Securing bookshelf speakers to stands - AVS Forum | Home Theater Discussions And Reviews
 1Likes
  • 1 Post By TheGSRGuy
post #1 of 19 Old 06-16-2014, 08:26 AM - Thread Starter
TheGSRGuy's Avatar
Quoted: 17 Post(s)
Question Securing bookshelf speakers to stands
About to move into the world of bookshelves on stands, which is something I've never done before (always had floorstanding/towers).
How do the speakers stay secured to the stand? Is there a standard way of doing it? I want to be sure it's safe but not total-overkill -- my fear is my clumsy friends bumping into them and knocking an expensive speaker off.
TheGSRGuy is offline
post #2 of 19 Old 06-16-2014, 08:35 AM
WhskyTangoFoxtrt's Avatar
Quoted: 76 Post(s)
Liked: 58
Blu-Tack works great. However, it does little to prevent guests from placing their frosty beverages on top of your speakers.
WhskyTangoFoxtrt is offline
post #3 of 19 Old 06-16-2014, 08:42 AM - Thread Starter
TheGSRGuy's Avatar
Quoted: 17 Post(s)
That's what Jack Johnson and Tom O'Leary are for.
RPGMasta likes this.
post #4 of 19 Old 06-16-2014, 08:57 AM
fatbottom's Avatar
Quoted: 1420 Post(s)
Liked: 518
Blu-tack. But if you want a more secure finish, double sided foam pads. You'll rip off the veneer/wrap before those foam pads pull off.
fatbottom is offline
post #5 of 19 Old 06-16-2014, 09:33 AM - Thread Starter
TheGSRGuy's Avatar
Quoted: 17 Post(s)
Assume you're talking about the thick 3M VHB foam tape? In that case, yes, it's ridiculously-sticky.
post #6 of 19 Old 06-16-2014, 11:45 AM
Reefdvr27's Avatar
Quoted: 1564 Post(s)
Liked: 1038
Best way to secure them is not to get married and have kids and dogs
I had 4 bookshelf's a few years ago and sure enough the wife knocked one off the stand and gashed it. This is the same woman who denied throwing away the old box for my old Denon 2112 with all the parts inside of it. Went to go sell it and the box was gone with the remote and mic. She said I did it.
Reefdvr27 is offline
post #7 of 19 Old 06-16-2014, 12:32 PM - Thread Starter
TheGSRGuy's Avatar
Quoted: 17 Post(s)
Not married and have no pets, but my friends and I do enjoy the occasional adult beverage (or six) and spatial awareness tends to plummet.
Perhaps I need a 'you break it, you buy it' sign in the living room.
post #8 of 19 Old 06-16-2014, 12:37 PM
fatbottom's Avatar
Liked: 518
Talking
For those times I'd probably get a pair of Jamo Pro speakers..
post #9 of 19 Old 06-16-2014, 12:50 PM
Reefdvr27's Avatar
Liked: 1038
[quote=fatbottom;25011386]
Or build a dedicated theater with a big lock.
post #10 of 19 Old 06-16-2014, 03:30 PM
UofAZ1's Avatar
Quoted: 50 Post(s)
Liked: 75
Don't know what your stands look like but I have my Def Tech Studio monitors sitting on metal plant stands and placed them on Mopads then used flat bungee cords (buy cheap at Home Depot) secured over the top of the speaker to the metal plant stand. Is very secure and the soft material of the flat bungee cord doesn't ruin the piano gloss finish on the speaker.
UofAZ1 is offline
post #11 of 19 Old 06-16-2014, 04:04 PM - Thread Starter
TheGSRGuy's Avatar
Quoted: 17 Post(s)
That sounds pretty cheesy and ugly.
Also, go Wildcats!
post #12 of 19 Old 06-16-2014, 05:20 PM
kamouflage's Avatar
Quoted: 130 Post(s)
Liked: 86
Just use Blu-tack. Also if you move or change speakers it's reusable.
kamouflage is online now
post #13 of 19 Old 06-16-2014, 05:33 PM
Maximus330I's Avatar
Quoted: 20 Post(s)
I just changed out my speakers and after 11 years, the original Blu Tack is still sticky and works great!
Maximus330I is offline
post #14 of 19 Old 06-16-2014, 05:41 PM
Home Theater Lover
Craig Peer's Avatar
Quoted: 3038 Post(s)
Liked: 2969
Earthquake Putty is what I'm using - if it's good enough for earthquakes, it's good enough for speakers !
Current home theater photos - http://www.avsforum.com/photopost/sh...hp?cat=2386514
craigpeer@earthlink.net
Craig Peer is offline
post #15 of 19 Old 06-17-2014, 07:06 AM
Quoted: 76 Post(s)
Liked: 58
Aw, you just broke the first couple rules of Fight Club.
Blu-tack is the stuff. I would not use foam tape.
post #16 of 19 Old 06-17-2014, 01:08 PM
nirvy111's Avatar
Quoted: 119 Post(s)
Liked: 39
They should make bookshelf speakers with screw holes on the base. The ability to bolt the speaker down not only makes them safe but it can improve the sound quality quite a bit in my experience.
nirvy111 is offline
post #17 of 19 Old 06-17-2014, 01:20 PM
kamouflage's Avatar
Quoted: 130 Post(s)
Liked: 86
What differences did you notice? Always been curious but never did just in case it's only a minimal gain.
post #18 of 19 Old 06-17-2014, 02:14 PM
nirvy111's Avatar
Quoted: 119 Post(s)
Liked: 39
I have the q acoustic concept 20 bookshelf speakers. These speakers have inbuilt screw holes because they're designed to be bolted down to their matching stands. I didn't buy the matching stands because they're expensive but instead went diy. I'm not sure how my stands compare, most likely not as good but it still made a pretty big difference, especially in the bass which is clearly faster and tighter. The speakers use to get a tad boomy at high volumes not anymore. There is also a noticeable improvement in clarity with better focus and imaging, in short they sound like better speakers. So all that got me thinking why they don't make mounting screw holes standard for bookshelf speakers just like plinths on floorstanders which likewise help to secure the speaker and improve the sound.
nirvy111 is offline
post #19 of 19 Old 06-17-2014, 07:27 PM
UofAZ1's Avatar
Quoted: 50 Post(s)
Liked: 75
Also, go Wildcats!
The speakers are black, the stand is black and the flat bungee cord is black. You actually have to look pretty hard to even notice them.
UofAZ1 is offline
Reply Speakers
