SVS Ultra center review - AVS Forum | Home Theater Discussions And Reviews
 3Likes
  • 1 Post By mpjmeyer
  • 2 Post By rbkraz
post #1 of 14 Old 06-26-2014, 08:07 PM - Thread Starter
mpjmeyer's Avatar
Quoted: 118 Post(s)
Liked: 34
I must say I am very impressed with SVS. I purchased 2 PB-2000's (which I reviewed in a different post) and the SVS Ultra center speaker. I am in construction of my home theater which will take awhile to complete so I went WAY outside my budget to get more for my buck (I am a strong believer in "you get what you pay for"). It will take me a bit to save for the rest of the SVS ultra line, but will be worth every penny when I'm done.
I went to Best Buy looking to buy the Bose surround setup. Once I heard the Klipsch Icon speakers, I immediately changed my thoughts. The Klipsch sounded crisp, clear, and loud. I honestly didn't think another speaker could match it. Not until I came across the SVS line!!!
Please don't get me wrong, the Klipsch sounded great, but didn't blend with the PB-2000's like I was hoping. When I sat in the room and closed my eyes, I could tell exactly where the center and subs were by pointing my finger.
When I first got the speaker, first I noticed was the size difference. This is almost twice the weight, longer and wider than the Klipsch.
I hooked the SVS up and immediately noticed a difference. The SVS filled the air with it's presence. It ALMOST reminded me of a soundbar, bringing sound to all points of the room. I couldn't tell where any of the subs were when I closed my eyes, the SVS center took over the show and turned the segregation into a party. There wasn't even distortion when cranked to 0dbs. Both speakers have identical wood paneling so can't say much about the designs, except that they are real eye catchers. Just like the PB-2000's, I don't think I will have the grill on this either. I was so happy with the sound and look of the SVS that I found myself starring at the speakers more than the movie I tested out.
In conclusion, if you are on a budget, I would highly recommend the Klipsch series speakers, but if you are looking for a setup that will have your guests talking and asking questions, go for the SVS. The sound, build and especially customer service are worth every dime spent.
Matt2026 likes this.
mpjmeyer is offline
post #2 of 14 Old 06-26-2014, 08:08 PM - Thread Starter
mpjmeyer's Avatar
Quoted: 118 Post(s)
Liked: 34
mpjmeyer is offline
post #3 of 14 Old 06-26-2014, 08:14 PM - Thread Starter
mpjmeyer's Avatar
Quoted: 118 Post(s)
Liked: 34
Here is the review for the PB-2000's
What's the BEST HT Subwoofer??
mpjmeyer is offline
post #4 of 14 Old 06-27-2014, 05:55 AM
fatbottom's Avatar
Quoted: 1420 Post(s)
Liked: 518
Having had a center with BMB + treble I wouldn't go back to MTM layout. Although I don't like ported center, and rear ports causes problems with placement
Got a Kef Refence Model 200 and also trying to find a Celeston A4C
fatbottom is offline
post #5 of 14 Old 06-27-2014, 06:40 AM
Elihawk's Avatar
Quoted: 981 Post(s)
Liked: 829
Well, not really a fair comparison! The Klipsch Icon center is like $250 and the SVS ultra is $700 at most vendors!
The really big suprise would be if the SVS didn't sound way better than the Klipsch!
Set up #1: EMP e5ti, e5Ci, and EMP e5Bi surrounds, Outlaw LFM1 Plus sub, EMP 10i10i sub
Set up #2: Def Tech SM450, CLR2002, SLS Qline surrounds and Klipsch 12wD sub
Set up #3: Philharmonics- BMR in a 2.0 system, music only
Elihawk is online now
post #6 of 14 Old 06-27-2014, 08:10 AM - Thread Starter
mpjmeyer's Avatar
Quoted: 118 Post(s)
Liked: 34
I wasn't trying to do a side by side comparison, just showing you what the difference is when an extra $450 comes into play.
mpjmeyer is offline
post #7 of 14 Old 06-27-2014, 08:20 AM
crazyrob425's Avatar
Quoted: 443 Post(s)
Liked: 337
Now you sold yourself on the SVS Center finish your system with the SVS Ultra Bookshelfs and you are golden.
crazyrob425 is offline
post #8 of 14 Old 06-27-2014, 11:23 AM - Thread Starter
mpjmeyer's Avatar
Quoted: 118 Post(s)
Liked: 34
That's next on the list. Would it be wise to match the rears as well or would that really matter?
mpjmeyer is offline
post #9 of 14 Old 06-27-2014, 12:50 PM
fatbottom's Avatar
Liked: 518
The SVS rears are pretty expensive though. I wouldn't spend more on surrounds/sides on the front/center (even though they match) My sides were about £300 a pair.
post #10 of 14 Old 06-27-2014, 12:57 PM
Quoted: 443 Post(s)
Liked: 337
If you want the best possible sound matching the rears to the fronts would be the best.
Its not necessary but that is what would be best.
As for the price being really high. Thats why you start with budget number in mind and you stick to it.
But if you want the best I would suggest the SVS Surrounds or another pair of Bookshelfs for surround duty.
You would be able to get away with a cheaper surrounds until you can afford the matching ones.
post #11 of 14 Old 06-27-2014, 01:05 PM - Thread Starter
mpjmeyer's Avatar
Quoted: 118 Post(s)
Liked: 34
Nah, I'd rather save the money instead of settling for cheaper speakers just to save for better ones anyway.
mpjmeyer is offline
post #12 of 14 Old 06-27-2014, 02:09 PM
fatbottom's Avatar
Liked: 518
I agree. The surrounds are 200 euros more Granted they have twice as many drivers, but still, that's why I never got considered M&K tripoles (I liked them), they cost more than my fronts!
post #13 of 14 Old 02-19-2016, 07:06 PM
Quoted: 27 Post(s)
Liked: 7
Thanks for your review sir. I'm actually doing an upgrade as we speak. I'm currently using a Polk CSI A6 center and it's just not cutting the cake. I'm with you on saving up the money for the ultra. I know this thread was a while ago but hope you are still loving it.
btbed is offline
post #14 of 14 Old 02-19-2016, 08:11 PM
Quoted: 22 Post(s)
Liked: 4
I really need infinite amount of money.
zencarver and Matt2026 like this.
rbkraz is offline
Reply Speakers
