Have $1350 to spend for speakers - AVS Forum | Home Theater Discussions And Reviews
 7Likes
  • 2 Post By Transmaniacon
  • 1 Post By zieglj01
  • 2 Post By jdcrox
  • 1 Post By cel4145
  • 1 Post By ScottS
post #1 of 17 Old 06-26-2014, 06:33 PM - Thread Starter
Liked: 0
I'm in the market and want to purchase floor standing speakers to put in my family room. It pretty open room with hardwood floors. I do not have any equipment as of yet and plan on buying speakers first. I'm thinking 2.1 channel.
Going to use it for music, movies and xbox. Will probably get a svs sub down the line.
I'm not looking for a massive floor standing speaker and want it to look good and perform well. I'm looking to get the new monitor audio silver 6 in gloss white. I can get them for $1350 and I'm looking to see what else is there in this price range.
Dangerzone9k is offline
post #2 of 17 Old 06-26-2014, 10:22 PM
cel4145's Avatar
Quoted: 2668 Post(s)
Liked: 3002
Great deal on these Focal Chorus: http://www.accessories4less.com/make...-havana/1.html
With the savings, you could start putting money away toward your sub
Living room HT: Energy RC-50, Ascend Sierra Horizon w/RAAL, Ascend Sierra 1, PSB Imagine XA | PSA V1500 and CHT SS 18.1 | Denon X4200W | modified Dayton SA1000
Other rooms: CBM-170 SE | SVS SB-1000 | Audio-GD NFB-11 | Parasound Zamp | JBL LSR305
Headphone & Portable AKG K7XX | HE-400i | NAD HP50 | Sony MDR-1A | Soundmagic E50 & E80 | X5ii | DX50 | E12
cel4145 is offline
post #3 of 17 Old 06-27-2014, 04:25 AM
commsysman's Avatar
Quoted: 1080 Post(s)
Liked: 569
The PSB Image T6 speakers are the best I know of at that price. I had them for two years and they are very good.
They were chosen as speaker of the year by both Stereophile and The Absolute Sound a couple of years ago.
The list price is $1299, but Saturday Audio has them for $999.
commsysman is offline
post #4 of 17 Old 06-27-2014, 04:38 AM
Transmaniacon's Avatar
Quoted: 1586 Post(s)
Liked: 1394
I would take a look at the NHT Absolute Tower, it's not a full-sized tower and measures incredibly well. Also take a look at the Goldenear Triton 7 Tower, these speakers sound excellent and I am strongly considering them if I upgrade.
I'd also recommend looking at a nice pair of bookshelves instead of towers. For a tad more money you could get a pair of the Ascend Sierra-2 bookshelves which are incredible sounding. They were just released and succeed the very popular Sierra-1 bookshelves. Since you will be adding a sub, the lower extension of towers compared to bookshelves is wasted and the end result is essentially the same sound. Difference being $1350 buys you a better bookshelf than it does a tower.
bluerondo56 and kpotier16 like this.
Samsung PN60F5300 | Denon AVR-1713 | EMP E55Ti | EMP E56Ci | EMP E5Bi | Outlaw Ultra-X12
Transmaniacon is offline
post #5 of 17 Old 06-27-2014, 05:10 AM
cranster's Avatar
Quoted: 155 Post(s)
Liked: 89
I'm looking forward to mine arriving. I just ordered 3 sierra 2's for lcr, and an lv12r sub. I'm going to hold off on a new avr until the atmos avr's are out. I'm thinking the denon x4100, and possibly 4 sierra 1's for heights, but will wait to see if atmos is the real deal or hype first.
cranster is offline
post #6 of 17 Old 06-27-2014, 05:14 AM
Liked: 1394
Excellent choice! From what I can tell Atmos is probably going to be a success since Dolby is behind it.
post #7 of 17 Old 06-27-2014, 02:51 PM - Thread Starter
Liked: 0
Thanks for the other recommendations. I think I'm really set on floor standing speakers. I just like the way they look. I'm leaning towards the silver 6 because they have a gloss finish and magnetic grill. Just look very clean I'm sure other speakers might sound better in the price range but will not look as nice (build quality).
post #8 of 17 Old 06-27-2014, 02:59 PM
fatbottom's Avatar
Quoted: 1420 Post(s)
Liked: 520
Generally you need to spend quite a bit on floorstanders, personally I'd say $1000 minimum
fatbottom is offline
post #9 of 17 Old 06-27-2014, 03:39 PM
zieglj01's Avatar
Quoted: 1713 Post(s)
Liked: 1627
Monitor Audio Silver is a good option - and they can hold their own,
with a lot of speakers out there.
postrokfan likes this.
