Need some speaker wire recommendations - AVS Forum | Home Theater Discussions And Reviews
post #1 of 10 Old 06-18-2014, 09:08 PM - Thread Starter
Quoted: 16 Post(s)
Liked: 1
Hello all,
Im buying a new set (tv, receiver, speakers).
I would like to get some speaker wire recommendations.
Im only really going to be running 2 bookshelves and a center channel (living in an apartment and I fear a sub will go through the walls)
I ordered a Denon X1000 receiver, Sony core SSCS8 center channel, and Sony Core SSCS5. Someone in another thread recommended them as being pretty decent for the price so i followed that advice as i could get them from BB along with my TV and everything else. The speakers will be within 10 feet of the receiver (if not less).
VladDracule is offline
post #2 of 10 Old 06-18-2014, 09:22 PM
Nicktx27's Avatar
Quoted: 64 Post(s)
Monoprice.com
/thread
Nicktx27 is offline
post #3 of 10 Old 06-18-2014, 09:24 PM
zieglj01's Avatar
Quoted: 943 Post(s)
Liked: 846
Regular copper speaker wire is fine.
You can order 16 awg speaker wire from Monoprice
http://www.monoprice.com/Product?c_i...seq=1&format=2
Or, go to RadioShack or the hardware store - and have them cut enough (copper) speaker wire for you.
I try to avoid copper-clad-aluminum wire > aluminum does not have the same conductivity as copper.
__________________________________________
Who AM I
Speakers > Snell K7, EOS 150SP
Receiver > Tascam PAR-200
zieglj01 is offline
post #4 of 10 Old 06-18-2014, 11:05 PM
FMW
FMW's Avatar
Quoted: 1652 Post(s)
Liked: 1684
Any copper wire will do. Use 16 ga or larger.
FMW is offline
post #5 of 10 Old 06-18-2014, 11:27 PM
jevans64's Avatar
Quoted: 187 Post(s)
Liked: 145
Beware of the bulk wire with the clear sheath sold by B&M retailers like Home Depot or Lowes IF you plan on running this stuff in an attic. After about 10 years or so in my attic, the copper discolored and started to turn green in places. I guess a combination of the rubber reacting with the copper plus running it up into attic caused the wire to go bad.
If you are going in-wall to attic or crawl space, then get CL2/CL3 rated wire. Now I use CL2/CL3 rated wire for ALL of my wire since it has a nice, round sheath that looks really professional when covered with TechFlex. There is a whole thread on how to make your own cables.
Denon AVR X7200WA, Emotiva XPR-5, Emotiva XPA-7, Sony XBR 75" 850C, Oppo UDP-203, Roku Ultra.
DefTech BP7000SC (L/R), CLR3000 (C), SM55 (FH), UIW BPZ/A (SB), UIW 75 (TM).
JBL L7 (Sur), EoSone RSR 350 (RH).
PC 2.1 setup. Emotiva Stealth 6, SVS SB16-Ultra sub, Emotiva DC-1 DAC.
jevans64 is offline
post #6 of 10 Old 06-18-2014, 11:47 PM
lovinthehd's Avatar
Quoted: 4588 Post(s)
Liked: 4775
Usual suggested reading around here on the subject of wire http://www.roger-russell.com/wire/wire.htm
lovinthehd is offline
post #7 of 10 Old 06-20-2014, 08:28 AM - Thread Starter
Quoted: 16 Post(s)
Liked: 1
Why is shipping so expensive from monoprice? that 16 gauge spool is cheaper than the shipping cost on their site
post #8 of 10 Old 06-20-2014, 08:33 AM
FMW
FMW's Avatar
Liked: 1684
Shipping costs what it costs. It has nothing to do with the cost of what is being shipped. It is just a matter of weight and dimensions.
FMW is offline
post #9 of 10 Old 06-20-2014, 08:34 AM
Nicktx27's Avatar
Quoted: 64 Post(s)
I'm assuming because of its weight and the shipping they provide. Still, at $22 that's a pretty good deal. I typically wait and buy a lot from them to make up for it.
Nicktx27 is offline
post #10 of 10 Old 06-20-2014, 08:39 AM
Divergent9999's Avatar
Belden 5000 from bluejeanscable[dot]com
Divergent9999 is offline
Reply Speakers
