New Erskine home theater -- Need advice on Klipsch vs. Procella - Page 6 - AVS Forum | Home Theater Discussions And Reviews
 66Likes
post #151 of 237 Old 07-17-2014, 12:14 PM - Thread Starter
Tnedator's Avatar
Quoted: 347 Post(s)
Liked: 127
Originally Posted by Dan Hitchman View Post
Don't forget the wiring for the front wide side wall surrounds. Perhaps even wire for six or more ceiling speakers depending on Dolby recommendations for spacing given your room dimensions.
I thought in the Atmos info I was reading, they weren't using wide sides, but instead front and rear ceiling (could be more than that, but that being the minimum recommended). I bed I was looking at what the first crop of receivers will support and not what will be coming.
I have an empty column halfway between the front row and screen, I bet that could be used for front side wides, and maybe wire and put fabric in place for 6 ceiling speakers. I'm guessing that's all I can do without some fairly major changes to my room design.
Tnedator is offline
post #152 of 237 Old 07-17-2014, 12:57 PM
dan1210's Avatar
Quoted: 22 Post(s)
Originally Posted by Cam Man View Post
I can't say I agree with all of Doug's opinions in his posts here. Lots of good stuff, but some stuff that I don't agree with. One in particular is large room verses small room regarding ease of design. One is no easier than the other. Both have their issues, and once addressed, will result in terrific performance. It comes down to scale; the quality of the sound over x number of seats. The smaller the room, the tougher it is to deliver a uniform experience, especially with regards to low frequency acoustic response. It's a matter of math. The math helps a larger room in the LF range.
Tnedator, listen to Dennis. This is a room of very good size and proportions. You can get a good-sized screen in there, and at least two rows with very good low frequency acoustic response.
Dennis is totally right to suggest horn designs in this room ... for one reason. As rooms get larger, they have more influence. To know which type of speaker to use, you must be able to anticipate or design for "critical distance." If your LCRs to primary/reference seat distance reaches or exceeds critical distance, you will have an imprecise front stage at that seat. Since home-sized theaters can be so easily over-absorbed with treatments, it becomes advantageous to choose speakers with higher directivity index (some call it controlled directivity) in rooms this size and larger. Horn designs (and good waveguides) have higher directivity therefore it is easy to keep the listener inside "critical distance." The challenge can be covering the primary seats smoothly with speakers with high directivity (especially smaller rooms with shorter throws). Those LCRs must be aimed (including KL-650-THX).
The theater in the attached photos is almost exactly the size of yours. I designed the basics, but used Dennis as a consultant, and to generate the plans. I chose the speakers and designed the acoustic treatments with another colleague to have broadband absorption but retain acoustic life and have a low noise floor. Klipsch KL-650-THX LCRs, KS-7800 THX surrounds (two on each side wall, and two on the back wall), and the two subs from that line. All were concealed behind fabric.
I've used that Klipsch line a lot and still have them at home (a much larger family room). They sound great for all types of sound. I'm sure the big 212s and such will out scream them, but that's not my benchmark in any room.
The Procellas would also be awesome, but pricey.
If it's a big room, these are okay. They have the ISO roll-off ("SMPTE/ISO2969 Curve X high frequency de-emphasis")... which is inappropriate for a smaller acoustic environment. That is not a problem in a large volume and/or acoustically lively room.
that room looks to be similar size to mine, ive searched high and low for the speakers for my ht within my budget but i keep coming back to the klipsch kl 650, how does it sound in that room?
The procellas are very pricey i was quoted £2100 for a single p8
I narrowed my selection down to the klipsch 650, qsc sc-1120 or the jbl 3677, something tells me the klipsch would suffice in my room @ 5.9m deep 4mwide 2.7m high
dan1210 is offline
post #153 of 237 Old 07-17-2014, 01:01 PM
Cam Man's Avatar
Location: Tucson, AZ, Telluride, CO, & Los Angeles,CA, USA
Quoted: 363 Post(s)
Liked: 350
PM me so that I don't bore everyone to sleep or sound like a fanboy.
