Speaker System below £300 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 06-26-2014, 01:58 AM - Thread Starter
Liked: 0
Question Speaker System below £300
Hi
Basically I am looking for some new speakers that cost less than £300. I have no idea what I should be looking for really and so I am looking for some advice.
They will be plugged into my computer which has an asus Maximus V Extreme motherboard with a decent on-board soundcard.
I mainly listen to Hip hop, dance, electronic music, so the bass is the most best part for me, after that I listen to alot of rock so those are really the only preferences.
I have been looking around and some people said that a 2.1 decent pc set are good, others are saying that a pair of bookshelve speakers, a good subwoofer and an amp are the way to go. Any help would be much appreciated.
DJ1249 is offline
post #2 of 5 Old 06-26-2014, 10:35 PM
cel4145's Avatar
Quoted: 2668 Post(s)
Liked: 3002
Wharfedale makes good passive speakers and is a UK brand. You might look into them. I don't know what the good values are on subwoofers in the UK.
For computer multimedia speakers, Edifier is a popular brand in the UK.
If you were wiling to build in pieces, a good route to go could be to get powered studio monitors with your current budget, and then buy a sub on down the road after you save up for it separately.
Living room HT: Energy RC-50, Ascend Sierra Horizon w/RAAL, Ascend Sierra 1, PSB Imagine XA | PSA V1500 and CHT SS 18.1 | Denon X4200W | modified Dayton SA1000
Other rooms: CBM-170 SE | SVS SB-1000 | Audio-GD NFB-11 | Parasound Zamp | JBL LSR305
Headphone & Portable AKG K7XX | HE-400i | NAD HP50 | Sony MDR-1A | Soundmagic E50 & E80 | X5ii | DX50 | E12
cel4145 is offline
post #3 of 5 Old 06-27-2014, 02:41 AM
fatbottom's Avatar
Quoted: 1420 Post(s)
Liked: 520
If you have more than one source, I'd recommend passive speakers. Active speakers only have a single input, unless you then use a amp to switch inputs. You could consider second hand, you'd get some nice standmounts for £300.
fatbottom is offline
post #4 of 5 Old 06-27-2014, 04:19 AM
commsysman's Avatar
Quoted: 1080 Post(s)
Liked: 569
Originally Posted by DJ1249 View Post
Hi
A decent amp plus bookshelf speakers is going to run more like 600L.
Some powered speakers are in your price range, but I don't know what is available in the UK.
I use the Audioengine 2, which are very good.
If you want to switch between sources, there are switch boxes that are very inexpensive and usually will let you switch between 4 sources.
commsysman is offline
post #5 of 5 Old 06-27-2014, 04:31 AM
fatbottom's Avatar
Liked: 520
but also need hdmi, hdmi audio..xbox ps3 etc
Reply Speakers
Bookshelf Speakers , Speaker Systems , subwoofer
