are high-end speaker wires bunk? - Page 17 - AVS Forum | Home Theater Discussions And Reviews
Closed Thread
post #481 of 492 Old 04-04-2003, 11:49 AM
Mmasterg314's Avatar
After readind this whole thread and another thread l posted on l am not going for high priced speaker wire.l was going to spend about $500 for 200 feet of wire but for what.I have 50 foot runs to fronts and think l should go with 12 gauge OFC,but want 4 cond in wall and can not find it for a fair price.I was told to keep wires as far away from electric one to two feet if possable,and speakers wire at least 2'' from each other If l go with 2 -2cond to bi wire will l be able to run both in same hole with out losing anything,having to make 3 holes for fronts with 2 wires in each hole.
Mmasterg314 is offline
post #482 of 492 Old 04-04-2003, 01:51 PM
Figgie's Avatar
Originally posted by shoot
1) Did you set up your home theater/listening room for acousitcs or aesthetics? If you set it up for aesthetics, skip the good cables.
2) How often do you listen to a new CD and think that the recording isn't very good. If you rarely have complaints about the quality of the recording on CDs you don't need the good cables either.
If however, you passed these test you should audition some good cable to see if you can hear an improvement.
Given blind testing with cables, some can hear an improvement (and think it is worthwhile), and some can't.
shoot
Err
I think you got it backwards :) For acoustics a cheap cable will do. For aesthetics the cable has to fit the decor ;)
Blind testing the cable has proven that there IS NO difference between cable X and lamp zip cord.
Hell my little space heater from Holmes pulls 1500 watts on high and it has 18 AWG wire!!!!
here is the marking on this bad boy
(UL) SPT-2 18AWGX2C VW-1 105°C 300V E205059 LICHENG C
Do NOT let the magic smoke out because it is impossible to put the magic smoke back in!!!!
Figgie is offline
post #483 of 492 Old 04-04-2003, 02:05 PM
bigwally's Avatar
shoot
If you see someone pass a properly conducted blind test on cables you might suggest they cash in. There are challenges issued from time to time by David Clark, Tom Nousaine, and others sometimes with a substantial wager included. I don't know if it's still going on, but there was a pot of around $6000 being held by some regulars at rec.audio for anyone who could pass the challenge.
bigwally is offline
post #484 of 492 Old 04-04-2003, 03:53 PM
Figgie's Avatar
umm
bigWally
do you Mean RICHARD Clark from the Car Sound forums
Figgie is offline
post #485 of 492 Old 04-04-2003, 04:05 PM
nutt's Avatar
"are high-end speaker wires bunk?"
YES!!!
nutt is offline
post #486 of 492 Old 04-04-2003, 04:52 PM
JohnR_IN_LA's Avatar
Originally posted by Figgie
Err
I think he had in mind hiding the cable as much as possible, at one point I was running the thinnest cable I could find at Home Depot, 22 ga or something, simply because I could hide it so well ... it sounded exxcceelllente'!
Theres some nice looking audio cable out there, dont you call it audio jewelry? Makes the whole system LOOK like it sounds better, haha.
JohnR_IN_LA is offline
post #487 of 492 Old 04-04-2003, 07:50 PM
bigwally's Avatar
umm
bigWally
Yes, thanks. David Clark is the headphone guy. :D
bigwally is offline
post #488 of 492 Old 04-05-2003, 05:01 AM
nhparrot's Avatar
This topic is the same as discussing politics or religion. If you think so then - yes, if you don't think so then - no.
Although, I don't subscribe to the thought that higher cost makes a better product. I have heard differences in my system with different interconnects and speaker wires. Not huge differences but subtle differences. Did, I buy the most expensive? No, I bought the one that sounded right to me in my system. Just my opinion.
nhparrot is offline
post #489 of 492 Old 04-06-2003, 09:46 AM
ve4can's Avatar
LONG, LONG AGO...IN A GALAXY FAR, FAR AWAY...THERE WAS SPEAKER WIRE WARS.
The link that nerdbOt posted at the beginning [post#1]
can also be read herehome.earthlink.net/~rogerr7/wire.htm
TOYS!!....WE NEED "MORE" and BETTER TOYS!!
ve4can is offline
post #490 of 492 Old 04-06-2003, 03:47 PM
Hey guys any 12 gauge 4 cond twisted copper wire for speakers that do not cost to much under $300 for 200 ft.
post #491 of 492 Old 04-07-2003, 04:08 PM
rrchampion's Avatar
Originally posted by nerdb0t
hey dudes,
here's a quote from this article i read:
"...So what do our fifty hours of testing, scoring and listening to speaker cables amount to? Only that 16-gauge lamp cord and Monster cable are indistinguishable from each other with music and seem to be superior to the 24 gauge wire commonly sold or given away as 'speaker cable.' "
the whole article can be found here:
http://www.sundial.net/~rogerr/wire.htm
Have been unsuccessful for days accessing the about URL. It eventually just times out. Do you have another way to get to the article?
rrchampion is offline
post #492 of 492 Old 04-07-2003, 08:57 PM
ve4can's Avatar
The Roger Russell"s article that you want is:http://home.earthlink.net/~rogerr7/wire.htm
brian
ve4can is offline
Closed Thread Speakers