__________________________________________
Who AM I
Speakers -- Canton GLS 2 > Boston VS240
Receiver -- Integra 50.2
zieglj01 is offline
post #10 of 17 Old 06-28-2014, 10:31 AM
RayGuy's Avatar
Quoted: 996 Post(s)
Liked: 877
Second the recommendation of Golden Ear Triton 7. Go listen, let your ears decide!
RayGuy is offline
post #11 of 17 Old 06-28-2014, 03:50 PM
kpotier16's Avatar
Quoted: 14 Post(s)
Don't do 2.1 with towers. You should either do a 2.0 with the towers or a 2.1 with bookshelves. Towers are designed to have strong bass and so are subwoofers of course. This means that you would have to keep the sub volume really low to have the system sound decent, basically making the sub a waste of money.
kpotier16 is offline
post #12 of 17 Old 06-28-2014, 04:05 PM
The Murderousone's Avatar
Quoted: 261 Post(s)
Liked: 77
Golden ear triton seven. /THREAD GAMEOVER
The Murderousone is offline
post #13 of 17 Old 06-29-2014, 06:40 AM
jdcrox's Avatar
Quoted: 80 Post(s)
Liked: 107
This is really wrong. Unless you spend a lot of money, most towers peter out well above what a decent subwoofer will bring to the table. And by limiting your towers to 60 or 80 HZ, you will take a big load off of the receiver's amps. Not just my opinion!
darthray and marquee-moon like this.
jdcrox is offline
post #14 of 17 Old 06-29-2014, 07:19 AM - Thread Starter
Liked: 0
I'm pretty much set on the monitor audios silver 6. They go down to 35hz and will probably get a svs sb1000 sub because it's not as massive as the pb1000. Do you guys think I should get an emotiva amp?
post #15 of 17 Old 06-29-2014, 07:34 AM
cel4145's Avatar
Liked: 3002
Might as well not bother with the amp since the sub you have picked out for yourself might not be able to keep up with your speakers as it is.
I have an SB-1000. Nice "compact" 12" sealed sub. Sounds great, but they are designed for smaller rooms and/or moderate listening volumes in a medium sized room. Sub performance is related to room size. How big your room is and how loud you listen determines what sub you need.
How big is your room (volume-cubic feet), including any open adjacent areas?
darthray likes this.
cel4145 is offline
post #16 of 17 Old 06-29-2014, 10:18 AM
ScottS's Avatar
Quoted: 26 Post(s)
I haven't listened to them but... I have heard raves about the KEF LS-50. If you google them you'll see that every magazine and website offers high praise: http://www.kefdirect.com/ls50.html
I know these are minimonitors, but I think they might be worth a listen and are right at yor price point.
Scott
schowtyme likes this.
ScottS is offline
post #17 of 17 Old 06-29-2014, 10:39 AM
schowtyme's Avatar
Scott
I have to echo what Scott said, I bought a pair of LS50s a little over a month ago from a local dealer for exactly $1350 and they are absolutely amazing. I auditioned everything I could around me (B&W, Def Tech, Martin and Logan, Polk, Klipsch) and to me they sounded like they were on a whole different level. They seem much more accurate, and the imaging for music is almost surreal (check the thread on Audiokarma for more details).
If you are going to buy the sub anyway to fill out the bass you might as well listen to a pair before you decide, I really think you will be impressed.
I've also heard the Ascend Acoustics Sierra-2s are supposed to be amazing but I've never had a chance to hear them. Could be worth buying a pair and auditioning at home to see what they are like, I haven't read any posts comparing them to the Kefs though. Whatever you do, audition as many as you can, I thought I was set on the new B&Ws before I heard the LS50s.
schowtyme is offline
Reply Speakers