Cam Man is offline
post #154 of 237 Old 07-17-2014, 01:10 PM
carp's Avatar
Quoted: 2486 Post(s)
Liked: 1741
Originally Posted by ack_bk View Post
With two solid subs up front, you may find you don't need the balancing subs.
I have four 15's that I custom built myself running off a DSP amp and I could honestly gotten away with two of them and been happy (my room is larger than yours).
I agree, I was lucky enough to get away with 2 stacks of subs up front. I have 8 18" driver subs, and have tried any and all placements in the room - and I don't mean once or twice. I'm kind of OCD about this, so I have spent a ton of time with sub placement over the past 15 months or so and more than once I've measured every new position for the 8 subs in all my seating positions.
In the end the sweet spot seat measured the best with the subs stacked in the corners from floor to ceiling - that measured even better than having them in 2 stacks in the quarter positions along the front wall and better than some subs in the back of the room, some on the sides, some nearfield, etc., etc.
Now, when I had some subs in the back of the room the 2nd row and bar table area measured closer to the front row and sweet spot - but subjectively I like the bass better in the back row and bar table area with the subs stacked in the front corners. You get a better *slam* and tactile feel.
So in the end if they measure and sound/feel better in my main LP and measure worse BUT sound/feel better in the other seating areas then it's a no brainer for me even if the subs end up in a position that most say is horrible for smooth frequency response because it excites the peaks and nulls.
carp is offline
post #155 of 237 Old 07-17-2014, 01:21 PM
carp's Avatar
Liked: 1741
Tnedator -
I HIGHLY recommend looking at Seatonsound and JTR for your subwoofer. Send a PM to Craig John, he has Triad Platinums (which are AWESOME) and he loves them of course but for him when it comes to subs he will only go with Seaton Submersives. He has 3 of them and I think loves them every bit as much as the Platinums and I've heard him say he is glad he didn't go with Triad subs.
You get so much for your money with Seaton and JTR, especially with subs. DIY gets you more for your money which is why I sold 2 Seaton Submersives for 8 DIY subs, but I did love those Submersives. My 8 is equal to roughly 5 of the Submersives I would guess since 2 of mine slightly outgun a single Submersive. Impressive since the Submersive is so "tiny".
If you need ported you can look at JTR Captivator 2400's or if you really want maximum output (and they sound great too) JTR Orbit Shifters have the most output of any sub you can buy. They are huge of course, but their horn design has so much output it's really impressive. 2 Orbit Shifters would crush my 8 18" subs above 20hz.
carp is offline
post #156 of 237 Old 07-17-2014, 05:11 PM - Thread Starter
Tnedator's Avatar
Quoted: 347 Post(s)
Liked: 127
Ok, FWIW, while I'm not making the purchase tomorrow (I still have a little time), this is what I'm pretty sure I'm going to do first my first phase.
KL-650 LCRs
KS-7800 surrounds & rear
Two subs that aren't Klipsch (need to figure out best bang for buck here, hopefully in the $1,500 give or take range per sub, including amp/dsp).
I'll drive it all with an Auddissey Pro receiver
Thanks for all the help and insight.
Later on, probably after things are clearer on Atmos and my wallet is healthy again, I'll ditch the KS-7800's and go to monopole surrounds/rear, and three more in-column subs and maybe ceiling speakers, and upgrade the equipment with amps and DSPs and a proper calibration.
Tnedator is offline
post #157 of 237 Old 07-17-2014, 05:24 PM
ack_bk's Avatar
Quoted: 548 Post(s)
Liked: 631
KL-650 LCRs
Seems like a great plan. You could also start with one sub if it stretches past your $1500 per sub budget, but I would also consider PSA, SVS, Hsu, and Rythmik. You can easily get multiples in that price range that would be far superior to the Klipsch subs.
A pair of these would do nicely with a pro Audyssey receiver to EQ.
http://www.powersoundaudio.com/colle...oducts/xv30fse
ack_bk is offline
post #158 of 237 Old 07-17-2014, 05:40 PM
TMcG's Avatar
Quoted: 1072 Post(s)
Liked: 870
You can very easily beat this budget number. If you're not going the DIY route and are looking for a branded sub with high value, consider HSU Research's VTF-15. They are highly rated and can certainly fill your room with satisfying base. NYGiantsFan23 (Ralwingsway Theater) has a pair in his large theater room and loves them. Impressions from others have also been very positive.
