Suggestion for 5.0 setup (3 L/C/R satellite white) + 2 Rear In-Ceiling for under $1k - AVS Forum | Home Theater Discussions And Reviews
Old 06-25-2014, 02:45 PM - Thread Starter
atwnsw's Avatar
Quoted: 20 Post(s)
Suggestion for 5.1 setup (3 L/C/R satellite white) + 2 Rear In-Ceiling for under $1k
Current equipment is:
Denon AVR-X2000
Sony BDP-S6200
Apple TV
(In process of buying TV...)
The room dimensions are 17" x 15".
75% - Movies. 25% - TV.
I already have a subwoofer so I don't necessarily need to spend money at this time to replace it. It is hidden behind sofa so can be any color.
Front Speakers L/C/R: Need 3 white satellite speakers to be mounted to ceiling..
Rear speakers: In-Ceiling. These will be used over the sofa.
Now that I have purchased the equipment, I am ready to pull the trigger on my speakers.
Thanks in advance....
Current Front Speakers in Black:
Current Rear Speakers in Black:
atwnsw is offline
Old 06-25-2014, 04:16 PM
mtn-tech's Avatar
Quoted: 232 Post(s)
Liked: 178
For really small speakers, it is hard to beat Definitive Technology. Their speakers with 4 1/2" mid-range drivers sound like much bigger speakers. And some of their in-wall / in-ceiling speakers have integrated cabinets and sound like real speakers even when mounted in the wall or ceiling.
These come in white and can be purchased individually:
http://www.definitivetech.com/products/promonitor-1000
Very good in-wall speakers:
http://www.definitivetech.com/produc...ling-speakers/
2-Ch (HT L/R): Oppo BDP-105 BD, Adcom GFP-750 pre, Bryston 10B Sub Xover, Bryston 4BSST2 / Paradigm Signature S4 v.2 (L/R), (2) SVS SB12-NSD (Subs)
Home Theater: Bryston 4BSST2 amp / Paradigm CC-590 (C), Outlaw 7700 amp / (4) Def Tech UIW-RSSII (LS/RS/LB/RB), Samsung 46” 3D LCD
mtn-tech is offline
Old 06-26-2014, 06:03 PM - Thread Starter
atwnsw's Avatar
Quoted: 20 Post(s)
If I did the Promonitor 1000 for L/R, would I need to do the 2000 for center?
Also, how reprehensible is it to do the Boston Acoustic In-ceiling from A4L?
I remember reading that you shouldn't mix manufacturers but not sure why.
Finally, is Promonitor the only quality game in town for quality white satellite speakers?
Thanks again for your input.
atwnsw is offline
Old 06-26-2014, 06:44 PM
crn3371's Avatar
Quoted: 239 Post(s)
Liked: 192
You could get a 3rd ProMonitor 1000 for a center, provided you could mount it vertically. The matching center would be the ProCenter 1000. The 2000 center doesn't come in white. Another option would be the B&W M-1's in white.
crn3371 is offline
Old 06-26-2014, 10:20 PM - Thread Starter
atwnsw's Avatar
Quoted: 20 Post(s)
As an alternative, if I would consider 5 white satellite/bookshelf speakers for both front & rear, meaning a 5.1 configuration since I already have a subwoofer, any other options worth looking at for $1,000?
atwnsw is offline
Old 06-26-2014, 10:27 PM
thegardentool's Avatar
If you did decide to go with the Definitive Tech speakers, bajawaverunner on eBay does have some of the white ProMonitors in stock so you could save some money if you don't mind refurbished items with only 90 day warranty as opposed to their normal 5 year warranty. Not sure how perfect of a match they are but they do have some 4.5" and 6.5" DI series in-ceilings in stock as well.
thegardentool is offline
Old 06-26-2014, 11:27 PM
cel4145's Avatar
Quoted: 2653 Post(s)
Liked: 2984
NHT makes great bookshelf speakers, and some of the models come in white: http://www.nhthifi.com/Bookshelf-Speakers
They also have in-ceiling speakers: http://www.nhthifi.com/In-ceiling
Living room HT: Energy RC-50, Ascend Sierra Horizon w/RAAL, Ascend Sierra 1, PSB Imagine XA | PSA V1500 and CHT SS 18.1 | Denon X4200W | modified Dayton SA1000
Other rooms: CBM-170 SE | SVS SB-1000 | Audio-GD NFB-11 | Parasound Zamp | JBL LSR305
Headphone & Portable AKG K7XX | NAD HP50 | AKG K550 | Soundmagic E50 & E80 | DX50 | E12 | X1
cel4145 is online now
Old 06-27-2014, 12:17 AM
RayGuy's Avatar
Quoted: 733 Post(s)
Liked: 596
Denon AVR-X2000
Sony BDP-S6200
Apple TV
Seems to me that some white speakers were recommended in your previous thread from a few months back ....
RayGuy is offline
Old 06-27-2014, 05:46 AM
Transmaniacon's Avatar
Quoted: 1530 Post(s)
Liked: 1319
+1
I would go with three Absolute Zero bookshelves in white for the front, and then a pair of Polk OWM3 in white for your surrounds. There isn't a problem with having a different brand for the surrounds, just the front three need to match. You can also get on-wall versions of the Absolute Zero which aren't as deep and would probably work better.
AZ On-Wall (White): http://www.nhthifi.com/Home-Theater-...&category=3772
OWM3 (White): http://www.amazon.com/Polk-Audio--Wa...olk+Audio+OWM3
Samsung PN60F5300 | Denon AVR-1713 | EMP E55Ti | EMP E56Ci | EMP E5Bi | Outlaw Ultra-X12
Transmaniacon is offline
