Surround Sound Suggestions? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 06-24-2014, 09:24 AM - Thread Starter
Iownyoujk's Avatar
Hey I have visited the forum before regarding if my uncle had ripped me off and had a tremendous amount of help and feedback, thankfully I went with the recommendations on the forum and have been more than happy with what I have ended up with. Here is the current setup that I have:
Bic America F12:
www.amazon.com/BIC-America-F12-475-Watt-Subwoofer/dp/B0015A8Y5M
Pioneer SP-BS41-LR 130 Watt RMS 2-Way Speakers:
http://www.amazon.com/Pioneer-SP-BS4.../dp/B0045US6DE
DENON-AVR-1612-5.1-Channel-A/V-Home-Theater-Receiver
I am not 100% sure where to go from here, the questions I had were:
What bookshelf speakers should I get?
How do I set up the surround sound on my speaker?
Once I have 4 speakers should I put one in each corner of the room?
Any help/suggestions are appreciated!
Iownyoujk is offline
post #2 of 6 Old 06-24-2014, 09:29 AM
crazyrob425's Avatar
Quoted: 443 Post(s)
Liked: 337
You need a center channel. The Pioneer SP-C21 Center is the matching one.
Then read the Denon AVR-1612 manual cover to cover.
crazyrob425 is offline
post #3 of 6 Old 06-24-2014, 09:32 AM
zieglj01's Avatar
Quoted: 943 Post(s)
Liked: 846
Speaker placement options
http://www.crutchfield.com/S-NUQSkBC...placement.html
__________________________________________
Who AM I
Speakers > Snell K7, EOS 150SP
Receiver > Tascam PAR-200
zieglj01 is offline
post #4 of 6 Old 06-24-2014, 07:53 PM - Thread Starter
Iownyoujk's Avatar
My room is basically a fairly square room if that helps at all.
Would it be ideal to buy another of the same pair of speakers that I already have? (Pioneer SP-BS41-LR 130 Watt RMS 2-Way Speakers
Would the surround sound work ok with speakers around all four corners of the room?
What plug in does a center channel use on a receiver?
Where would an ideal place be to put a center channel in the room?
Thanks again for the help!
post #5 of 6 Old 08-14-2014, 01:47 PM - Thread Starter
Iownyoujk's Avatar
I don't mean to bump this but I'm still unsure of these things.
post #6 of 6 Old 08-14-2014, 01:52 PM
djp2k7's Avatar
Quoted: 108 Post(s)
Liked: 46
Please follow the link that Ziegl posted above. It has excellent info on speaker setup.
djp2k7 is offline
Reply Speakers
setup , sound , suggestions , surround
