5.1 system for $3000? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 13 Old 06-15-2014, 11:14 AM - Thread Starter
thp427's Avatar
I've got an old Axiom surround system, and I'm looking for a new speaker set. The house already has Paradigm in ceiling speakers for the rears if I decide upon a 7 speaker system - so all I really need are the standard 5.1.
I don't want to spend much over $3000 for the speakers, including a sub. (I suppose I could simply keep using my Axiom sub for now, if that would really open up better possibilities for the rest of the system)
This will be in a large basement room, with the HT in one corner. I'll be buying a new X series (2100/3100?) Denon receiver to run this.
Looks like I could get the KEF Q series for about this. Any other brand/series that should be on a short list? I have no speaker brand loyalty, and am hours from the city, so I'm not concerned about a local dealer - 'cause there isn't one.
thp427 is offline
post #2 of 13 Old 06-15-2014, 11:24 AM
commsysman's Avatar
Quoted: 964 Post(s)
Liked: 522
The KEF Q series speakers are very good.
My top recommendation, however, would be a pair of PSB Image T6 speakers ($1300), a C4 center speaker ($500), and a pair of the B5 speakers ($500).
Add an NHT B12D subwoofer, which is excellent, for $800.
Actually, you can get the PSB speakers for a 25% discount at Saturday Audio (minor factory finish issues, full factory warranty new speakers).
I had the Image T6 speakers for two years; they were very very good (I replaced them with Vandersteen Treo speakers...$6500).
PSB also has a line of very good in-wall/in-ceiling speakers, if you ever want to replace the ones you have.
commsysman is offline
post #3 of 13 Old 06-15-2014, 11:34 AM
AcuDefTechGuy's Avatar
Quoted: 175 Post(s)
Liked: 262
You might be able to find something like this for around $3,500:
RBH SX-61 x 5 speakers
RBH SX-1010N x 2 subs
Send me a PM if you would like assistance.
AcuDefTechGuy is offline
post #4 of 13 Old 06-15-2014, 02:58 PM
shadyJ's Avatar
Quoted: 1330 Post(s)
Liked: 1350
Here is one good possibility:
EMP Tek E55Ti towers: $700
EMP Tek E56Ci center: $400
EMP Tek E5Bi bookshelf speakers: $225
Reaction BPS 215 dual drive: $1500
Great setup which comes in under budget. You will definitely want to ditch the Axiom sub, btw.
shadyJ is offline
post #5 of 13 Old 06-15-2014, 03:27 PM
darthray's Avatar
Quoted: 939 Post(s)
Liked: 896
I will trow something else in the mix.
Do a lot of reading on all sugestions and check for reviews.
So here's my other sugestion;
Main $700
http://www.aperionaudio.com/speakers...-tower-speaker
Surronds
$450
http://www.aperionaudio.com/speakers...ellite-speaker
or at $700
http://www.aperionaudio.com/speakers...bipole-speaker
Center
http://www.aperionaudio.com/speakers...hannel-speaker
Sub ($1400) with the bookshelf to keep within the budget
http://www.svsound.com/subwoofers/ported-box/PB12-Plus
Or sub ($1250) with the Bi-pole to be over$100 of the budget
http://www.powersoundaudio.com/products/xs30se
Happy hunting and let us know what you decide to get.
Ray
darthray is offline
post #6 of 13 Old 06-15-2014, 08:57 PM
zieglj01's Avatar
Quoted: 938 Post(s)
Liked: 846
Focal Chorus 717V - towers
http://www.accessories4less.com/make...-havana/1.html
Focal Chorus CC701V - center
http://www.accessories4less.com/make...results/1.html
Focal Chorus 705V - for surrounds
http://www.musicdirect.com/p-41245-f...eakers-pr.aspx
HSU VTF-3 sub - 2 each
http://www.hsuresearch.com/products/vtf-3mk4.html
__________________________________________
Who AM I
Speakers > Snell K7, EOS 150SP
Receiver > Tascam PAR-200
zieglj01 is offline
post #7 of 13 Old 06-15-2014, 09:02 PM
Reefdvr27's Avatar
Quoted: 1564 Post(s)
Liked: 1038
Here is something interesting. I heard the towers a year ago at the NE GTG and thought they sounded great. Could use these as mains and get two more.
RAAL equipped Sierra-1's! Three for $1,200.00!
Reefdvr27 is offline
post #8 of 13 Old 06-16-2014, 09:18 PM - Thread Starter
thp427's Avatar
I like the idea of the seconds/blems. Looks like A4L has the KEF (Q900 fronts, surrounds, center would be $2300), but Saturday doesn't currently have any PSB Image. Does Saturday's inventory change frequently?
thp427 is offline
post #9 of 13 Old 06-16-2014, 09:24 PM - Thread Starter
thp427's Avatar
Are the speakers mentioned above all noticeably a "step above" the EMP Tek speakers? Looks like the tower/center/surrounds can be had from EMP for about $1500.
thp427 is offline
post #10 of 13 Old 06-16-2014, 11:48 PM
cel4145's Avatar
Quoted: 2658 Post(s)
Liked: 2990
How larger is your basement room? Subs see the whole space, including any adjacent open areas. You may need to allocate more of your budget to subwooferage than you might think.
Which Axiom subwoofer do you currently have?
Living room HT: Energy RC-50, Ascend Sierra Horizon w/RAAL, Ascend Sierra 1, PSB Imagine XA | PSA V1500 and CHT SS 18.1 | Denon X4200W | modified Dayton SA1000
Other rooms: CBM-170 SE | SVS SB-1000 | Audio-GD NFB-11 | Parasound Zamp | JBL LSR305
Headphone & Portable AKG K7XX | NAD HP50 | AKG K550 | Soundmagic E50 & E80 | DX50 | E12 | X1
cel4145 is offline
post #11 of 13 Old 06-17-2014, 05:11 PM - Thread Starter
thp427's Avatar
It's roughly 35 x 20 feet, with the home theater area in one corner, and a bar/ping pong table/shuffleboard table area on the other side of the space.
I've got an EP350 sub.
thp427 is offline
post #12 of 13 Old 06-17-2014, 06:19 PM
jaeelarr's Avatar
Quoted: 46 Post(s)
Liked: 42
I would suggest no matter what sub you decide on, make sure you get two. You will thank me later.
jaeelarr is offline
post #13 of 13 Old 06-17-2014, 09:15 PM - Thread Starter
thp427's Avatar
I'm considering switching gears after my idea (to build a center speaker shelf into the wall so that the center speaker doesn't stick out past the wall) may be a bad one. I really want a clean appearance, and don't want a bulky center speaker visibly sticking out well past the tv.
So now I'm going over reviews of Definitive Tech Mythos 10, and using it for the front 3 speakers, and maybe the SR8080BP as surrounds. It looks like this set of 5 speakers would be around $2400 - and I would then add a nice sub.
I realize there have to be trade offs with a wall mounted system rather than towers - but I'm mainly using this for movie/tv watching, and really no hardcore audiophile music. If I went with towers, they would be pretty close to the walls - which I realize isn't ideal, but the married among us will understand. So maybe wall mounted are as good as "too-close-to-the-wall" towers?
For movie watching - and at a similar price - are there big tradeoffs between the Mythos and the PSB, KEF, etc at a similar pricepoint?
If I do go the wall mount route, what about KEF T305 series vs the Mythos?
thp427 is offline
Reply Speakers
