speaker cable brands! - AVS Forum | Home Theater Discussions And Reviews
 3Likes
  • 1 Post By Bill Fitzmaurice
  • 1 Post By ermghoti
  • 1 Post By psgcdn
Old 06-16-2014, 05:21 AM - Thread Starter
soler37's Avatar
Quoted: 18 Post(s)
Looking to buy 12 awg's for my 5.1 system
I don't want to buy monster brand cables since they are over priced imo.
I want to buy cables that will sustain future upgrades, along the lines of blue jeans. . Heard that monoprice is great but abit too cheap (??)
Also I live outside the states in Europe so I buy my stuff from ebay just fyi.
soler37 is offline
Old 06-16-2014, 06:27 AM
Bill Fitzmaurice's Avatar
Liked: 4631
First, why 12ga? Use this to find out what you actually need:
http://www.bcae1.com/images/swfs/spe...rassistant.swf
Any pure copper wire will do. Electrons aren't fussy about the wire brand.
Transmaniacon likes this.
Bill Fitzmaurice is offline
Old 06-16-2014, 08:02 AM
Nicktx27's Avatar
Quoted: 64 Post(s)
Monoprice is FANTASTIC! Its the only place I buy cables for myself and family. I bought 300 ft of 14 gauge wire for $80.
Nicktx27 is offline
Old 06-16-2014, 09:17 AM
ermghoti's Avatar
Quoted: 57 Post(s)
Liked: 84
I ran "great but too cheap" through my Acme Logic Calculator, and it loudly disappeared in a flash of blinding violet light.
Tom White likes this.
ermghoti is offline
Old 06-16-2014, 12:01 PM - Thread Starter
soler37's Avatar
Quoted: 18 Post(s)
Link doesnt work. Reason I wanted 12g is for future high end gear. . Not smart?
soler37 is offline
Old 06-16-2014, 12:52 PM
psgcdn's Avatar
Quoted: 206 Post(s)
Liked: 307
High-end speakers will only require thicker cable if their impedance is lower, which isn't usually correlated with speaker quality. There's no downside to using 12 AWG if you only need 14 AWG, other then it may be more difficult to hide. I use it!
darthray likes this.
psgcdn is offline
Old 06-16-2014, 01:18 PM
Liked: 4631
It works for me. Higher end gear doesn't necessary need higher gauge wire. Sellers of wire would like you to think that you need not only higher gauge but also higher quality, even though there's no such thing.
Old 06-16-2014, 11:52 PM - Thread Starter
soler37's Avatar
Quoted: 18 Post(s)
So how would these do for me?
http://www.bluejeanscable.com/store/speaker/index.htm?PHPSESSID=fcf3a493c642973a4819eecfef282b c3
Takin bout 12 awg white.
soler37 is offline
Old 06-17-2014, 03:57 PM
ermghoti's Avatar
Quoted: 57 Post(s)
Liked: 84
They will work exactly like 14ga lamp wire that costs pennies per foot by the spool.
ermghoti is offline
Old 06-17-2014, 04:33 PM
riffer's Avatar
Quoted: 12 Post(s)
I have some Belden 5T00UP in my system and there is nothing wrong with it, but like ermghoti says, it is just very nice lamp wire. I assume the 5000UE is similar. The locking bananas Blue Jean's sell are also good quality. Not WBT though, but I like audio jewelry
riffer is offline
Old 06-17-2014, 05:25 PM
BOSTON-HD's Avatar
Quoted: 57 Post(s)
Sorry...But I find Blue Jeans to be over-priced myself. Check out Sewell "Silverback" speaker cables here:
http://sewelldirect.com/Silverback-S...Terminated.asp
12 AWG, plus sizes from 3'-50' Wonderful speaker cable & I'm using it with many systems in our home & not a rip-off price. I'm using it with NHT ST4 towers, PSB B4's & PSB B6's & my beloved Boston Acoustic's M25 bookshelf speakers. These are terminated & ready to go out of the package. They sound great! It's a win-win IMHO.
PS: I buy many cables (close to all) from Monoprice, just not their speaker wire. Just my 2 cents worth.
BOSTON-HD is offline
Old 06-17-2014, 06:12 PM
psgcdn's Avatar
Quoted: 206 Post(s)
Liked: 307
More expensive than monoprice... I had the impression that you were going the other way.