HSU offers a dual VTF-15 package for $1709. With shipping you are just under $2K. More or less just plug and play. They're also quite popular on the secondary market if you go to sell them on when Phase II begins.
TMcG is offline
post #159 of 237 Old 07-17-2014, 05:42 PM
ack_bk's Avatar
Quoted: 548 Post(s)
Liked: 631
I owned a VTF-15H. It is a solid sub. I think two of the PSA subs for under $2900 shipped is a better deal, but you are spot on with regards to resale. I sold mine within days of putting it up for sale and did not lose very much from the purchase price.
ack_bk is offline
post #160 of 237 Old 07-17-2014, 07:51 PM
Dan Hitchman's Avatar
Quoted: 3413 Post(s)
Liked: 1766
I thought in the Atmos info I was reading, they weren't using wide sides, but instead front and rear ceiling (could be more than that, but that being the minimum recommended). I bet I was looking at what the first crop of receivers will support and not what will be coming.
Some units will utilize the front wides in future generations. Currently, only the Trinnov processors allow for more than a 7.1.4 configuration... and one model looks like it will do all 34 discrete outputs.
With the front wides, they need to be angled towards the MLP. Your empty column would be an ideal place for them.
Listen up, studios! Just say "NO" to DNR and EE!!
Dan Hitchman is offline
post #161 of 237 Old 07-17-2014, 09:11 PM - Thread Starter
Tnedator's Avatar
Quoted: 347 Post(s)
Liked: 127
Wow, spent the evening trying to do some research on subs, mostly the ones mentioned, but some others. And I thought LCR opinions were all over the place. My head is spinning, glad I'm not making a decision today. Read a bunch of threads, and reviews off of AVS, and several of the GTG's dedicated to subs.
Seems to be a ton of love for the Seaton Submersive HP, which is also more expensive. If I went this route, I would probably have to get one, and then maybe in short order at a slave to it. Not sure how one of these would stack up against two (both located up front, behind the screen) of the $1000-1500 range subs.
Seemed to be a little less info on the PSA30fse than some others.
The SVS PB-13 Ultra and Rythmik FV15HP seemed to mostly get high marks.
Seemed to be a little less love for the HSUs.
There were others of course, but those seemed to be mentioned the most.
Like I said, head spinning. A couple things that might help some of you guys point me in the right direction.
1. As mentioned, music (2 channel) is of zero concern, only movie sound tracks.
2. Extending way down deep, below 20hz with oomph, isn't my number one objective, because quite honestly even with the heavily treated room, I have some concerns about loud, deep bass escaping and bothering neighbors. I don't want to be the guy that has the neighbors hearing/feeling/sensing deep bass, like a teenager driving around town with his thumper going in the car.
3. What I want is good, clean movie sound, which obviously includes crisp, room filling bass, but I don't need it to feel it punch me in the chest and such. Hope that makes sense, I want/need it to be powerful and room filling, but I would be willing to sacrifice some of the ultra low for clarity above 20hz and to keep more of the bass in the room (hopefully, with the room build I'm getting, I'm more concerned about this than I should be).
Tnedator is offline
post #162 of 237 Old 07-17-2014, 09:16 PM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2682
Orbit shifter
Mfusick is offline
post #163 of 237 Old 07-17-2014, 09:20 PM
Liked: 1766
Either of these choices would be quite good. You'd need multiples, of course.
post #164 of 237 Old 07-17-2014, 10:46 PM
ack_bk's Avatar
Quoted: 548 Post(s)
Liked: 631
Look for the CEA-2010 measurements. Based on your description, I think Seaton and JTR subs would be overkill. Honestly, consider starting with a single Rythmik or PB-13. But if it was me, based on what you described, you could go with a pair of these:
http://www.powersoundaudio.com/products/xv15se
This guy is a really trusted reviewer and posts here:
http://www.audioholics.com/subwoofer...v-15-subwoofer
He loved the above PSA subs and measured them using the CEA-2010 guidelines.
