Used equipment store in NYC? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 06-26-2014, 11:34 AM - Thread Starter
Liked: 0
Need a recommendation for low budget bookshelf speakers
Hi all,
I need a recommendation for a pair of bookshelf speakers for a mid-size room for stereo listening. I mainly listen to jazz and classic rock. Budget is around $100-$150 for the speakers only.. another $100-$150 for the amp. Saw that the Pioneer SP-BS22-LR are getting good reviews, anyone has an opinion on these?
nadav2605 is offline
post #2 of 8 Old 06-26-2014, 03:06 PM
dftkell's Avatar
Quoted: 74 Post(s)
Liked: 68
Originally Posted by nadav2605 View Post
Hi all,
Does anyone know of a good place to buy used stereo speakers & amp in NYC?
Also, I need a recommendation for a pair of bookshelf speakers for a mid-size room for stereo listening. I mainly listen to jazz and classic rock. Budget is around $100-$150 for the speakers only.. another $100-$150 for the amp. Saw that the Pioneer SP-BS22-LR are getting good reviews, anyone has an opinion on these?
The Pioneer's are very good budget speakers. The Infinity Primus speakers are also very good. I think those are your best choices.
There isn't a place to buy used equipment in NYC. You're best bet is Craigslist. If you're patient, you'll find something. Of course eBay is an option as well.
dftkell is online now
post #3 of 8 Old 06-26-2014, 10:22 PM - Thread Starter
Liked: 0
Thank you! I used to own the mission m31.. How are these compared? Are they better/worse?
post #4 of 8 Old 06-27-2014, 04:42 AM
RC1991's Avatar
Quoted: 29 Post(s)
Hi all,
Stereo Exchange in NYC sells used equipment and also have an eBay store.
RC1991 is offline
post #5 of 8 Old 06-27-2014, 05:56 AM
dftkell's Avatar
Quoted: 74 Post(s)
Liked: 68
I haven't been there in years. I didn't know that.
post #6 of 8 Old 06-27-2014, 06:25 AM
Ears to you's Avatar
Hi all,
Hi nadav,
I also live around NYC, and I sent you a Private Message through this site about what you were asking about.
Best,
Bob
Ears to you is offline
post #7 of 8 Old 06-27-2014, 06:38 AM
dftkell's Avatar
Quoted: 74 Post(s)
Liked: 68
I have no idea how they compare to the Missions. But honestly, for your budget, I wouldn't even worry about it.
Here are your best choices for new, best bang for your buck, speakers.
1. Pioneer bookshelf
http://www.amazon.com/Pioneer-SP-BS4...oneer+speakers
http://www.amazon.com/Pioneer-Subwoo...neer+subwoofer
2. Infinity bookshelf
http://www.amazon.com/Infinity-Primu...inity+speakers
3. Infinity floorstanding speaker.
http://www.amazon.com/Infinity-Primu...rimus+speakers
The Pioneer is excellent, one of the best values out there, but the Infinity will go a bit lower. It is a bit more money though. The floor standing Infinity is off the charts for a floor standing value. But again, you're spending a bit more.
Some receiver/amplifier choices (You've gotta go used here, but that's okay):
http://newyork.craigslist.org/mnh/ele/4532381671.html
http://newyork.craigslist.org/mnh/ele/4535971858.html
Get your cables from Monoprice. If you go with one of the bookshelf speakers, keep in mind you'll need to buy stands if you don't already have them.
Also:
http://newyork.craigslist.org/brk/ele/4499222477.html
Good luck
post #8 of 8 Old 06-27-2014, 09:01 AM - Thread Starter
Liked: 0
Also:
Good luck
Thank you so much for your detailed response. I will check them out. In the meanwhile I found a few more options.. What do you think of these?
http://www.ebay.com/itm/Roth-Oli-1-L...item563eb3ae4c
http://www.ebay.com/itm/CAMBRIDGE-AU...item1e8d77c413
http://www.ebay.com/itm/Q-ACOUSTICS-...item3cce0b2156
http://www.amazon.com/Boston-Acousti.../dp/B004LA96M8
Reply Speakers
bookshelf , hifi , nyc , speakers