I use 12 AWG monoprice wires.
psgcdn is offline
Old 06-17-2014, 06:15 PM
jaeelarr's Avatar
Quoted: 46 Post(s)
Liked: 42
All you need to worry about is if its pure copper or not. Brands mean squat and only drive the price up. 12 AWG is overkill by all means, unless you are running 100+ ft of cables.
Seriously, wires are the LAST component in any system you should be droppin duckets on.
jaeelarr is offline
Old 06-17-2014, 06:21 PM
BOSTON-HD's Avatar
Quoted: 57 Post(s)
PSG: So be it. I find that Sewell's speaker wire is great for the money. If you're in "love" with Monoprice cable, then good for you. Do I love most of Monprice's product? You bet. I just like Sewell's better when it comes to speakers cable. Wonderful speaker cable & ready to go when it arrives @ your door. BTW...Sewell's posts are top-notch!
Old 06-21-2014, 04:51 AM - Thread Starter
soler37's Avatar
Quoted: 18 Post(s)
soler37 is offline
Old 06-21-2014, 06:19 AM
KidHorn's Avatar
Quoted: 1374 Post(s)
Liked: 877
I've used lots of monoprice speaker and it works fine, but I just ran into an issue with a short in one of the wires. It's in the wall so can't see what the problem is, but not all speaker wire is the same. They all contain copper (And maybe some aluminum), but the sleeve quality may vary.
KidHorn is offline
Old 06-21-2014, 06:38 AM
arnyk's Avatar
Quoted: 851 Post(s)
Liked: 1238
There are a lot of things that can happen to speaker cable that no brand's product can resist. For example, those nasty dry wall screws.
However most cable failures relate to termination. That's another thing that no brand's product can resist.
arnyk is offline
Old 06-24-2014, 11:12 PM - Thread Starter
soler37's Avatar
Quoted: 18 Post(s)
So are any of these good enough for my system?
soler37 is offline
Old 06-25-2014, 06:18 AM
Liked: 4631
Are they of adequate gauge? Are the conductors pure copper? If they are then they will deliver as good a result as anything else, no matter what your system consists of.
Old 06-25-2014, 06:27 AM
arnyk's Avatar
Quoted: 851 Post(s)
Liked: 1238
Probably both plenty good enough for a typical high quality home audio system if they meet their published specs.
Please note that 12 gauge wire has 3.31 square mm cross sectional copper area, while this cable is speced at 3.0 square mm, or about 10% undersized. That is probably why they say that these are for audio purposes only. Shouldn't noticeably affect sound quality.
arnyk is offline
Old 06-25-2014, 11:46 AM - Thread Starter
soler37's Avatar
Quoted: 18 Post(s)
What's the purpose of the 12awg then. Resistance doesn't effect sound quality for decent ht system?
soler37 is offline
Old 06-26-2014, 10:15 AM
kjfalls's Avatar
Location: Dennison IL, just across the state line from Terre
Quoted: 204 Post(s)
Liked: 65
Will any of your wire runs come close to AC power? Zip-type wire will not provide any protection from induced AC hum.
kjfalls is offline
Old 06-26-2014, 10:33 AM
Liked: 4631
Speaker cables are not subject to induced AC hum except in severe cases of extremely poor installation practice, for instance, when an entire long cable cable run is literally touching an AC supply wire. Some cable manufacturers claim that their cables have protection against induced AC hum, but if they do it's a prescribed cure for a disease that doesn't exist.
Old 06-26-2014, 10:43 AM
jdcrox's Avatar
Quoted: 78 Post(s)
Liked: 102
Agreed, and speaker wire is not shielded, so why would zip-type wire be any more susceptible to hum?
jdcrox is offline
Old 06-26-2014, 11:07 AM
KidHorn's Avatar
Liked: 877
It wouldn't be. Hum is mainly an issue for low voltage connections that are yet to be amplified. For speaker connections, that are coming downstream from the amplifier, it's very unlikely to be an issue.
KidHorn is offline
Old 06-26-2014, 12:01 PM
Liked: 4631
Some speaker wires are shielded. They shouldn't be, as that results in higher capacitance, which can roll off high frequency response. Sellers of shielded speaker cables are not only promoting snake oil, it's snake oil that can degrade the sound of your system.
Old 06-26-2014, 12:03 PM
arnyk's Avatar
Quoted: 851 Post(s)
Liked: 1238
What's the purpose of the 12 AWG then. Resistance doesn't effect sound quality for decent ht system?
The difference in resistance is about 10%. For audio, no big deal.
arnyk is offline
