PDR-12 blown woofer - AVS Forum | Home Theater Discussions And Reviews
post #1 of 19 Old 06-15-2014, 07:24 AM - Thread Starter
brian_tr's Avatar
PDR-12 blown woofer
I have a Paradigm PDR12 Subwoofer with a blown woofer. I would like to find a replacement for it. Any ideas where to get one? What is 15 kOhm?
Specs say it is.
  • Amplification type
    active
  • Woofer size (inches)
    12" in
  • Nominal (RMS) output power
    110 Watt
  • Input impedance
    15 kOhm
  • Crossover frequency
    50 - 150Hz
brian_tr is offline
post #2 of 19 Old 06-15-2014, 07:31 AM - Thread Starter
brian_tr's Avatar
I took the woofer out and the foam around it is completely gone. The speaker sounds really bad. No bass at all just muffled sound. Would just the bad foam cause this?
brian_tr is offline
post #3 of 19 Old 06-15-2014, 07:45 AM
Bill Fitzmaurice's Avatar
Liked: 5619
That's exactly what bad foam causes. have it re-foamed or replaced.
Paradigm?
Bill Fitzmaurice is offline
post #4 of 19 Old 06-15-2014, 07:52 AM - Thread Starter
brian_tr's Avatar
Yes it is a Paradigm. Would like to just replace the driver but not sure what to get. Part number on speaker is B156WFPDR0012 0599
brian_tr is offline
post #5 of 19 Old 06-15-2014, 08:04 AM
audio4life's Avatar
Liked: 300
Unfortunately, your best bet may be to contact Paradigm and see if they can sell you a replacement. Other than that, you could contact Parts Express on the phone and ask them if they are familiar with the PDR-12 and what replacement they may have. I'd suggest re-foaming it yourself, but it's a tricky procedure. Another option may be to get it refoamed as suggested above, if there are reputable places near you.
audio4life is offline
post #6 of 19 Old 06-15-2014, 08:22 AM
fatbottom's Avatar
Quoted: 1420 Post(s)
Liked: 519
You can get a driver re-coned. Personally I'd probably buy a new sub, get yours re-coned and perhaps use it for second system.
fatbottom is offline
post #7 of 19 Old 06-15-2014, 08:35 AM - Thread Starter
brian_tr's Avatar
I have another sub. Just got a 7.2 reciever and wanted to use it for second sub.
brian_tr is offline
post #8 of 19 Old 06-15-2014, 08:45 AM
audio4life's Avatar
Liked: 300
Here is a link from simply speakers. I googled "pdr 12 replace woofer" and got this among other links. If you can scroll down on the link, you will see that 2 reviewers of the woofer used it with good results as a replacement in their PDR-12.
http://www.simplyspeakers.com/replac...-w-12pc-4.html
post #9 of 19 Old 06-15-2014, 09:12 AM - Thread Starter
brian_tr's Avatar
Thanks for the link. I think speaker is 8 ohms and they have a 8 ohm version of that speaker. Would probably better with it if the paradigm is 8 ohm. Not for sure if 8 or 4 though.
brian_tr is offline
post #10 of 19 Old 06-15-2014, 12:47 PM
Liked: 5619
With only 4mm xmax it would be very weak in maximum output. The minimum I'd consider for even moderate listening levels is 8mm. A high quality sub driver will have at least 12mm xmax.
post #11 of 19 Old 06-15-2014, 01:16 PM - Thread Starter
brian_tr's Avatar
I think I will try to re-foam it. Hopefully that is all that is wrong. I measured with meter and reads 3.8 ohms so I would guess it is a 4 ohm speaker.
brian_tr is offline
post #12 of 19 Old 06-15-2014, 01:48 PM
fatbottom's Avatar
Liked: 519
tbh I wouldn't pay to get it re-coned, I'd just DIY. PDR-12 is a old sub, so driver tech has moved forward, a better quality newer driver should give it a lease of life. Ie mates old Rel Q100E wasn't impressive then, and it certainly wouldn't be now if you repaired the cone, hopefully replacing it with a higher quality driver with more output, should enhance it.ie
http://www.bkelec.com/HiFi/Drive_Uni...eplacement.htm
post #13 of 19 Old 06-15-2014, 01:52 PM
audio4life's Avatar
Liked: 300
Do you have any idea what the xmax is for the stock woofer? Or if installing a woofer with 12mm xmax would be a bad combination for the box or amp? This was more of a budget model from 15 years ago or more, if judging by the foam rot is any indication, and I doubt its amp could drive such a woofer without damage of one kind or another.
post #14 of 19 Old 06-15-2014, 02:22 PM
Liked: 5619
You can never have too much xmax. A sub loaded with a driver with 4mm xmax would not be able to handle more than 30 watts before severe distortion occurred, perhaps 90 watts before mechanical damage is a possibility. 4mm is marginal even for a standard woofer that's not expected to be used below 40Hz.
post #15 of 19 Old 06-15-2014, 02:30 PM
fatbottom's Avatar
Liked: 519
The PDR-12 is about 20 years old now? Drivers have come a long way since then...
post #16 of 19 Old 06-15-2014, 10:58 PM
basshead81's Avatar
Quoted: 231 Post(s)
Liked: 6374
I refoamed a PDR-10 with a kit from speakerworks.com. i actually use those kits for various paradigm speakers(titans/atoms)...work great! Paradigm speakers from the 90's thru early 2000's were notorious for rotting foam after 5-10yrs.
basshead81 is offline
post #17 of 19 Old 06-16-2014, 02:26 AM
fatbottom's Avatar
Liked: 519
My NHT speakers have foam surrounds, they've discoloured a bit, but still seem ok. I guess UV makes foam fall to bits, and they're out of sunlight.
post #18 of 19 Old 06-16-2014, 05:30 AM
Liked: 5619
First generation foam surrounds started failing in droves in the 90s, since then the foam formulation has been changed to resist UV and rot.
post #19 of 19 Old 06-21-2014, 02:06 PM - Thread Starter
brian_tr's Avatar
I re-foamed my sub today and it actually works. Thanks for the help! Two subs really sound nice Got two more mini monitors on ebay When get them hooked up will have 7,2. Life is good.
brian_tr is offline
Reply Speakers