They are going to have more than enough output based on your description above. And remember, you will be able to control the bass output. And don't mistake good clean bass with muddy distorted bass. In fact you may want to look at the PSA XS15. Sealed sub. Smaller. Less output, and a pair of them might be exactly what you are looking for.
That said, I don't think you are the bass head many of us are here, so I would not overspend if you are not looking for ultra low frequency and high output.
ack_bk is offline
post #165 of 237 Old 07-17-2014, 10:52 PM - Thread Starter
Tnedator's Avatar
Quoted: 347 Post(s)
Liked: 127
Another issue in sub selection is that I only have 28" from screen wall to front wall and about 2" will be burned on the treatment on the front wall.
So, that leaves me with only 26" of usable depth behind the screen. Can a front ported or sealed sub be placed basically up against the front wall? If not, how much Gap do I need?
Ideally, I don't want to move the screen farther into the room.
Tnedator is offline
post #166 of 237 Old 07-17-2014, 10:54 PM
GIEGAR's Avatar
Quoted: 706 Post(s)
Liked: 1220
If your only option is a pair of subs up the front, take a look at dual (sealed) Rythmik F25's for $3060 shipped. I'm a fan of Rythmik's DirectServo implementation and the range of controls on their amps is impressive too.
If you have some flexibilty in placement, a worthwhile alternative (although perhaps beyond your budget) is quad Rythmik F15's for $3870 shipped.
Also, at the moment you can pick up five Outlaw Audio LFM-1 EX's for $2995 shipped. These are a well regarded downfiring version of Dr. Hsu's VTF-3 MK4 sub and are a great deal at that price. The variable port tuning might be a useful feature for you.
GIEGAR is offline
post #167 of 237 Old 07-17-2014, 11:19 PM
GIEGAR's Avatar
Quoted: 706 Post(s)
Liked: 1220
Sorry T, saw this after I posted. Both Rythmiks will fit within the 26" depth facing forward. (Although sideways makes no difference if the acoustic source is at the same point.) The Outlaw will also not be a problem, but will fit better sideways
Yes, a sub can be placed right up to the wall. Assuming the plate amp is on the rear face though, you will need a few inches clearance for cables.
GIEGAR is offline
post #168 of 237 Old 07-17-2014, 11:29 PM
rcohen's Avatar
Quoted: 1208 Post(s)
Liked: 517
4x identical subs in each corner is ideal, IMO.
rcohen is offline
post #169 of 237 Old 07-18-2014, 12:24 AM
carp's Avatar
Liked: 1741
I know you say you don't want a lot of bass but you might be surprised how addicting low CLEAN bass is and eventually you will want more. Hmmm maybe best not to start down that road to begin with, you could end up like some of the crazy guys in the DIY forum....
Mfusick and Reddig like this.
carp is offline
post #170 of 237 Old 07-18-2014, 05:17 AM
COACH2369's Avatar
Quoted: 801 Post(s)
Liked: 673
I was this way at one time. 18 months ago I was "blown" away by my three HSU VTF-15H's and thought any additional bass would be too much....
Today I have 8-18" SI subs and thought about one more.
COACH2369 is offline
post #171 of 237 Old 07-18-2014, 06:56 AM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2682
Marty cube would fit perfectly; load it with uxl18. 4 will pound senselessly compared to a mfg made sub for the price ($2400). Not even a contest.
Mfusick is offline
post #172 of 237 Old 07-18-2014, 07:05 AM - Thread Starter
Tnedator's Avatar
Quoted: 347 Post(s)
Liked: 127
I might not have been clear on that, it's not that I don't "want" a lot of bass, it's that I want to be a good neighbor. I'm going down the room treatment route, not only to have a great sounding room, but to keep the sound in the room (the same treatment to keep the noise floor low, are the things to keep the sound in).
That's the reason I talked about ultra-deep bass. I know some strive for getting down into the low teens or lower, even at times willing to sacrifice some clarity for the absolute loudest and lowest bass possible. That's clear reading through all of the subwoofer threads.
