Audioengine A5+ Bamboo vs Black - AVS Forum | Home Theater Discussions And Reviews
 2Likes
  • 1 Post By ZSamuels28
  • 1 Post By RicardoJoa
post #1 of 20 Old 06-23-2014, 02:14 PM - Thread Starter
Liked: 1
Hi Audiophiles,
Is there a sound difference between the A5+ Bamboo and A5+ Black? I am looking to purchase them and wanted to know if the Bamboo makes any difference in SQ. If so is it beneficial?
lukitass likes this.
ZSamuels28 is offline
post #2 of 20 Old 06-23-2014, 06:09 PM
RicardoJoa's Avatar
Quoted: 23 Post(s)
Liked: 24
Originally Posted by ZSamuels28 View Post
Hi Audiophiles,
I read thru the web page and it seens to me that both black and bamboo are built with mdf board. They just have a different finish, one with a painted finish while the other uses bamboo veneer.
So there shouldnt be any difference in SQ.
RicardoJoa is offline
post #3 of 20 Old 06-23-2014, 07:45 PM
niccolo's Avatar
Quoted: 139 Post(s)
Liked: 39
My understanding is that while the black ones are MDF, the bamboo ones are in fact solid bamboo, not a veneer. My best guess is they sound slightly different, but whether you'd be able to tell the difference isn't clear. All things equal, MDF is a better choice for engineering a speaker. Audioengine has great customer service, just email them if you have questions. I have the A5+s in black and have been quite impressed with them.
niccolo is offline
post #4 of 20 Old 06-23-2014, 08:22 PM
RicardoJoa's Avatar
Quoted: 23 Post(s)
Liked: 24
It is pretty clear that the site on features states hand built mdf wood cabinets.
As for the bamboo, is really the finish that they use and is not for the cabinet construction. They even use the word wrapped. Unlike anything you see from ascend sierra cabinets which are true constructed with bamboo. I think they did a good job at confusing prospects byers.
Quality bamboo sheet are quiet more expensive then mdf, i would be suprised they can offer a solid bamboo construction for $70 additional over the regulars.
Laminated bamboo are much densier and stiffer so they are actually better for speaker cabinets but due to cost and difficulty in working with it, manufactures chooses mdf.
http://audioengineusa.com/Store/Powered-Speaker-Systems/A5-plus-N-Powered-Speakers
post #5 of 20 Old 06-23-2014, 09:00 PM
niccolo's Avatar
Quoted: 139 Post(s)
Liked: 39
http://audioengineusa.com/Store/Powe...wered-Speakers
Yes, they use the word "wrapped," but they also write, "Made from renewable and sustainable solid bamboo - no veneers."
niccolo is offline
post #6 of 20 Old 06-23-2014, 09:38 PM
RicardoJoa's Avatar
Quoted: 23 Post(s)
Liked: 24
Veneer usually refers to wood, but if solid bamboo sounds better to you, be it. My speakers are wrapped with solid paoferro. Like i said they are great at confusing buyers.
post #7 of 20 Old 06-24-2014, 09:28 AM
jaeelarr's Avatar
Quoted: 46 Post(s)
Liked: 42
Veneer, inst usually wood....its wood. The very definition of veneer from Webster:
ve·neer
noun \və-ˈnir\ : a thin layer of wood or other material that is attached to the surface of something in order to make it look better
The point of this is that Audioengine is not clear. Is it "wrapped" or is it "solid"? You cant have it both ways.
I own the P4's and by looking at the slot port, it looks like these are solid Bamboo, as there is not layering of different colors from edge to edge. It just looks like a straight wood cut.
jaeelarr is offline
post #8 of 20 Old 06-24-2014, 12:20 PM
niccolo's Avatar
Quoted: 139 Post(s)
Liked: 39
According to Audioengine customer service reps, it's solid bamboo. They claim they tweak the speakers to account for this, and that it actually has acoustic advantages over MDF. I'm skeptical of that, but my guess is the performance hit isn't significant. And yes, their use of "wrapped" is ambiguous, though their use of "solid bamboo -- no veneers" isn't particularly ambiguous.
niccolo is offline
post #9 of 20 Old 06-24-2014, 06:39 PM
jaeelarr's Avatar
Quoted: 46 Post(s)
Liked: 42
I know someone awhile back reviewed both he bamboo and the MDF and he said the bamboo "sounded better" FWIW. Completely subjective IMHO. Unless published graphs come out showing distinct differences, im not buying it. However, im a sucker for bamboo and they look way better than the black MDF...IMHO of course. I would even take the white over the black.
jaeelarr is offline
post #10 of 20 Old 06-24-2014, 06:46 PM
zieglj01's Avatar
Quoted: 938 Post(s)
Liked: 846
Hi Audiophiles,
You will need to have the ears of Superman - to really pick up any type of difference.
