headache and dizzyness from speakers ? - AVS Forum | Home Theater Discussions And Reviews
 1Likes
  • 1 Post By charmerci
post #1 of 18 Old 06-18-2014, 12:44 PM - Thread Starter
Liked: 0
Hi
I have the B&W cm 9 which i really love with he nad m3 amp and the van den hul cs 122 speaker cables i also have the nad m51 dac with a transparent usb cable. The thing is i really like the sound and everything but most of the time after listening to music for about 20-60 min later on the night i can get a headache and feel dizzy and feel nausea. i also tried the cm 5 and cm1 with the same result. i really really dont want to change my cm 9 cause i like the sound. Anyone else experecing the same symtoms or anyone have any tips to fix this problem ?
thanx
charliecarlsson is offline
post #2 of 18 Old 06-18-2014, 11:01 PM
charmerci's Avatar
Quoted: 310 Post(s)
Liked: 195
This is not a problem with your stereo. See your doctor.
SocialCapital likes this.
charmerci is offline
post #3 of 18 Old 06-18-2014, 11:15 PM
rcohen's Avatar
Quoted: 1208 Post(s)
Liked: 518
Were you playing Mirror's Edge at the time?
rcohen is online now
post #4 of 18 Old 06-18-2014, 11:32 PM
jevans64's Avatar
Quoted: 187 Post(s)
Liked: 145
Or Slim Whitman? " Aaak! Ak, ak, aak! "
Yes. I'd see a doctor. The sound could be playing with the fluid in your ears and causing those symptoms. Loud bass will cause this sometimes but it has to be VERY loud.
Denon AVR X7200WA, Emotiva XPR-5, Emotiva XPA-7, Sony XBR 75" 850C, Oppo UDP-203, Roku Ultra.
DefTech BP7000SC (L/R), CLR3000 (C), SM55 (FH), UIW BPZ/A (SB), UIW 75 (TM).
JBL L7 (Sur), EoSone RSR 350 (RH).
PC 2.1 setup. Emotiva Stealth 6, SVS SB16-Ultra sub, Emotiva DC-1 DAC.
jevans64 is offline
post #5 of 18 Old 06-19-2014, 12:12 AM
lovinthehd's Avatar
Quoted: 4588 Post(s)
Liked: 4775
I fear it is likely the infamous audiophoolius inflictus which is unfortunately fatal. It is sometimes suggested that total abstinence may resolve the issue....but it is rare.
lovinthehd is offline
post #6 of 18 Old 06-19-2014, 11:36 AM
SocialCapital's Avatar
If you do die, can I have your B&W?
SocialCapital is offline
post #7 of 18 Old 06-19-2014, 12:03 PM
Goat1's Avatar
SocialCapital,Lovinthehd,either you are 2 stupid kids or you have zero compassion,which is unfortunate. 2 of the most insensitive posts I've ever read! To the OP...Get your eyes checked,do you wear glasses or contacts? A lot of times if you get dizzy and headaches,your eyes are out of focus. You might need glasses. You could have fluid in your ears also,Get them both checked,not something to mess around with.. Good luck!
Goat1 is offline
post #8 of 18 Old 06-19-2014, 12:06 PM
DonH50's Avatar
Quoted: 1792 Post(s)
Liked: 1325
^^^ Seems harsh but getting a check-up sounds like a good idea.
To the OP: How loudly do you listen and do you have a subwoofer? Does it happen if you turn the volume down? Do you have any ringing or high-pitched tones in your ears after listening?
"After silence, that which best expresses the inexpressible, is music" - Aldous Huxley
DonH50 is offline
post #9 of 18 Old 06-19-2014, 12:36 PM
kjfalls's Avatar
Location: Dennison IL, just across the state line from Terre
Quoted: 204 Post(s)
Liked: 65
First to ask is did you have the same system before without the effects. If so, then what has changed with either your system, or you since then.
kjfalls is offline
post #10 of 18 Old 06-19-2014, 12:55 PM
Goat1's Avatar
The only other thing is if he listens too loud,those speakers can be a little bright. I almost bought them myself,but they had too metallic of a sound I didn't like..
Goat1 is offline
post #11 of 18 Old 06-19-2014, 01:22 PM
lovinthehd's Avatar
Liked: 4775
Puhleease. What part of this makes you take it seriously? The single post? The DAC? The amp? The interconnects? Trying three different models of the speaker lineup? Am I supposed to show compassion for stupidity?
post #12 of 18 Old 06-19-2014, 03:02 PM
Goat1's Avatar
I didn't read the whole thing. Yes,it is pretty ridiculous.. But still,just ignore him.
Goat1 is offline
post #13 of 18 Old 06-19-2014, 03:34 PM - Thread Starter
Liked: 0
Finally some normal answers. I dont use a sub and i play them on normal volume not to high. My previous system was the B&W 685 with the denon 710 amp i think it was called with the van den hul the clear water cables without any dac which i didnt have any problem with but that was also in my old apartment so i dont know how they would effect me on the new one cause the room is different. I also tried the Bose v35 i liked the sound but they gave me the symptoms faster. I have checked my eyes some time ago and i dont wear any glasses but i dont think this issue has anything to do with my eyesight. And yes if u dont have anything a normal person would say then its no point in commenting at all.
post #14 of 18 Old 06-19-2014, 04:39 PM
lovinthehd's Avatar
Liked: 4775
Normal people don't associate different speaker models or particular audio gear with the symptoms you describe nor come as an unknown user to a forum such as this seeking medical advice....
post #15 of 18 Old 06-19-2014, 05:59 PM
kjfalls's Avatar
Quoted: 204 Post(s)
Liked: 65
Arrow
You must be a very very special member, possibly with a medical degree. Or maybe you stayed at a Holiday Inn Express last night. It's rude to automatically assume something isn't so just because you haven't experienced it. I'll give him the benefit of the doubt. I have heard people complaining about listening fatigue from a too strident tweeter, mostly related to horns. It's not a just to think it could be a more severe case. We all react differently.
kjfalls is offline
post #16 of 18 Old 06-19-2014, 06:49 PM
DonH50's Avatar
Liked: 1325
@OP: The cables don't matter. The new room may be emphasizing frequencies the old room did not, contributing to this issue. Try sitting off to one side, and closer/further away, to see if it still happens.
IME, and I am not an M.D., headaches can happen but I have not heard of nausea except as associated with loud bass tones. If you can a checkup still might be a good idea.
Perhaps the moderators can clean up all the personal insults hurled around...
DonH50 is offline
post #17 of 18 Old 06-19-2014, 08:15 PM
rcohen's Avatar
Liked: 518
Too much bass or too much treble could do it.
You could fiddle with the EQ or find a speaker that doesn't give you a headache.
post #18 of 18 Old 06-19-2014, 09:16 PM
lovinthehd's Avatar
Liked: 4775
Maybe we can take another tack altogether. The problem is probably with the B&W brand of speakers, since he tried several different but similar flavors. To test this hypothesis thoroughly he should now find another brand to test, and probably several more models. Maybe just try headphones. It could be the interconnects, maybe even the DAC or amp, so try other brands/models of that too. Why would it be psychosomatic or even medical? It could be listening levels or the material he is listening to....but we don't know anything about that. Good grief.
Reply Speakers
