Hidden/minimal 5.1 speaker advice - 4k budget - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 06-18-2014, 06:03 PM - Thread Starter
Liked: 0
Hi everyone -
What would your advice be for a 5.1 setup that must be hidden or very non-invasive? It'll be used like 60/20/20 for TV/movies/music, respectively - totally general purpose.
The room is a combo kitchen and family room. Section devoted to media is ~9Wx16L with overall room ~25Wx18L'. Ceiling heights are 9'.
Will be sitting about 13' from screen.
We are building a false wall so can frame openings in any fashion.
Thanks in advance. I really appreciate everyone's input.
frspm is offline
post #2 of 3 Old 06-19-2014, 07:47 AM - Thread Starter
Liked: 0
Following up with my current research in case anyone else may be interested.
I did get a recommendation for B&W CWM7.5 for LCR channels. http://www.bowers-wilkins.com/Speake...es/CWM7.5.html
I've also been reading about the Rel Habitat1. http://rel.net/usa/products/habitat-1-landing/
I'm a little hesitant to build subs into the wall like the B&W ISW3/4 - worried that they would make the wall vibrate. Is this an unfounded worry?
frspm is offline
post #3 of 3 Old 06-19-2014, 07:49 AM
TheGSRGuy's Avatar
Quoted: 17 Post(s)
Depends on the construction of said walls and what sort of installation you do. I agree that it is risky.
MartinLogan has the ultra-slim stuff that might work well:
http://www.martinlogan.com/motionSer...ultra-slim.php
TheGSRGuy is offline
Reply Speakers
general purpose , hidden , in-wall