__________________________________________
Who AM I
Speakers > Snell K7, EOS 150SP
Receiver > Tascam PAR-200
zieglj01 is offline
post #11 of 20 Old 06-24-2014, 08:22 PM
RicardoJoa's Avatar
Quoted: 23 Post(s)
Liked: 24
Question
ve·neer
Im not getting your quote,.... veneer isnt usually wood..its wood then you quote a definition that states other material?
There are people that call bamboo wood, solid wood is just another way of saying that is pure wood. It really depends on how you interprete the meaning "solid" as there are various of meaning in different subject of content you are discussing.
post #12 of 20 Old 06-25-2014, 05:39 AM
FMW
FMW's Avatar
Quoted: 1652 Post(s)
Liked: 1681
Bamboo is not wood. It is actually a type of grass. However, this discussion is truly imbecilic.
FMW is offline
post #13 of 20 Old 06-25-2014, 06:33 AM
RicardoJoa's Avatar
Quoted: 23 Post(s)
Liked: 24
No it is not and welcome for joining the imbecility post.
post #14 of 20 Old 06-25-2014, 11:50 AM
jaeelarr's Avatar
Quoted: 46 Post(s)
Liked: 42
Bamboo is grass, not wood. In fact, some people consider it a weed, becuase it can be very invasive.
http://en.wikipedia.org/wiki/Bamboo
Bamboo i/bæmˈb/ (Bambuseae) is a tribe of flowering perennial evergreen plants in the grass family Poaceae, subfamily Bambusoideae, tribe Bambuseae
jaeelarr is offline
post #15 of 20 Old 06-25-2014, 11:52 AM
jaeelarr's Avatar
Quoted: 46 Post(s)
Liked: 42
Sorry for the confusion, but veneer is more often than not wood finishes.
jaeelarr is offline
post #16 of 20 Old 06-25-2014, 12:34 PM
RicardoJoa's Avatar
Quoted: 23 Post(s)
Liked: 24
Actually i meant to agree with him as not being wood.
post #17 of 20 Old 06-25-2014, 12:59 PM
RicardoJoa's Avatar
Quoted: 23 Post(s)
Liked: 24
Hey... what ever you like veneer to mean...
post #18 of 20 Old 06-25-2014, 01:32 PM
ZachF88's Avatar
Quoted: 22 Post(s)
From my understanding, they are solid bamboo. The bamboo has a tendency to separate though. Some say that since the bamboo is a harder material than mdf, the sound is more natural sounding..... I didn't hear a difference. So just buy based on the look, because sound is pretty much the same, if any difference. Source - I use to own A5's in bamboo.
ZachF88 is offline
post #19 of 20 Old 07-31-2014, 02:32 PM
Daniel Smith's Avatar
Quoted: 22 Post(s)
Liked: 27
There may be a slight improvement with Bamboo in sound quality. They claim there is. The main difference is aesthetics, I love the looks of the Bamboo.
The same signature sound of the award-winning P4 wrapped in rock solid and beautifully hand-finished bamboo. Bamboo is an excellent alternative to hardwoods and the dark bamboo used for the Audioengine P4N cabinets is not a stain, but achieved through a specialized heating process. As the wood is pressure heated, the sugar compounds inside the bamboo are "carbonized" which in turn darkens the bamboo to a rich caramel color. Awesome sound, great looks, eco-friendly, and panda-safe.
P4N Eco-friendly features
No stains or paint used - naturally "carbonized" finish sealed with hand-rubbed water-based satin polyurethane
Is the bamboo version a veneer and does the P4 bamboo version sound better than the black or white finished cabinets?
The P4 enclosure is made of solid carbonized bamboo, not a veneer. The bamboo cabinets were tuned to sound the same as the MDF speakers, but the density of bamboo will give it natural acoustic advantages over MDF material.
Daniel Smith is offline
post #20 of 20 Old 08-01-2014, 12:33 AM
Liked: 0
yep,All things equal, MDF is a better choice for engineering a speaker. Audioengine has great customer service, just email them if you have questions. I have the A5+s in black and have been quite impressed with them.[IMG]http://*******/pQ9tzh[/IMG]thanks
ssionoewer is offline
Reply Speakers
Audioengine , Computers , speakers
