studio monitors or regular computer speakers for office? - AVS Forum | Home Theater Discussions And Reviews
Old 06-13-2014, 10:20 PM - Thread Starter
unknown00's Avatar
Liked: 0
what should i get for my home office?
what will i use it for? music (want bass heavy), movies, everyday stuff
what did i have before? Logitech z5500, it was awesome. i feel like i didn't take advantage of the full 5.1 though and used it more for a 2.1
i don't know if i should stay with a pair of logitech computer speakers or go with some studio monitors, what is the main difference? budget is $400
unknown00 is offline
Old 06-14-2014, 07:38 AM
crazyrob425's Avatar
Quoted: 443 Post(s)
Liked: 337
$400 isn't a high budget for studio monitors with a subwoofer( since you want bass you'll need that. If you like you z5500's keep them.
crazyrob425 is offline
Old 06-14-2014, 07:59 AM
SyntheticShrimp's Avatar
Quoted: 241 Post(s)
Liked: 210
I'd go with a pair of JBL LSR308 if you have room. They will have a decent amount of bass too.
SyntheticShrimp is offline
Old 06-14-2014, 08:43 AM
commsysman's Avatar
Quoted: 964 Post(s)
Liked: 522
I use a pair of the Audioengine A2 speakers, which are only $250; they are excellent.
NO monitor or powered small speaker can produce enough bass to be of any use.
You will have to have a subwoofer, but it does not have to be huge unless you plan on some really punishing sound levels.
The PSB Sub Series 100 is only $249, and is compact and should be good for your setup.
commsysman is offline
Old 06-14-2014, 09:34 AM - Thread Starter
unknown00's Avatar
Liked: 0
thanks for the answers thus far. what is the main difference between a pair of studio monitors (Which are pretty expensive) and a normal highend computer speaker?
Old 06-14-2014, 10:42 PM
Quoted: 241 Post(s)
Liked: 210
High end PC speakers usually come with a sub. Studio monitors usually have better measured performance, but I've seen some pretty bad ones also.