So, I want good bass, I just don't want the neighbors feeling my bass like when a teen driving down the road with his trunk loaded with sub drivers. I want to "feel it" when the T-rex is walking or the Black Hawk Down helicopter is flying over, I just don't want my neighbor to "feel it." That was my main point, along with clarity of sound being more important than volume of sound. Again, reading through the threads, it's clear that some are willing to sacrifice some clarity for the ultimate in SPL.
Tnedator is offline
post #173 of 237 Old 07-18-2014, 07:12 AM - Thread Starter
Tnedator's Avatar
Quoted: 347 Post(s)
Liked: 127
Initially, my only option will be two subs (or three lesser priced for that matter) up front. This is primarily due to room design. I will have no exposed subs, and no wall penetrations (besides hvac/wiring behind soffits/columns), so placing subs around the room isn't an option initially. Longer term, I will add three balancing subs (one on each side and one in the back) that will go in the columns, they will either have to be small subs like the Procella P10Si or more likely in wall subs (that won't really be in the wall, but instead in the 7" deep column, so no wall penetration).
The reasons for not doing it now, is more about not wanting to go down the amp/DSP route than anything. Once I start mixing two full powered subs up front, and three different passive subs in the walls, it not only raises the costs, but also the complexity of properly calibrating the room. I'll do that in phase II.
Tnedator is offline
post #174 of 237 Old 07-18-2014, 07:21 AM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2682
ULF bass at decent levels you'll notice have no respect for sound proofing. None. I don't care if you buy a semi truck of green glue and do 4 layers of drywall. Expect some sound leakage.
If it's enough to disturb a neighbor on another house ? Idk. But it won't be contained.
In order to appreciate or even realize ULF bass (20hz and down) it will need to be at a decent SPL level. Your ability to hear or sense it is dependent upon this. At the level you'd appreciate or enjoy it then it will make itself known to others too. You won't probably know the extent of this being a problem till it's happening though.
Mfusick is offline
post #175 of 237 Old 07-18-2014, 07:25 AM - Thread Starter
Tnedator's Avatar
Quoted: 347 Post(s)
Liked: 127
I understand, hence my original comment about the bass in the teens.
Tnedator is offline
post #176 of 237 Old 07-18-2014, 09:18 AM
ack_bk's Avatar
Quoted: 548 Post(s)
Liked: 631
Where is this (media room) room located in your house? Do you have shared walls with your neighbors (condo/townhouse?)
I have a decently treated room (basement) and I can play pretty flat to 15hz in my room with my 4 subs and, even with it cranked, it is a non-issue with neighbors. The bedrooms are two floors above, and even at night when if I crank up a movie I have never woken any of my three kids up. Point being, you may be overanalyzing this unless you are talking about shared walls or having something like 10+ 18" subs in your house.
ack_bk is offline
post #177 of 237 Old 07-18-2014, 10:45 AM
Liked: 1766
If you have an Erksine design, taking into account SPL and sound leakage with properly balanced speakers and subs for the room (not too much, not too little... just right), and the contractor doesn't muck it up, and you still disturb your neighbors... then you will be playing movies loud enough to have permanent hearing damage. And that would be just plain stupid.
Some of these bass heads will rue the day they chased the "nth degree" of bass response and reference levels. They'll be practically deaf come retirement age. Home theater rooms are not large commercial auditoriums.
post #178 of 237 Old 07-18-2014, 11:00 AM
jbrown15's Avatar
Quoted: 2523 Post(s)
Liked: 1993
have you seen this option? the sub 3x12 http://www.xtzsound.com/cinema-series you might catch the pre order price which is very good, they are being released in aug/sep uk price is about £----- i think
Sorry but $2500us for one of those subs? ...lol
His money could easily be better spent on other subs.
jbrown15 is offline
post #179 of 237 Old 07-18-2014, 11:18 AM
Davecraze's Avatar
Quoted: 158 Post(s)
Liked: 55
Yes, but that XTZ sub has "high speed drivers"! hahaha
Davecraze is online now
post #180 of 237 Old 07-18-2014, 11:29 AM
jbrown15's Avatar
Liked: 1993
Plus they don't list the xmax of the drivers, so I wonder what they call "high excursion".
darthray likes this.
jbrown15 is offline
Reply Speakers
