How to strip the LFE audio signal out of an HDMI signal? - AVS Forum | Home Theater Discussions And Reviews
 1Likes
  • 1 Post By fatbottom
post #1 of 8 Old 06-21-2014, 02:32 PM - Thread Starter
chrisreeves's Avatar
Quoted: 408 Post(s)
Liked: 283
EDIT: This thread belongs in the receiver forum - whoops. I can't seem to move it, however.
So here is my challenge:
I've purchased the new Sony HDR-HW700DS wireless surround headset (two of them - so my gf I can watch films together). This thing sounds insanely good and the surround is scary accurate (which brings up another point - why can't Sony figure out how to promote their own products - but that's a different post).
It even does a good job with the low frequency effects, given its 50mm driver. But I'd like more - specifically I'd like to install bass shakers to my sofa.
But how to get the signal to them?
The Sony headphones work as follows:
HDMI signal from video source device is sent to the sony's HDMI switcher box that comes with the headset. Audio is then sent wirelessly to the headset, and video is passed on to the output device (projector). Another option is sending the source device HDMI signal first to a receiver, and then sending audio only to the headphones (via HDMI or optical) via the Sony switcher box.
Are there receivers that can output both the LFE channel to a subwoofer or bass transducer AND send the rest of the audio signal via optical or HDMI on to another device?
"Don't forget that a significant contribution made by the use of high-end cabling is emotional. Knowing that you have the best available causes the listening and viewing to be that much more enjoyable. Observable improvements make it even better."
-From a post on the audio video improvements forum
chrisreeves is offline
post #2 of 8 Old 06-21-2014, 04:51 PM
blipszyc's Avatar
Quoted: 134 Post(s)
Liked: 72
This is exactly what a receiver does. Do you have one already? If so, just connect your source device to the receiver and then to the switcher box. You then need to connect the bass shakers to the LFE output of the receiver. The receiver will handle all the signal handoffs needed.
I don't recall which forum has threads on bass shakers, but a quick search will turn up a few I'm sure.
Visit the Lipszyc Home Theater! 1.0
2.0 done and finally posted! - Theater 2.0
And now...The Queen City Theater (3.0)
blipszyc is offline
post #3 of 8 Old 06-21-2014, 06:15 PM
darthray's Avatar
Quoted: 950 Post(s)
Liked: 902
Shakers - Simple/Cheap Hookup - Visual Guide
Lots of reading, but also lots of info about Butt-kickers.
If the Op meant to remove all calibrations made by the receiver before it goes to Butt-kicker.
I don't think there is way around it.
If there is a way, I would sure like to Know!
Ray
darthray is offline
post #4 of 8 Old 06-21-2014, 06:16 PM - Thread Starter
Quoted: 408 Post(s)
Liked: 283
Thanks Blip,
Perhaps my question was a stupid one! My receiver is a Sony ES series with digital Class D amps from the early 2000's. It's high output and 7.1, so I've never bothered to upgrade it even though it does not do HDMI switching or have pre-amp outputs.
So, that's why I asked the question. I thought perhaps modern receivers could pass along EITHER the entire HDMI audio signal OR decode it and output directly to speakers but not both.
Guess it's finally time to upgrade to a modern receiver.
post #5 of 8 Old 06-21-2014, 08:21 PM
blipszyc's Avatar
Quoted: 134 Post(s)
Liked: 72
Thanks Blip,
If you're using this as an excuse to upgrade your receiver, I'll get out of the way.
Does your Sony have HDMI inputs? If not, you still might be able to run the audio signal from the source to your receiver, probably through a digital signal, and then out to the shakers.
blipszyc is offline
post #6 of 8 Old 06-22-2014, 12:21 AM
cel4145's Avatar
Quoted: 2660 Post(s)
Liked: 2991
I would research any receiver VERY carefully before you buy. I don't know a lot about it, but my understanding is that the HDMI out on some AVRs only outputs 2 channel audio because it's meant for a TV. Sort of defeats the whole idea of the surround features of those headphones if you aren't getting multichannel to the transmitter. And you don't probably want to use optical from your receiver to your headphone transmitters because it will be lossy with blu-ray.
Have you explored using the optical output on the headphone transmitter with an optical DAC? If it can output 2 channel stereo to a DAC, you could find a subwoofer amp that excepts left and right inputs and use it with the buttkickers. The downside is that you'd have to control the volume for the buttkickers with the sub amp.
Living room HT: Energy RC-50, Ascend Sierra Horizon w/RAAL, Ascend Sierra 1, PSB Imagine XA | PSA V1500 and CHT SS 18.1 | Denon X4200W | modified Dayton SA1000
Other rooms: CBM-170 SE | SVS SB-1000 | Audio-GD NFB-11 | Parasound Zamp | JBL LSR305
Headphone & Portable AKG K7XX | NAD HP50 | AKG K550 | Soundmagic E50 & E80 | DX50 | E12 | X1
cel4145 is online now
post #7 of 8 Old 06-22-2014, 01:18 AM
fatbottom's Avatar
Quoted: 1420 Post(s)
Liked: 519
How about using the .1 output from your source (say Oppo BD Player) into your butt kicker amp? Volume won't scale relative to your phones but you could set it so at your typical listening level, the buttkicker is at the right level
darthray likes this.
fatbottom is offline
post #8 of 8 Old 06-22-2014, 03:04 PM
darthray's Avatar
Quoted: 950 Post(s)
Liked: 902
It is a good idea!
I do use a Velodyne SMS-1 for volume contol before the signal goes to two Outlaw mono amp.
I will let the idea simmer since it require me to run another cable and it would need to be an RCA since my Oppo 103 doesn't have XLR (around 50ft).
The way it set at moment one XLR cable to sub 1 from the Maranzt AV8801,
Another XLR to sub 2, then another XLR from sub 2 to the Velodyne SMS-1.
So Thanks for thinking outside the box
Ray
darthray is offline
Reply Speakers
