return policy
Who AM I
zieglj01 is offline
post #13 of 30 Old 06-09-2014, 09:43 AM - Thread Starter
TonyB1966's Avatar
Quoted: 187 Post(s)
Liked: 25
Just ordered. Father's Day gift to myself, lol.
Thanks everyone for your input.
post #14 of 30 Old 06-09-2014, 09:50 AM
Elihawk's Avatar
Quoted: 830 Post(s)
Liked: 715
If you are talking about having just ordered the AA CMT340, very good choice! I have listened to that a lot and really like the speaker for both HT and music!
Set up #1: EMP e5ti, e5Ci, and EMP e5Bi surrounds, Outlaw LFM1 Plus sub, EMP 10i10i sub
Set up #2: Def Tech SM450, CLR2002, SLS Qline surrounds and Klipsch 12wD sub
Set up #3: Philharmonics- BMR in a 2.0 system, music only
Elihawk is offline
post #15 of 30 Old 06-09-2014, 10:04 AM - Thread Starter
TonyB1966's Avatar
Quoted: 187 Post(s)
Liked: 25
Yup, the CMT-340 SE's... Pretty excited about trying them out after what I've read.
Just need a new Karaoke player now to finish things up. The old one's RCA jacks has finally made it obsolete...
post #16 of 30 Old 06-09-2014, 11:32 AM
RayGuy's Avatar
Quoted: 585 Post(s)
Liked: 449
Place the speakers such that they protrude slightly out the front of the cabinet you are putting them in. This will minimize the reflections off the cabinet and allow the speakers to function at their best. if the speakers are recessed in a cabinet, the sides of the cabinet will reflect the sound and it will become muddy. Also, you may want to invest in some isolating feet for the speakers, so they will not induce unwanted vibrations in the cabinet itself and anything else that is on/in the cabinet.
Congratulations on your new toys! Enjoy!
RayGuy is offline
post #17 of 30 Old 06-09-2014, 11:41 AM - Thread Starter
TonyB1966's Avatar
Quoted: 187 Post(s)
Liked: 25
Great information RayGuy. I was wondering about that and was going to research that very concern...
As far as isolation of the speaker's base, instead of feet, are there mats that might do the trick? I have some large pieces of memory foam mats that could be trimmed, like those used for standing on, that I was contemplating...
post #18 of 30 Old 06-09-2014, 01:13 PM
RayGuy's Avatar
Quoted: 585 Post(s)
Liked: 449
Sorbothane seems to be all the rage : http://www.amazon.com/Isolate-It-Sorbothane-Vibration-Isolation/dp/B0042U8P9C/ref=sr_1_2/184-2644006-8699944?ie=UTF8&qid=1402344333&sr=8-2&keywords=speaker+isolation+pads
That said, there are some pad-type isolators at Amazon, too. They are quite a bit more expensive, so I would go for the cheaper solution to start and trade up if you find you need more.
EDIT: FYI, I looked at your speakers and see that they are rear-ported. Is the cabinet sealed in the back or open (behind the speaker)? Generally, when putting speakers IN a cabinet, it is better to use front-ported speakers. You may find that there is no issue in your situation, if there is sufficient space around the speaker, however, you should be aware that there is the potential for muddy bass, for the same reasons I described in my previous post. You've got 30 days to decide, so there will be plenty of time to know if it will be an issue or not.
One good experiment for you to try is to set up the speakers OUTSIDE of the cabinet (on stands or a stack of books or whatever) and listen to them. Move them around a bit (closer or further away from the walls). Once you have a feel for their performance, put them in the cabinet and try them again. Note whatever differences you hear. In-cabinet-mounting, by it's very nature, is a compromise and you should be fully aware of it's effect on the speaker's ability to perform to it's fullest.
RayGuy is offline
post #19 of 30 Old 06-09-2014, 02:47 PM
zieglj01's Avatar
Quoted: 925 Post(s)
Liked: 836
You can use memory foam
You can even use self-adhesive rubber bumper feet - does not cost much.
The main thing I like to do, is to keep wood from touching wood
Also with your cabinet, you will have about 16 inches behind the speaker,
if it starts to sound a little muddy or boomy - then put some foam around
the back sides and rear wall - to help tame the tunnel effect.
Who AM I
zieglj01 is offline
post #20 of 30 Old 06-09-2014, 03:58 PM - Thread Starter
TonyB1966's Avatar
Quoted: 187 Post(s)
Liked: 25
Good stuff. I'll cut-out some memory foam padding and line the floor with the material.
