Need 7.1 Surround Speakers - AVS Forum | Home Theater Discussions And Reviews
 1Likes
  • 1 Post By Cal68
post #1 of 12 Old 06-23-2014, 09:21 PM - Thread Starter
rinku2012's Avatar
Quoted: 24 Post(s)
Hello,
I am pretty new to this Speakers, Sub Woofers and Receivers section. I am looking for 7.1 Surround sound speakers for in wall ceiling.
I am planning to purchase the below 7.2 Receiver ( Please let me know whether its good choice as i am looking for 4K upscaling for future proof)
http://www.newegg.com/Product/Produc...9SIA2GA1JV6946
Can someone suggest me good speakers ( 7 channel) and a good sub woofer
rinku2012 is offline
post #2 of 12 Old 06-24-2014, 04:53 AM
bladerunner6's Avatar
Quoted: 20 Post(s)
Liked: 59
Originally Posted by rinku2012 View Post
Hello,
Budget, room size, listening preferences, why do you want in-wall?
bladerunner6 is offline
post #3 of 12 Old 06-24-2014, 08:43 AM - Thread Starter
rinku2012's Avatar
Quoted: 24 Post(s)
Thanks for the reply.
Actually this is new home build and the builder gave option of 7 speaker system. Builder had pre wired to the room. I am not sure of room sixe but this room is main living area.
My Budget is from medium to high ( not very high end)
post #4 of 12 Old 06-25-2014, 08:31 AM - Thread Starter
rinku2012's Avatar
Quoted: 24 Post(s)
can someone reply to the thread
post #5 of 12 Old 06-25-2014, 08:35 AM
SyntheticShrimp's Avatar
Quoted: 241 Post(s)
Liked: 210
If future proofing is a priority for you I would consider one of the new Atmos capable receivers.
SyntheticShrimp is offline
post #6 of 12 Old 06-25-2014, 08:42 AM
SMHarman's Avatar
Quoted: 352 Post(s)
Liked: 118
You must be able to provide a rough size and ceiling height and if open to other rooms. Ask the builder.
Budget. How about a dollar value medium to high end is 2-10k for some ans 20-100+k for others.
Sent from my LT26i using Tapatalk
SMHarman is online now
post #7 of 12 Old 06-25-2014, 08:44 AM - Thread Starter
rinku2012's Avatar
Quoted: 24 Post(s)
Hi,
Budget for speakers and sub woofer is around $3000.
its just a living room ( 2nd floor) typical town home
post #8 of 12 Old 06-25-2014, 04:12 PM
shadyJ's Avatar
Quoted: 1330 Post(s)
Liked: 1351
If you care about future proofing, I would get a HDMI 2.0 receiver. The receiver you are looking at is not HDMI 2.0. Some of the new lower end Yamahas have implemented HDMI 2.0. HDMI 2.0 will allow 4k @ 60 FPS and 3d 4k, but the receiver you are looking at will not. I'm guessing the reason the price is so low is because they are clearancing out stock for the new Avantage HDMI 2.0 receivers. If you want to buy a future proof receiver right now, the best one is the Denon AVR-X3100w. Someone mentioned Atmos a bit further up, I wouldn't worry about Atmos yet, because you are in for a looong wait for Atmos compatible receivers.
shadyJ is offline
post #9 of 12 Old 07-18-2014, 12:17 AM - Thread Starter
rinku2012's Avatar
Quoted: 24 Post(s)
Hi Everyone,
can anyone please suggest me ASAP so that i will buy the speakers and receivers within 2 weeks. i want to buy HDMI2.0 and Dolby Atmos receiver and speakers
post #10 of 12 Old 07-18-2014, 02:57 AM
Cal68's Avatar
Quoted: 227 Post(s)
Liked: 168
You need to go somewhere and listen to a variety of speakers and decide which ones you like, because speaker preferences are quite personal in nature. My suggestion is to take a look at speaker recommendations at sound and vision dot com, and then track down dealers for the speakers in your budget range. I personally like speakers from B&W, KEF, PSB, Paradigm, Golden Ear, etc, but there are lots of other really good speakers out there. No one will be able to tell you exactly which speaker set up you should buy, This is a very personal decision that only you can make after listening to them in a good acoustic environment.
Good luck in your search and let us know what you eventually buy.
dsrussell likes this.
Cal68
Cal68 is offline
post #11 of 12 Old 07-18-2014, 03:35 PM
afrogt's Avatar
Quoted: 1369 Post(s)
Liked: 948
One of these subwoofers should suffice for $500 - $600
http://www.svsound.com/subwoofers/ported-box/PB-1000
http://outlawaudio.com/products/lfm1plus.html
http://outlawaudio.com/products/lfmEX.html
That leaves you roughly $2500 for speakers.
Where are you located? What stores do you have nearby?
You want in-wall/ in-ceiling speakers for everything? Why? That sure reduces the quality of your system.
Afro GT
afrogt is online now
post #12 of 12 Old 07-19-2014, 03:15 PM - Thread Starter
rinku2012's Avatar
Quoted: 24 Post(s)
Hi ,
thanks for the suggestions. i live in Bay area ( San Jose,CA). i will go to bestbuy or frys and check the speakers sound quality. Please suggest me a receiver which is compatible to 7.1 system and I am looking for HDMI 2.0 and Dolby Atmos compatible
I have a 7.1 speaker system which is pre wired in my home through the walls. this is why i am looking for in wall speakers
Reply Speakers
