Upgrading to 7.1. Need two more speakers. - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 06-12-2014, 06:00 AM - Thread Starter
brian_tr's Avatar
Bought a Sony STR-DN1040 7.2-Channel Network A/V Receiver to replace my old Yamaha reciever. I have Paradigm monitor 7's for fronts and mini monitors for rears, which are getting quite old now. I was thinking of getting some Polk Audio Monitor 45B for the extra surrounds. Do you think they will pair ok with the rest?
brian_tr is offline
post #2 of 5 Old 06-13-2014, 04:08 AM - Thread Starter
brian_tr's Avatar
Not sure how much longer my Paradigms are going to hold out. Not sure just how old they are but been many years. Seems like alot of people like Polk speakers. I would like to get my new surrounds to match what I might be getting in the future to replace my other speakers.
brian_tr is offline
post #3 of 5 Old 06-13-2014, 05:35 AM
Audiojan's Avatar
Quoted: 18 Post(s)
It may be ok, it may not… just no way of knowing how well those Polk's will sound with the Paradigm's. Personally, I would stick with Paradigm's…. The Monitor 7's are good speakers, so unless you spend significant $, it's going to be more of an incremental change (not necessarily better, but different for sure).
Speakers can last for MANY years… the main issues you will have over time is surrounds (foam and rubber will dry up) and caps in the cross-over. Easy fixes that won't cost much.
"Suddenly the thought struck me, my floor is someone elses ceiling" - Nils Ferlin
Audiojan is offline
post #4 of 5 Old 06-14-2014, 05:50 AM - Thread Starter
brian_tr's Avatar
Guess may be better to buy used mini monitors on ebay.
brian_tr is offline
post #5 of 5 Old 06-14-2014, 09:15 AM
commsysman's Avatar
Quoted: 973 Post(s)
Liked: 523
Get the Paradigm Atom speakers.
commsysman is offline
Reply Speakers