From my calculations, with these speakers all the way forward, as discussed here, there will be about 10" of space behind. How did you figure 16"?
post #21 of 30 Old 06-09-2014, 05:20 PM
zieglj01's Avatar
Quoted: 925 Post(s)
Liked: 836
My bad - I misread the 26 inch width
Use the memory foam on the bottom of the speakers, if the speakers can stand level.
If not, then use the bumper feet >>>
As stated, It may get a little boomy or muddy - if so, treat the bottom behind the speakers
and the sides and back wall - test it with the sound and do not under, or over do it.
Who AM I
zieglj01 is offline
post #22 of 30 Old 06-09-2014, 06:08 PM - Thread Starter
TonyB1966's Avatar
Quoted: 187 Post(s)
Liked: 25
AA shipped today. Thanks Dina! She was great...
Is there a recommended material to fill such space? I have plenty of styrofoam from a recent TV purchase that I can cut to fit, then cover in fabric to look nicer... If there are any good discussions here on this topic of space filling, material options and general guidance, I'll try to find it.
zieglj01, you've been helpful, thank you.
post #23 of 30 Old 06-10-2014, 05:11 PM
buzzy_'s Avatar
Quoted: 58 Post(s)
Liked: 79
Try it in the space before you worry too much about it.
Are you going to stand them up vertically? If so, make sure whatever you put them on is very stable, with no risk of falling over. I'm not sure memory foam fits the bill.
buzzy_ is offline
post #24 of 30 Old 06-10-2014, 05:34 PM
zieglj01's Avatar
Quoted: 925 Post(s)
Liked: 836
After setting them up, If you feel you need to do something - then look at the Sonic Barrier
I would use this over memory and styrofoam
http://www.parts-express.com/Search.aspx?keyword=foam%20damping&sitesearch=true
Who AM I
zieglj01 is offline
post #25 of 30 Old 06-10-2014, 05:48 PM - Thread Starter
TonyB1966's Avatar
Quoted: 187 Post(s)
Liked: 25
Thanks buzzy_ Yup, plan to stand them up, and all the way forward, as discussed. So.... your concern is one that crossed my mind too. I might somehow tether it from the rear to prevent it from falling over, or find some other way to secure them.
zieglj01, I recall using that stuff in a friend's garage when we were kids, playing music in there!
As buzzy_ said, I'll fire these up tomorrow and if I sense a need, at least now I know what to get... Thanks again.
post #26 of 30 Old 06-10-2014, 06:48 PM
RayGuy's Avatar
Quoted: 585 Post(s)
Liked: 449
I agree with this sentiment ... unstable surface with tethers to compensate? Not the best approach, IMO.
RayGuy is offline
post #27 of 30 Old 06-10-2014, 07:19 PM - Thread Starter
TonyB1966's Avatar
Quoted: 187 Post(s)
Liked: 25
I have a feeling that the mat will do the trick. If not, I'll try something else...
I used these (neoprene) to line the floor of one of our cargo storage containers. I'll cut pieces to fit below each speaker...
http://www.harborfreight.com/4-piece-anti-fatigue-foam-mat-set-94635.html
post #28 of 30 Old 06-13-2014, 09:19 AM - Thread Starter
TonyB1966's Avatar
Quoted: 187 Post(s)
Liked: 25
Follow-up...
I want to say thank you again for the input provided here and the recommendation of the AA CMT340. We are still moving, have a lot stuff in boxes, but I found our PS3, popped in a CD (classical) and was just blown away. Not sure at the moment I'll need something below the speakers or in the back, but I'll get that refined later, if need be...
I must admit, when I first looked at the rear of the speakers, seeing separate inputs for tweeter and woofer, I scratched my head. I then remember seeing this before on some speakers I had some time back. No bi-amping or bi-wiring here, so I kept the bridge in place.
I have some JBL Control 1 Pro speakers that I really like, and just found in a box, and was hoping to use as surrounds, but they are 4 ohms though. I think they might kill my Denon 3801. I'll give them a go and monitor for heat...
post #29 of 30 Old 06-13-2014, 09:26 AM
zieglj01's Avatar
Quoted: 925 Post(s)
Liked: 836
Glad that you like them
Not as much info goes to the surrounds - if you do not play at extreme volumes,
then try them out - and check the Denon for excess heat.
Who AM I
zieglj01 is offline
post #30 of 30 Old 06-13-2014, 10:11 AM - Thread Starter
TonyB1966's Avatar
Quoted: 187 Post(s)
Liked: 25
Not sure how to "like" posts now, but thanks much zieglj01. Makes sense when using them as surrounds, which would be in a 7.1 system, but I wonder what happens when I use them for tunes?
I'm going to wire-up these JBL's... Thanks again.
Reply Speakers
